Old Jan 06, 2012, 12:07 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Originally Posted by turboparker View Post
Turnerm,
<snip>
HF,
Usually, I am reasonably good with details. However, I did not measure the current because I don't have a convenient way of doing that on these UM aircraft. I wonder if Dylan has measured the current. Maybe someone on his thread has done so: http://www.rcgroups.com/forums/showthread.php?t=1405120
Joel
Joel
Thanks, I PM'd him shortly after posting my question to you earlier. I will post here whatever I hear back from him, if he has some data.
habitforming is offline Find More Posts by habitforming
Old Jan 06, 2012, 12:28 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Well crap. I noticed today that my tail boom seemed crooked and I tried to straighten in but I couldn't get it resolved. So I started looking closer and sure enough - right near where it goes into the frame it's cracked.
This was the very reason I sold my first mCPx. I can NOT seem to quit breaking these dang things! I'll order a replacement.
BUT... I seemed to make some decent progress in my flying today. I flew in idle up with a milder pitch curve and it seemed to help. I only got out of control once and it's because I lost orientation.
Being as I fly a lot of fixed wing 3D, I usually use my rudder to turn A LOT!! So it's hard for me to get used to do everything with the right stick and only using the left stick to get the tail behind me.
That and I keep trying to slow down by moving the left stick down. Again... I have to remember that the right stick does all of this now!!
turnerm is offline Find More Posts by turnerm
Old Jan 06, 2012, 12:36 PM
kokopelli is offline
Find More Posts by kokopelli
Joined Oct 2011
I've found the solid tail booms to be pretty durable.
kokopelli is offline Find More Posts by kokopelli
Reply With Quote  (Disabled)
Old Jan 06, 2012, 12:37 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Which ones in particular? If I'm going to buy a replacement maybe I should get one of the ones you're using.
Old Jan 06, 2012, 12:40 PM
Joined Oct 2011
I use the solid 140mm (stock length is 125mm) booms from Dylan (Asteroid Designs). I haven't broken one yet. I also use his delrin single tail motor mount. I just wrap the wires neatly along the outside of the boom. They're more than long enough. Just be careful when cutting/cracking the motor and wires out of the original broken stock boom. It's pretty easy to do, but those wires are mighty thin.
Old Jan 06, 2012, 01:41 PM
StangGuy is offline
Find More Posts by StangGuy
StangGuy's Avatar
Joined Mar 2007
I don't mean to take business away from Dylwad since he is such a great supporter of us mcpx fliers, but you can also make your own booms from 2mm solid carbon rod. I cut mine to length with a dremel and then grind down a flat spot with the flat side of the cut-off wheel. It's very easy to do and takes only a few minutes to make including setup time. You can probably get 2mm carbon rod for pretty cheap from your LHS and make yourself a bunch like I did. Booms seem to be the weak spot for my heli now, so this was a great help for me.
StangGuy is offline Find More Posts by StangGuy
Old Jan 06, 2012, 01:55 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
That's a good idea. I think I actually even have some carbon fiber rod laying around. Not sure if it's 2mm or not but if it's not, that's pretty cheap stuff to get. I also got a dremel for Christmas so it sounds like I have what I need!
But explain to me again exactly how you used the dremel to flatten out the end that goes into the frame??
Old Jan 06, 2012, 02:17 PM
joliecoeur13 is online now
Find More Posts by joliecoeur13
joliecoeur13's Avatar
Canada, BC, Fernie
Joined Dec 2009
does anyone actually like these KBDD main blades ?
The tail blades are by FAR better but I find the main KBDD have more drag and don't really perform that well ... that's just my findings
joliecoeur13 is online now Find More Posts by joliecoeur13
Old Jan 06, 2012, 02:18 PM
Joined Oct 2011
Then don't... He IS a great asset here. And, I was specifically asked WHICH booms I used. I'm sure most people already know you can buy carbon rod stock and cut/grind their own. It's just whether they want to do it or not. Capisce?
Old Jan 06, 2012, 02:19 PM
Joined Oct 2011
You might be better off using a small file and doing it by hand. It only takes a minute or two, anyway. Dremels remove stuff quickly, if you're not careful!
Old Jan 06, 2012, 02:31 PM
punisher96 is offline
Find More Posts by punisher96
Joined Dec 2011
I have noticed that my mCP X has slight movement between blade grips. Is this normal or should I tighten it?
punisher96 is offline Find More Posts by punisher96
Old Jan 06, 2012, 02:34 PM
Joined Oct 2011
Are you talking about being able to push/pull on the blade grips and them having a little linear play along the feathering spindle axis? While I can't say your feathering spindle screw doesn't need tightening, some play in the grips is normal. The play is there immediately after I reassemble the head and locktite/snug up the feathering spindle screw.
Old Jan 06, 2012, 02:38 PM
Joined Dec 2011
Yes thats what I meant.
Old Jan 06, 2012, 02:54 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
just curious about your experience with the tail blades - is it FAR better in relation to the original tail blade, or the V2 (shiny) tail blade?
Old Jan 06, 2012, 03:00 PM
Joined Oct 2011
I found it performs pretty much the same as the V2 blade. Both are a lot better than the old mSR style V1 blade. I just like the KBDDs because the neon yellow really stands out in flight.
And, for the other question about the KBDD mains, I like them well enough, but would be happy flying the KBDDs or the stock non-bullet blades since they're so similar. I never bothered to put the stock blades back on and, as above, the yellow rotor disk is very visible on this tiny heli that gets away quickly!
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Jun 29, 2016 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
