Old Apr 23, 2012, 06:57 PM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
Originally Posted by turboparker View Post
I wouldn't bother with trying to find a more efficient, more powerful brushed main motor. Brushless is far more efficient. I used Dylan's nearly plug & play kit with linear throttle, 125mm boom, and 4G3 tail motor. Installation was simple, the CG is still right where it should be, AUW with a Hyp 250 is the same as stock, and everything worked perfectly right from the start.
Joel
+1 for that setup works great!
achogg33 is offline Find More Posts by achogg33
Old Apr 23, 2012, 07:02 PM
achogg33 is offline
Joined Oct 2011
Originally Posted by mattijs321 View Post
Want to go brushless and i have a 4g3 brushless 11k Kv motor and 4g3 brushless esc.
Can i just use those alongside a Steve converter pwm to ppm?
Any reasons it wouldn't work or specifics on the converter itself i should be aware of?
Hi yes you can use those two items to covert your mcpx to brushless, what version esc do you have wk wst 10l or lt. Also what version mcpx, reason I ask is the difference in where to solder the white signal wire too, also you do not need a Steve converter.
You will probably have to upgrade your tail motor as well using that motor or use a very low pitch setting. Send me a pm if you need any help.
Old Apr 23, 2012, 07:24 PM
HeliStyle is offline
Find More Posts by HeliStyle
hmmm...
Joined Sep 2008
hey guys stated in a previous thread I stated that I did indeed go brushless using the AEO RC M5 Brushless Upgrade with 9T.
I love the setup tons of power with the hyperion 250mah batteries but I still find them losing 3d performance after about 1-1.5 minutes.
do you guys recommend using the hyperion 550mah batteries, and if so can I expect better and more level performance performing 3d ?
HeliStyle is offline Find More Posts by HeliStyle
Old Apr 23, 2012, 09:11 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
Yes! I just upgraded my motor and batteries and it is awesome now. I made a small adapter cable so I can switch between the regualr mcpx 250mah batts and the hyperion 550's ( left the connectors that come with the batteries on them). I just got back from flying all 3 packs for the first time I could really put them to the test. You can do tictocs with the 550's and the hp05 motor. theres a bunch of videos onyoutube of people running those batts as well. You can also get up to 8 minutes flight time out of them but I still quit after around 4 minutes.
sideburn is offline Find More Posts by sideburn
Old Apr 23, 2012, 10:33 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Originally Posted by cloudflying View Post
Diesel, welcome to your new addiction this heli is a blast. What causes the tail blow out (usually) is there just not being enough motor for the pitch that the heli is capable of. Try turning your positive pitch down to 70 and your negative to around the same. Once you do this, start to hover then punch full collective pitch (up) and if the heli turns (like if you were using rudder), your pitch can go down another point or two. Just my .02
Originally Posted by rynldgalano View Post
DIESEL i did the tailboom extended with a V2 tail blade, 3/4 inch is the best option to extend the boom, and if you always fly outdoor i bet 85% on your pitch is better. best regards mate.
I am always outdoor but my collective management is poor so anything over 70 makes my tail piro out of control I have been seeing vast improvements over the past few weeks thought. Nothing like seeing 5 grown men stand on a flight line grinning ear to ear chasing each other around with these helis.
Thanks everyone for the help and yes this is another rc addiction without a doubt. Been having fun with the helis and mqx, its just so out of my norm of boats, planes and cars its a nice switch up.
I have this same question posted in the other mcpx thread and the 70% pitch seems common. I will try that.
Here are my settings.
Norm: 30%, 40%, 50%, 75% 100%
ST 1: 0%, 25%, 50%, 75% 100%
ST 2: 0%, 25%, 50%, 75% 100%
* so on the last two settings the 75% and 100% I should set those both at 70% for all three modes?
Not sure if I should continue to post the same questions in both threads or dedicate to one.. I don't want to annoy anyone. You heli guys are very welcoming!
Diesel6401 is offline Find More Posts by Diesel6401
Old Apr 23, 2012, 10:36 PM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
might help to just post in one I read both,
stevebarrow is offline Find More Posts by stevebarrow
Old Apr 23, 2012, 10:43 PM
anthony7820 is offline
Find More Posts by anthony7820
Team CJ Youngblood
anthony7820's Avatar
United States, WV, Wheeling
Joined Jul 2009
I set my pitch with the Travel Adjustment setting. Not the Pitch Curve, I don't know what the difference is but I think that's what the manual said to do
anthony7820 is offline Find More Posts by anthony7820
Old Apr 23, 2012, 11:06 PM
Heli Mad
Joined Feb 2002
Travel adjust sets the end point range of the pitch, the pitch curve sets the amount of pitch for each stick position within the available range as you move the throttle up and down.
Old Apr 23, 2012, 11:36 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Diesel, do as they said. You want to keep your pitch curve by the manual which is how that looks. Go into the "Travel adjustment" menu and move the throttle to the up position, then select it with the wheel and set to around 70. Then move it to the down position, and select with the wheel and set that to around 70. Give it a try and see if the tail still wants to blow out when you jam full collective regular/inverted.
3d astronaut is offline Find More Posts by 3d astronaut
Old Apr 24, 2012, 09:32 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Hey thanks a lot. Ill do that today and give it a try. Hopefully weather cooperates with me today, been very windy lately. If not ill have to take out the fixed wing birds.
Old Apr 24, 2012, 11:17 AM
terencechan is offline
Find More Posts by terencechan
Rotary~myPast,Present &Future!
SINGAPORE
Joined May 2006
I can't do 3D on my MCPx anymore
But I found a new joy ... flying FPV with it.
Here's a video of messing around in the living room with all the FPV gear mounted onboard my MCPx (I wasn't flying it thru the camera's view wish I'm good enough to do that though)
BL MCPX FPV Video (4 min 27 sec)
This is my first recorded video of real FPV-flying the same bird, I was piloting it thru the 'eyes' (the onboard camera) from takeoff to landing. It was a very rough landing, I simply cut throttle when the grass appeared close enough. I have set the throttle-hold pitch curve to flat-65% so that the MCPx would kinda 'auto' down gracefully from half a meter above ground.
One of my flying mates who happened to be at that field, witnessed my FPV flight. He told me my MCPx was zooming from one end to the other end at an insane speed! With FPV, the higher you are from the ground, the harder it is to tell how fast you are going.
McpX - FPV Outdoor Flight (2 min 50 sec)
terencechan is offline Find More Posts by terencechan
Old Apr 24, 2012, 11:44 AM
Joined Sep 2011
terencechan, VERY NICE! That is too cool man. Mind if I share this video with some club friends?
Old Apr 24, 2012, 12:20 PM
SINGAPORE
Joined May 2006
Sure, happy to share this joy with your friends.
Old Apr 24, 2012, 12:57 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Originally Posted by dbennettya View Post
Both of my C05m motors would not start with my older Walkera 10A ESCs that run my HP08 motors just fine.
YMMV, Don
Thanks. I bought a whole bunch of upgrades and that's the one thing I didn't buy! This is by far my most expensive heli
tonyastro is offline Find More Posts by tonyastro
Old Apr 24, 2012, 02:09 PM
Joined Sep 2011
Haha this thing BNF cost me more than my hk450! Still, fun as can be though
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15676 Aug 31, 2015 12:28 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 27, 2011 12:34 AM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 08:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 09:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 03:28 PM
