Is the mai gear pushed all the way up so there is no end play (up and down) o he main shaft? You must start here or other setting mean nothing. With this setup and the setting recomended in the maual the heli should hiver at aprox. 65% throttle / collective. Out of the box many of these require that the servo links be turned out (made longer) two or three full turns. That means out of the box they have to little positive pitch and to much negative pitch. Here is a video and also a bunch of links to help out. http://www.helifreak.com/showthread.php?t=342153 |
Well, I am not sure if this is what I want of not???
I thought I would post a vid to see if you guys could give me some feedback. There is definitely way more pitch between half stick and full as opposed to half stick to zero throttle. http://youtu.be/im2EdUBcH0U |
United States, CT
Joined Apr 2012
I was tol that I need to set the pitch to zero at half stick. Now I have a lot of power and hover around 55% throttle, but I am afraid that I hve very little negative pitch. I can't tell yet because I am not ready to flip the heli and find out. ![]() I was hoping the vid would show something that I missed. |
United States, CT
Joined Apr 2012
![]() But I'm no expert so I could be completely wrong. |
I'm not quite there yet. I have 13 flights and everything still works. ![]() I have a feeling, this was a good heli to learn on but not one to expect a whole lot of stability. Everyone at my club flies 600's and 700's so it's hard to expect much out of this little guy. |
United States, CT
Joined Apr 2012
This heli can do quite a lot and I think it's very stable considering how small it is. I'm having a blast with mine. |
United States, CT
Joined Apr 2012
Going back and flying my 120SR after spending tons of hours with my new mCPX, I had to turn the high rates on (inside in a small room), the darn thing doesn't respond fast enough! So used to the sensitive controls and the quicker response of the mCPX now!
Sorry if I sound like a smart ass but by the time you get to this point
you should better understand setups such as zero pitch atr mid stick and why, different throttlre cyrevs for Normal , St/ 1 and St,2 why some baldes work better with less pitch and some better with more pitch , why some are better at low HS and some better at higjh HS. A heli is an extremly complictaed piece of equipment. These are not Air Hog vclass toy helis they are very complex CP semi high performane piece of equipment. FYI You can unplug the main and tail motor plugs flip to St 1 and St 2 and check postive and negative pitch at the blades as long as you desire to do so. Charles |
If the throttle hold is on,now matter what you do with the flight mode switch,the pitch won't change. Throttle hold has it's own pitch curve. Throttle hold has it's own throttle curve. With throttle hold switch on,the idle up switch is disabled. I know you said throttle cut and not throttle hold but a lot of people confuse the two and not all radios have a throttle cut feature. |
| Thread Tools | |
| Discussion Blade mCP X BNF Heli... | ChuckTseeker | Micro Helis | 15111 | Yesterday 09:50 PM |
| Discussion Blade mCP X Discuss anything thread | A Rdnek | Micro Helis | 457 | Jul 26, 2011 11:34 PM |
| Discussion The New BLADE mCP X Has Arrived... | ChuckTseeker | Electric Heli Talk | 38 | Mar 27, 2011 07:35 PM |
| Discussion new blade mcp X anyone know anything new. | epoweredrc | Atlanta Area RC | 6 | Mar 16, 2011 08:14 PM |
| Discussion Blade mCP x - strictly on topic Q and A thread | jdog83 | Micro Helis | 58 | Feb 07, 2011 02:28 PM |
