Hi all,
I just finished installing my almost plug & play b/l kit with linear throttle from Dylan. CO5M motor, 8T, 140mm boom, lower frame brace w/boom supports, and the 43G tail motor w/KBDD rotor. I only had to solder the signal wire to the small resistor. The kit went in without a hitch. Of course, Dylan's workmanship is excellent. The weights are with the bullet blades & Dylan's lower frame brace.Empty weight: 40.0g AUW w/Hyp 240: 46.7g AUW w/TP 240: 46.54g I test-flew it in the living room, and everything was perfect. I only had to make a couple of small tweaks to my normal mode throttle curve. Throttle-response in normal mode is buttery-smooth. I just had to do some hard pitch-pumps to see how the tail behaves. It's absolutely rock-solid! ![]() Looking forward to getting in some flights at our indoor session on Sat night. ![]() Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Japan, Nagasaki Prefecture, Sasebo
Joined Mar 2007
Arthur |
If you change travel adjust to 75% on "+" and "-" as recommended in the manual, you will get now get 50% to 87.5% pitch range from mid-stick to full-up. If you leave it at 100% you will get 50% to 100%. More pitch travel per unit of stick movement will make it more "jumpy" for a more novice pilot not used to making small pitch adjustments during flight. I've seen it myself on my own heli, so I know it's true. |
Effectively the 65% setting becomes the new 100% as the travel adjust limits or resets your servos end point back from true 100% full travel. This is why it is also called EPA or endpoint adjustment as it permanently changes what your tx see at the servo's 100% movement. Travel has nothing to do with a pitch curve other than limiting your maximum positive or negative pitch on a one servo swash setup. Your pitch curve is what determines your stick input pitch from midstick to top stick. Though if you limit your servos through travel adjust to 85% then a 100% on your pitch curve will max out at 85% of the servos travel as the tx see's the 85% travel adjustment as now the servo's full movement (100%) As far as not making the servo move at all you have a 100% range for each side of the servo so 0% of each side of the servo travel would equal no movement. Also 125% travel does increase servo travel past 100% on normal servos so it gives more collective range by extending throw. Though do not do it with linear servos as it will ruin them with continued use like that. Quote:
Sorry - I wasn't clear. I meant that I changed my Pitch Travel Adjust for both directions.
I did, however setup my radio to use a lowest negative pitch of 42 and a highest positive pitch of 85 to see how I like it. I'll run out at lunch and give it a shot. I got my 34" EPP Edge stuck on the roof of my house last night and spent the evening trying to get it down. I was unsuccessful unfortunately. But I ran out of daylight so I couldn't try my new mCPx settings. I'll do that today while I'm waiting on the wind to blow my dang plane back down to terra firma! |
USA, WA, Bremerton
Joined Feb 2007
Indoor, maybe you can clarify this Travel Adjust related to Pitch range or servo movement with respect to another Heli I fly. That is a 450 Pro with CCPM and a normal FB head.
On my 450, I have the Travel Adjust values on all servos at 100% in both directions other than Rudder. I have thought that using the SWASH (CCPM mode) with something like 60-70 range for Pitch is what controls the maximum Pitch I can setup for flying. Should I be also using Travel Adjustment on the Pitch, Elev and Aile servos? BC |
![]() Though in the future you might find it easier to only limit your servos as much as you have to during proper mechanical setup. This way you dont have to reconfigure your endpoints when you want to use advanced curves or different curves with maximum possible servo movements If you figure out what maximum travel your heli can take at the beginning when you first get your heli, you can leave those endpoints set for the life of your heli. Then you only need change your curve to make a more mellow or more advanced flyer. |
Cyclic/collective pitch mixing (ccpm) is different on your 450 since you have access to the ccpm menu by using the 120 degree/3 servo setting and not one servo setting. On the mcpx you have no access to ccpm mixing so you have to limit the pitch through the travel adjust. On my larger helis i like to max out all servos and adjust through the ccpm menu for collective and cyclic pitch |
Cool - we meet again! ![]() Yeah, I decided to get into helis about three years ago. Started out with the mSR right when they came out, and then picked up a BSR on which to learn CP. After a year of learning new swear-words & never progressing beyond the hover & slow-flight stage with that evil-handling bird, I pre-ordered the mCP X. Within a half-hour, I was doing FFF circuits, figure-eights, and was taking off, hovering, and landing nose-in. Within the first two hours, I had done my first roll, flip, and loop! Best money I've spent on the heli side of the hobby!I'm primarily scale & sport heli pilot who enjoys a few aerobatic maneuvers now & then. I wanted to go brushless & upgrade the tail - primarily for the consistency of brushless and to improve rudder authority. So far, I'm loving it! ![]() Good luck with learning CP - I found it to be a rewarding experience. I think the most difficult part for me was (and still is) to get the tail to come around in a scale manner during turns. HF, Usually, I am reasonably good with details. However, I did not measure the current because I don't have a convenient way of doing that on these UM aircraft. I wonder if Dylan has measured the current. Maybe someone on his thread has done so: http://www.rcgroups.com/forums/showthread.php?t=1405120 Joel |
| Thread Tools | |
| Discussion Blade mCP X BNF Heli... | ChuckTseeker | Micro Helis | 15109 | May 17, 2013 07:58 PM |
| Discussion Blade mCP X Discuss anything thread | A Rdnek | Micro Helis | 457 | Jul 26, 2011 11:34 PM |
| Discussion The New BLADE mCP X Has Arrived... | ChuckTseeker | Electric Heli Talk | 38 | Mar 27, 2011 07:35 PM |
| Discussion new blade mcp X anyone know anything new. | epoweredrc | Atlanta Area RC | 6 | Mar 16, 2011 08:14 PM |
| Discussion Blade mCP x - strictly on topic Q and A thread | jdog83 | Micro Helis | 58 | Feb 07, 2011 02:28 PM |
