Old Mar 30, 2012, 08:03 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Originally Posted by PLMS View Post
Thanks for the reply.
I don't have a spare as2000l servo that I know of. I googled the as2000l and it came out looking like the servo already in the mCPX. Is that what you meant ?
I do have a big bag of dead normal micro servos at home, maybe a gear from one of them will fit.
Martin
Yes but I meant to say just the gear. I didnt replace the entire servo, just that plastic gear that I took off of the as2000L. Popped right on and has worked perfectly for 20+ flights so far without any modification.
3d astronaut is offline Find More Posts by 3d astronaut
Old Mar 30, 2012, 08:43 PM
cjg is offline
cjg
Find More Posts by cjg
cjg
"Pull up, pull up!"
cjg's Avatar
Vermillion, SD
Joined Jan 2006
Originally Posted by payne9999 View Post
I can remember when I first got my MSR I thought I wouldn't be able to fly it. Now I have an MCPX. I searched quite a bit and this thread has over 600 pages. I am having trouble finding some basic help.
I have 30 years of RC experience and a year on the mSR and a small amount of time on an SR. To me the SR is irrelevant though because it is a pile of .
So, I started out this afternoon and was able to establish a short hover. Tonight I am having trouble even lifting off. It wants to tip over to the left or right or seems to get stuck wanting to pitch forward or aft as if the trim is confused. The manual says to keep the stick neutral while lifting off but mine seems to need a lot of input while it is getting light.
I tried lifting off the hardwood floor so there is no resistance. I tried to really sneak up on the collective to get it light real slow so I can see if it is trimmed neutral but it is inconstant in which way it wants to drift. The drift isn't small either so it seems to be asking for a lot of correction and then I immediately get into over responding since I am new to CP.
Any ideas?
In the moments immediately following bettery connection be sure you quickly set the mcpx down on a level surface and dont move until the led on the 3 in 1 lights. During this time the gyros are orienting to level. If it is moved during startup it often confuses the gyro causing it to have the trim off when taking off.
cjg is offline Find More Posts by cjg
Old Mar 30, 2012, 08:51 PM
Brockshadow is offline
Find More Posts by Brockshadow
United States, NJ, West Long Branch
Joined Mar 2012
new guy checking in....
Just checking in... just joined.. been flying since fall.. a friend gave me a cheap co-ax heli and I had a blase.. got a Blade Scout and still have fun.. got a Phoenix Sim... then picked up a used McpX (v1) and have been taking it slow. Waiting on warmer (less windy) weather.
Brock
Brockshadow is offline Find More Posts by Brockshadow
Old Mar 30, 2012, 09:28 PM
nuttcaze is offline
Find More Posts by nuttcaze
nuttcaze's Avatar
Johnson City, New York
Joined Mar 2008
anyone got a BNF mCPX in good shape they wanna trade - http://www.rcgroups.com/forums/showthread.php?t=1624228
nuttcaze is offline Find More Posts by nuttcaze
Old Mar 30, 2012, 09:37 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
OK, so flying the Msr for almost a year I should have remembered about letting the gyros calibrate on power up. Thanks for the reminder. That is what was causing some flights to be much easier than others and inconsistency in stability. Wow, I can't believe I forgot about that.
Also, I went outside and it was calm enough and it makes such a difference to have some room. Ok, so it did achieve a fairly sane hover!
Dave
payne9999 is offline Find More Posts by payne9999
Old Mar 30, 2012, 09:39 PM
Joined Sep 2011
Dave
This heli will fly in winds over 10mph. Dont be afraid to take it out even if its a bit windy
Old Mar 30, 2012, 10:06 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Yep, it was breezy but I have really noticed watching CP pilots that wind is not much of an issue and even though I am struggling the wind didn't seem to be a factor.
The big issue is hard surfaces. I want to get out to a grassy area for sure. I put a little crack in the tail boom because I came down a little hard on the cement.
Is there a better tail boom material for this heli? It is hollow and maybe for balancing it needs to be hollow but it is quite fragile and vulnerable to beginner mistakes.
Dave
Old Mar 30, 2012, 10:11 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Solid 2mm carbon rod works fine. Much more durable.
You have to sand in a flat spot at each end for alignment and run the tail motor wires on the outside. Either wrap them around of use a few small pieces of heat shrink to hold them in place.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
bob s is offline
Find More Posts by bob s
kentucky
Joined Feb 2004
you can use 2mm solid carbon fibre rod and its a good idea to make it a little longer than stock
bob s is offline Find More Posts by bob s
Old Mar 31, 2012, 09:42 AM
winginman is offline
Find More Posts by winginman
United States, KY, Louisville
Joined Aug 2010
What are the first things to start to wear out in the MCP X? Mine seems to getting a bit more jerky when flying and there seems to be a bit of slop in the blade holders like feathering shaft is not quite tight enough. What do I need look at?
winginman is offline Find More Posts by winginman
Old Mar 31, 2012, 09:47 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
The dampers for sure wear out, make sure your feathering shaft screws are still tight.
livonia bob is offline Find More Posts by livonia bob
Old Mar 31, 2012, 11:02 AM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
My mcpx has started flying irratically. It will change direction while in a steady hover without input. I must continually correct to.I believe it is a bad ele. servo. What are your thoughts?
J_skaggs is offline Find More Posts by J_skaggs
Old Mar 31, 2012, 01:34 PM
philthyy is online now
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
What are the causes of the high speed death wobble? How to cure it?
philthyy is online now Find More Posts by philthyy
Old Mar 31, 2012, 02:27 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
Originally Posted by J_skaggs View Post
My mcpx has started flying irratically. It will move forward and backward with some tail shake when forward elevator is applied while in a steady hover. I must continually correct. I believe it is a bad ele. servo. What are your thoughts?
I can answer my own question. I was pretty sure of my diagnosis so I went to the LHS and purchased an elevator servo. Results, problem fixed.
Old Mar 31, 2012, 02:31 PM
pmackenzie's Avatar
Joined Dec 2002
Cracked main shaft can do this.
Mine cracked on one side right where the screw goes through for the shaft collar.
Also make sure the main gear has not slipped down.
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Jun 29, 2016 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
