Old Jan 04, 2012, 07:53 PM
joliecoeur13 is offline
Find More Posts by joliecoeur13
joliecoeur13's Avatar
Canada, BC, Fernie
Joined Dec 2009
DID YOU READ THE MANUAL ??????????????????????????????
There are some specific things you have to do to bind to the DX4 ....
putting the blades on correctly WILL help too LOL
joliecoeur13 is offline Find More Posts by joliecoeur13
Old Jan 04, 2012, 07:57 PM
kokopelli is offline
Find More Posts by kokopelli
Joined Oct 2011
Actually, after looking at those photos again, it looks like he took the picture in a mirror or somehow reversed the image.
Either way, it looks like WAY too much negative pitch...
kokopelli is offline Find More Posts by kokopelli
Reply With Quote  (Disabled)
Old Jan 04, 2012, 07:59 PM
JMull is offline
Find More Posts by JMull
Joined Jan 2012
first of all i did read the manual...it was already bound to it when i got it...second of all there is only one way to place the blades unless i flip them upside down...and third of all its the swashplate that controls the direction the blades are pointing (tilting left or right) not the way the blades are put on.
So i would love if a sophisticated...professional could help me out...not some scrub who finds sarcasm directed at a new member funny
EDIT: koko (this wasnt directed toward you BTW)
and how do i add more positive pitch to it on a DX4e? I took this with my laptop iSight camera.
JMull is offline Find More Posts by JMull
Old Jan 04, 2012, 08:10 PM
Joined Oct 2011
Well, without being able to adjust the pitch curve on that radio...
You need to make a mechanical change. You need to raise the swashplate to add positive pitch. You do this by popping off all three swashplate links and turning them OUT (counter clockwise, looking down) by the same amount of full turns for each one. This will effectively lengthen the pushrods from the servos to the swashplate and push the swashplate (and leading edges of the blades) up.
Also, make absolutely sure your white main gear is pressed fully up against the bottom of the frame.
And, just to be sure you have the blades on correctly... With the blades at the 3 and 9 o'clock positions, when looking down on the heli (tail towards you), you want the "bullet/protrusion" on the left blade pointing forward and the one on the right blade pointing aft (towards you).
Old Jan 04, 2012, 08:11 PM
CorgiCowPockets - xxDExx is offline
Find More Posts by CorgiCowPockets - xxDExx
Joined Jan 2012
Thinkin about the v2 purchase, any advice guys?
CorgiCowPockets - xxDExx is offline Find More Posts by CorgiCowPockets - xxDExx
Stugoose is offline
Find More Posts by Stugoose
Stugoose's Avatar
United States, NY, New York
Joined Jul 2011
I can give a stab at helping you, looks like you need to level out the arms, turn on throttle hold and put throttle stick mid stick, the blades should appear level if done right, u can raise and lower the servo pushrods by turning them,
Sometimes they can get bent and stuff so give that a try, tbh i have never flown one on a dx4, i think i tried to bind one of mine once to see how bad it was
Hope this helps
THE STU
Stugoose is offline Find More Posts by Stugoose
Old Jan 04, 2012, 08:13 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
I really love mcpx and all, but after i got out of the craze and bought my 450 and 250 i find my v1 with grommets and stock length tail rewired to be sufficient, it flies good,
I really dont think anyone needs more than 1 mcpx if they want to really enjoy the other aspects of the hobby "COMING FROM THE GUY WHO JUST THREW OUT
7 MCPX BNF/RTF BOXES"
Old Jan 04, 2012, 08:14 PM
JMull is offline
Joined Jan 2012
NO do not get it. I have heard many different things about how much better the v1 is than the v2...i know for a fact that the v2 shakes extremely while flying especially trying to do aerobatics. Get the v1.
And thanks to STU and koko I'll give it a whirl.
koko..a friend of mine at my RC club told me something like that but i had no idea what he was talking about... thank you
and when u say 3 you mean the 2 to the servos and the 1 other one, but not the one in the guard, right?
Old Jan 04, 2012, 08:16 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
@jmull Id like to read about this, can you link me to someone posting about this, this is good news to me i was thinkin for my next mcp if i do get one of going v2
Old Jan 04, 2012, 08:17 PM
Joined Jan 2012
And it seem a v2's should be better as a production upgrade, wow. V1 huh
Old Jan 04, 2012, 08:18 PM
Joined Oct 2011
You need to adjust all 3 pushrod ball links (black plastic thingie on upper end of each pushrod) from all three servos, including the rear one in the "guard". You need to make sure you turn them out the same number of full turns so you keep the swashplate level. You need to do full 360 degree turns because the links only fit on the balls properly one way. You can't do a "half 180 turn" and expect them to fit right.
Old Jan 04, 2012, 08:23 PM
Joined Jan 2012
Why did u go through 7? Is this heli that faulty on 3in1 board or what.
Of the tenergy, hyperion and lectrons what one is the best lipo?
Old Jan 04, 2012, 08:25 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
I did not use a sim, just learned on mcpx's, It was worth it, Boards do fry and stuff like that,
Sometimes servos got shot, i leatrned inverted hover on it too so add that in themix
Old Jan 04, 2012, 08:26 PM
Joined Oct 2011
I wondered that myself before when he talked about owning/modifying all those mCP X's and then "offing" them one by one.
I think he's a closet "Dexter-esque" psycho killer of mCP X helis...
Old Jan 04, 2012, 08:27 PM
JMull is offline
Joined Jan 2012
heres one:
http://www.rcgroups.com/forums/showthread.php?t=1555930
i also no from experience from watching my friend fly (he is quite experienced) and the tail was shaking very hard and so was the body of the heli...there are many more complaints like this one...i think its a common issue.
Its worse than the v1 and it doesnt add any new fancy additions so i dont think its worth it to get the v2...thats why i got the v1
Theme of this story: Always do your resarch!!!
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15676 Aug 30, 2015 11:28 PM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
