Old May 13, 2012, 12:52 PM
mr_nd is offline
Find More Posts by mr_nd
From Russia with Love. To fly.
mr_nd's Avatar
Russia, Moscow
Joined May 2008
fun with mcp x:
Blade MCP X. Trying to cut the grass :) (1 min 40 sec)
On the first few seconds video, inverted mcp x cut the grass
mr_nd is offline Find More Posts by mr_nd
Old May 13, 2012, 01:07 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Originally Posted by DJO View Post
Help guys! My mCPX won't take off of the ground any more. Even at full throttle, it refuses to get off the ground. What's happening??
EDIT: Never mind, I Googled it and found out that the main gear had slipped down on the shaft, it's all fixed now. I was wondering why it didn't have as much power as before.. well that was it!
Dan
Glad u figured it out. Happened to me before and I stripped the gear.
Diesel6401 is offline Find More Posts by Diesel6401
Old May 13, 2012, 01:08 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
"Yo, that's a thermal"
DJO's Avatar
Joined Oct 2011
Do you know anything about my problem with inverted flight, how it goes one way all the time?
DJO is offline Find More Posts by DJO
Old May 13, 2012, 01:11 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
No clue on that one buddy, sorry.
Old May 13, 2012, 01:14 PM
DJO is offline
DJO
DJO
DJO's Avatar
Joined Oct 2011
Oh well, I tried. The mCPX can handle my crashes as I'm learning
It's probably me and my dumb thumbs hitting the stick one way because I'm not used to flying with negative pitch...
Old May 13, 2012, 01:19 PM
mr_nd is offline
mr_nd's Avatar
Russia, Moscow
Joined May 2008
mcp x have weak tail in stock, so you need to work with pitch carefully, trying not to overload main rotor with rapid stick movement. Its easy to figure out how much and how fast you need to add pitch for your maneuver. Just keep trying and you`ll learn it.
Knowing how to manage pitch - key skill for 3d heli flying, especially if you plan to fly larger helis.
Old May 13, 2012, 01:23 PM
random13 is offline
Find More Posts by random13
Joined Jul 2011
First time inverted
I had been able to do flips before -- practicing pulling back on the collective when inverted -- but I could never stop inverted. The rotor would start to bog out and down it would come. I don't have a simulator, so I'm just winging it here... so to speak.
I realized today that I was giving too much negative collective. That, and I needed more initial height to give myself time to figure things out.
It was pretty windy, and that wasn't helping, but a few times I was able to hold the inverted hover! Once for about 30 seconds before flipping back upright and under control!
A few times while I was holding the hover, the wind pushed it farther and farther away. I had to hit the TH and ditch. Luckily the grass was long, so no harm.
Pretty exciting though... My mCPX is totally stock -- except for how beat up it is after more than a few crashes -- and I think the batteries are starting to fade, but it still flies really nice.
random13 is offline Find More Posts by random13
Old May 13, 2012, 04:47 PM
DJO is offline
DJO
DJO
DJO's Avatar
Joined Oct 2011
Guys, is it possible to auto-rotate the mCPX? Once you hit throttle cut the tail spins dramatically, but there's still control of the pitch of the blades, so...? Has anyone successfully done this?
Dan
Old May 13, 2012, 07:02 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
Yeah, you can auto rotate it with a one way bearing upgrade. However, the tail will slowly piro as the heli loses airspeed, since it is not driven.
phoenixheli is offline Find More Posts by phoenixheli
Old May 13, 2012, 07:07 PM
DJO is offline
DJO
DJO
DJO's Avatar
Joined Oct 2011
I don't get it. What does having a different gear and an added bearing do?
http://www.anythingheli.com/xtreme-a...ng-blade-mcpx/
Dan
EDIT: Oh, I get it now! The one way bearing keeps the blades spinning instead of having them stop so quickly to help with the auto-rotation!
Old May 13, 2012, 07:12 PM
segroegt is offline
Find More Posts by segroegt
Canada, QC, Montreal
Joined Jan 2009
Dan
Well with no tail authority you cannot do much . Best Regards.
segroegt is offline Find More Posts by segroegt
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Dan
The bearing is a one-way bearing so it freewheels in one direction and locks up in the other so the motor can drive the rotor. When the motor stops the one-way bearing lets the rotor and shaft assembly freewheel. Otherwise the motors cogging would stop the rotor rather quickly no matter what the descent speed is or the angle of the blades.
Don
dbennettya is offline Find More Posts by dbennettya
Old May 13, 2012, 07:15 PM
DJO is offline
DJO
DJO
DJO's Avatar
Joined Oct 2011
Thanks everybody for the clarification! Here's a video of my mCPX from this evening. I couldn't do much fast forward flight because I was flying it inside the fence this time and it was getting dark.
Blade mCPX V2 Loud Evening Flight (2 min 25 sec)
Dan
Old May 14, 2012, 05:30 AM
rynldgalano is offline
Find More Posts by rynldgalano
REYNALDO
rynldgalano's Avatar
Cyprus, Nicosia
Joined Dec 2011
mcpx xtra features
heres now my mcpx since been not on the air in a couple of weeks, i replace again a longer tail boom. cutted landing skid to reduce the weigth and i replaced also the batterry circuit wire into a bigger and longer size to avoid broken wire in swaping battery at the park.
rynldgalano is offline Find More Posts by rynldgalano
Old May 14, 2012, 07:58 AM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
How much longer did you make the tail boom rynldgalano?
barnstorm100 is offline Find More Posts by barnstorm100
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Jun 29, 2016 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
