Nevermind...i Just wanted to dup your post
The OC, California
Joined Feb 2007
If you are using all of the stock settings then 3/4 stick hover is normal. If you are at 3/4 stick and it does not hover you might want to check your blade pitch at mid-stick to make sure you have zero degrees. |
I was toying with using a pair of Boca's 1.5 x 4 x 1.2 mm ceramic hybrids for outers, since they're the same dimension as the 250 tail bearings that some are using - but I figured they'd be even more overkill than I typically go for:
http://www.bocabearings.com/bearing-...R681XC-15x4x12 Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Prescott, AZ
Joined Jan 2011
Yeah I know Indoor.....i would just like to see this little micro gem make it though without a crap load of Mario spam like every other micro that was released in the past. He Thrives on noobs and new members thinking that his nonsense will actually help something fly or perform better.
Has anyone busted the canopy posts of their frame yet?
I have one post left so my canopy is barely hanging on..and thinking about a solution to hold the canopy on without having to replace the frame. kindof dreading that.. its not as quick of a replace job as the msr is. starting to think i need a whole other heli for playing nice with and keep this one as my thrasher. its beaten to a pulp now. Busted up frame, busted tail boom wrapped in thread and CA all over it. busted skids, canopy busted all to hell (the green ones are thinner plastic by the way). cracked blades.. still flys great! loving this thing. I'm so glad i waited 4 years and didnt practice 3d on my belt cp now
Joined Mar 2011
it is copper towards the blade , as i understand it , cheers ![]() Edit: i added the part about the inboard bearing not an issue , as it does not see a thrust load
http://www.rcgroups.com/forums/showp...postcount=7968 |
| Thread Tools | |
| Discussion Blade mCP X BNF Heli... | ChuckTseeker | Micro Helis | 15109 | Yesterday 07:58 PM |
| Discussion Blade mCP X Discuss anything thread | A Rdnek | Micro Helis | 457 | Jul 26, 2011 11:34 PM |
| Discussion The New BLADE mCP X Has Arrived... | ChuckTseeker | Electric Heli Talk | 38 | Mar 27, 2011 07:35 PM |
| Discussion new blade mcp X anyone know anything new. | epoweredrc | Atlanta Area RC | 6 | Mar 16, 2011 08:14 PM |
| Discussion Blade mCP x - strictly on topic Q and A thread | jdog83 | Micro Helis | 58 | Feb 07, 2011 02:28 PM |
