Old Jan 30, 2012, 04:31 PM
mikeflys is offline
Find More Posts by mikeflys
Meridian, Idaho USA
Joined Feb 2004
Blade slop
Hi all
2nd full day of flying, doing good but an issue has come up. After an unfortunate contact with the Earth I no longer have enough thrust to rise more than 3 or 4 inches? Looking at the Heli I noticed that the main shaft has about vertical slop. At rest the white drive gear barely makes contact with the motor drive gear. As the motor ramps up it rises up to the top. On top of the chassis is a locking collar, I think this might have slipped. My instinct is to move the shaft to it upper most and bring the collar down. How much if any slop should be present?
mikeflys is offline Find More Posts by mikeflys
Old Jan 30, 2012, 04:35 PM
andione1983 is offline
Find More Posts by andione1983
andione1983's Avatar
Australia, VIC, Melbourne
Joined Nov 2011
Originally Posted by mikeflys View Post
Hi all
your main gear has been pushed down, gently push the gear back up on the main shaft.. and you should be set to go again..
andione1983 is offline Find More Posts by andione1983
Old Jan 30, 2012, 05:00 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
I use a colored drinking straw cut to lenght and slit down the side. I looks cool covers the wires and looks nicer. It also weights very little. I especially like floresent pink and green
Don
dbennettya is offline Find More Posts by dbennettya
Old Jan 30, 2012, 05:02 PM
SquidgyB is offline
Find More Posts by SquidgyB
SquidgyB's Avatar
United Kingdom, Newbury
Joined Jun 2011
Hi all
Yeah, the collar won't slip, it's screwed through - the main gear slips off in a crash, mitigating some damage. slip it back on and you'll be rosy.
SquidgyB is offline Find More Posts by SquidgyB
Old Jan 30, 2012, 05:59 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Hi all
Push the gear back on, apply force at the hub, not the rim. Snap...
hydro_pyro is offline Find More Posts by hydro_pyro
Old Jan 31, 2012, 07:18 AM
ronhawker is offline
Find More Posts by ronhawker
USA, AZ, Surprise
Joined Dec 2010
Tail vibration and instability turned out to be bent feathering spindle. Easy fix.
ronhawker is offline Find More Posts by ronhawker
Old Jan 31, 2012, 10:23 AM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
When I bent my feathering shaft I called the LHS and asked if they have them and how much. He told me 5.95 and I asked if that was for a ten pack.
Anyway, I was wondering why I can't flip this heli now. When I first got it I went to the field and flip it immediately and was hovering inverted. Now I try and the tail blows out. I have the V2. I found a Walkera feathering shaft from a Ufly that's the right diameter but its about 55mm longer. I'm not sure how much to cut off.
I went to a field with tall weeds but when I crashed, it broke one of the balls off the swash. I ordered a micro heli swash so we'll see what breaks next on this ultra durable heli.
barnstorm100 is offline Find More Posts by barnstorm100
Old Jan 31, 2012, 10:25 AM
Dilatory is offline
Find More Posts by Dilatory
United Kingdom, Wales, Isle of Anglesey
Joined Jan 2012
If your tail keeps blowing out suddenly are you sure you haven't cracked the tail boom? Does it twist real easy?
I'm going to go ahead and ask a stupid question, but when my batteries from HobbyKing finally arrive (if ever) I'm going to tire of charging batteries one by one on stock charger.
What chargers are people using for multiple batteries?
Dilatory is offline Find More Posts by Dilatory
Old Jan 31, 2012, 10:29 AM
Joined Jan 2011
I think your batteries from Hobby King comes with a muti plug adapter. I ordered 4 from Hobby King and there waiting for p/u at post office. I wonder if they're going to be any good at $2.96. The LHS wants $15.0 for the stock one but I know good after market ones you can get for $10.
Old Jan 31, 2012, 10:34 AM
Dilatory is offline
Joined Jan 2012
They're the 300mah 1S 35c ones, supposed to be decent from what I've heard. Better than stock so I'm told anyway.
Will wait and see!
Old Jan 31, 2012, 10:36 AM
Joined Jan 2011
[QUOTE=Dilatory;20594464]If your tail keeps blowing out suddenly are you sure you haven't cracked the tail boom? Does it twist real easy?
The tail wasn't cracked but it is now after removing it to install new longer one. The new one is solid so the frame will probably break next crash. What? they make an after market frame?
It could be that I just had too much coffee when I tried to flip it.
Old Jan 31, 2012, 10:41 AM
Joined Jan 2011
Will wait and see!
The 300mah 1S 35c numbers mean nothing except what they decided to print on them. You don't get what you pay for. Sometimes you get a lot less
Old Jan 31, 2012, 10:44 AM
Dilatory is offline
Joined Jan 2012
Well regardless of the discrepancies between packaging and product, I've heard good things about the batteries which is of course all one has to go on when ordering things from the internet. I'll reserve final judgement until they arrive.
Good luck with your tail!
Old Jan 31, 2012, 11:25 AM
Joined Jan 2011
Sorry for having such a negative attitude. I'll post if there is a muti plug adapter with the batteries.
Old Jan 31, 2012, 12:07 PM
BenScoobert is offline
Find More Posts by BenScoobert
United Kingdom, England, Halifax
Joined Oct 2011
hobby king x6 charger harness
add to cart, then add the 300mah turnigys for $2.96 from the above link
or a quality charger board here
astroid site or thread
BenScoobert is offline Find More Posts by BenScoobert
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Jun 29, 2016 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
