The second thing I would check is to make sure you have 0* pitch at mid stick. Plug everything in and fold the blades back, put your throttle stick at mid stick, the blades should be even with each other. Someone on this thread also posted a photo where he took the blades off and put toothpicks in the screw holes then put the stick at mid, the toothpicks should be even with each other. |
I first flew helis back around 25 years ago in the early days of Concept 30s which I had two of I also had a Kalt Cyclone 50 and a Kalt Whisper which was the first CP electric Heli to the best of my memory. Back then gyro sucked big time,it was difficult to get the engine and collective pitch cures matched so the engine would not bog at most settings, if one used a tuned pipe (exhaust system) which I di then the engine was on the pipe for a very limited range of RPMs. There were no really go computerized Heli Transmitters so much had to be setup by mechanical means. Long servo arm on the collective, shorter on the engine, neither at 90 degrees to servo. It was a royal PITA but could be done. I in fact learned to fly these monstors and did fairly well . Life,family,work got in the way so I went back to planes which wer much simpler,less mainataince and I had mastered many years prio. About 3 years ago I got anBlade CP from my son that he had coverted to Brush Less. I put a more powerful motor in it ,made a custom taill rttor setup withg two motors driving a single blade and fly it rather well and had a lot of fun with it. Next I purchased a Blade 400 and learned that out of the box it was barely flyable. I updated, servos,gyro, motor ,ESC and had it flying good but everytime I crashed it was a $50 to $100 and several hours of repaire. After abouyt 6 such crahes I set it on a shelf. A little over two months ago I ourchased a mCPX and I have had a ball with it. I have since purched a used one converted to BL ,converted my original to BL and have a new one in the box for parts ./ backup and later today I will be converting my son's mCPX V1 to BL with a stup more powerful than mine as he said he needs even more power. Bottom line hang in there, read a lot, learning the machinics / setups is difficult for most. practice and it will all come together for you. |
..... Can we agree that not everyone fly the same, not everyone will like the same set up, not every heli is the same. I have my heli that has 301 flights on it, Every since I got it day one I have had to fly it with 50% pitch cause that was only way to get zero pitch at center the links are not long enough for me to do it manually so i am running like 100%L and 80%H on the settings but it fly great Just got a newer heli for my gf and guess what it took 0 on pitch and were flying it at 70% H and L it fly great. I have now flown like 5 different MCPX's none of them fly just the same but I have no issues with what i call mild 3d back flips, front flips, side flips, nose in, tail in, rainbows, inverted hover, punch outs. piros, All of these were brushed then one was Bl now another is BL. Guess it true when your good your good. first time i try the KB blades I hated them went back to stock for 200 more flights but then I put them back on when got good battery's, they flew great i thought for about 75 flights, well now im back to flying stock blades they give lil more power but the Bl set up I have flown has KB and fly great not flown it with stock ones might be like WOW what a difference but then maybe not. |
Just flew the heli and I am now hovering at 55% stick.
Here is vid showing my pitch, alot easier to see. Looks good to me. http://www.youtube.com/watch?v=_iWYb...ature=youtu.be |
At about 13 seconds he did a half piro flip. Starts inverted nose in...rolls right with aileron...ends upright tail in. If you use aileron to roll and it changes from nose in to tail in...it obviously did a half pirouette. It's fast and hard to see but it's definitely a half piro flip. |
inverted nose in then rolls over then flips forward to end up tail in, guess need some slow motion video, i really do want to learn it but just not sure how to go about it. it seems your classified as a really good pilot if you can do them |
Joined Apr 2009
http://www.rcgroups.com/forums/showthread.php?t=1409275 Don |
It's all timing. You want to flip or roll while doing a piro. You need to stir the cyclic stick to keep the flip going. If you're holding the rudder to the left to do a counter clockwise piro...you need to stir the cyclic stick clockwise at the same rate as the piro. Say you're trying to flip forward... You start by pushing the stick forward but the nose is turning away so you need to stir it to the right since the right side of the heli is now facing straight away. As it continues the piro,keep pushing the cyclic to move the heli straight away. Get it? The nose is away. Forward cyclic The right side is away. Right cyclic The tail is away. Rear cyclic The left side is away. Left cyclic The right stick goes in the opposite direction of the piro at exactly the same speed. You need to learn to hold a pirouette in one place for as long as you want. The piro tricks are easy.
OK...is your throttle hold on? If it is,you haven't even checked your pitch in any of the other flight modes. You've only checked your pitch in throttle hold. That said,it should be the same pitch curve in ST1,ST2 and TH anyway but still...throttle hold disables the idle up switch. |
How do I look at the pitch curve while moving the sticks without the blades turning? I thought throttle hold was the only way to look at this without the blades turning. |
If throttle hold is on,that's the only pitch curve you're checking. Throttle hold has its own pitch curve. If you set your other pitch curves the same as your throttle hold curve,you should be good anyway. |
| Thread Tools | |
| Discussion Blade mCP X BNF Heli... | ChuckTseeker | Micro Helis | 15111 | Yesterday 09:50 PM |
| Discussion Blade mCP X Discuss anything thread | A Rdnek | Micro Helis | 457 | Jul 26, 2011 11:34 PM |
| Discussion The New BLADE mCP X Has Arrived... | ChuckTseeker | Electric Heli Talk | 38 | Mar 27, 2011 07:35 PM |
| Discussion new blade mcp X anyone know anything new. | epoweredrc | Atlanta Area RC | 6 | Mar 16, 2011 08:14 PM |
| Discussion Blade mCP x - strictly on topic Q and A thread | jdog83 | Micro Helis | 58 | Feb 07, 2011 02:28 PM |
