Old Dec 08, 2011, 05:54 PM
Stugoose is offline
Find More Posts by Stugoose
Stugoose's Avatar
United States, NY, New York
Joined Jul 2011
Does anyone here want to buy an mcpx board minus the battery clip on harness 35 bucks shipped
Stugoose is offline Find More Posts by Stugoose
Old Dec 08, 2011, 06:00 PM
timox72 is offline
Find More Posts by timox72
timox72's Avatar
Espaņa, CN, Las Palmas de Gran Canaria
Joined Oct 2011
Hi Stugoose,
By causality you wouldn't be wanting to ship to Spain would you? I'm interested
timox72 is offline Find More Posts by timox72
Old Dec 08, 2011, 06:05 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Thanks!
It's shopping time for blades and some other parts.
IceWind is offline Find More Posts by IceWind
Old Dec 08, 2011, 06:17 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
Originally Posted by timox72 View Post
Hi Stugoose,
I would but for a little extra
Old Dec 08, 2011, 06:58 PM
timox72 is offline
timox72's Avatar
Joined Oct 2011
For sure, just tell me how much
Old Dec 08, 2011, 07:15 PM
turboparker is online now
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
Originally Posted by Wiskey View Post
I'm a little disappointed.
I fly this thing all the time, and I always thought the head looked a little "Clunky" - so I upgraded to the aluminum center part, Aluminum grips, Microheli swash-plate (helps eliminate slop too), and Aluminum main-shaft.
After 2 flights the main-shaft is bent, and though the grips lasted much longer, the bearings eventually blew out in them, and the part that holds the ball bent.
I expected much better longevity, I hate to go back to the clunky looking stock head, especially after I spent so much to get a much cooler looking one, but the stock one I never had any problems with.
Do any of you guys with this aluminum stuff have the same results?
Whiskey
Wow. Do you crash a lot without hitting TH?
Aluminum parts weren't designed to make a heli crash-proof. In fact, plastic parts often fare better in a hard crash. Hence, why you typically don't see a lot of aluminum on beginner helis. I have MH's full-metal-head & swash. The MH hub is tighter than the plastic one, and it uses higher-durometer dampers. The aluminum shaft spins much truer than the stock hollow c/f shaft, however it bends easily in a crash. My MH grips were defective. The screw hole is further out on one than the other by a few thousandths of an inch - just enough to throw everything out of balance. The MH swash is much better than the stocker.
I am currently using the MH hub, swash, and their new solid c/f mainshaft. I went back to my 'B' grips with Boca bearings. After a few hundred flights, the bearings are still slop-free.
Joel
turboparker is online now Find More Posts by turboparker
Old Dec 08, 2011, 07:38 PM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
I bent my aluminium shaft on the 3rd flight trying inverted and hit the deck fully inverted I subsequently went back to the cf shaft and will keep it that way. I also use the MH swash and this in now my only modded head part.
stevebarrow is offline Find More Posts by stevebarrow
Old Dec 08, 2011, 07:59 PM View Post
raydys
A moderator felt this post violated the following rule: Cross-posting. Show it to me anyway.
Old Dec 08, 2011, 08:17 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Is it better to connect the yellow wire from thesteve to the resistor or to the + side of the motor connector? I prefer the motor connector as my soldering skills are weak.
tonyastro is offline Find More Posts by tonyastro
Old Dec 08, 2011, 08:37 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
Resistor by far!
Its not that hard to solder, strip 1mm on the end of the yellow wire and tin it, clean the tip of your iron and get a small blob of solder on the end and quickly tap the spot on the resistor just to transfer some solder to it, hold the wire on the resistor and touch it with a clean iron, takes less than a second.
Dylwad is offline Find More Posts by Dylwad
Old Dec 08, 2011, 08:44 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Originally Posted by Dylwad View Post
Resistor by far!
Thanks! Will do!
Old Dec 08, 2011, 08:48 PM
Wookster is offline
Find More Posts by Wookster
Augernaut
Wookster's Avatar
United States, KS, Overland Park
Joined Jan 2010
oooh, crash damage is worse than anticipated. What looked like a sliver of CF sticking out of the tail boom was really just a hint of the damage. It looks like the whole rod is feathered at the end that goes into the heli. I guess its a good excuse to get the better tail off the V2 right? I've had the thing less than a week and I'm already fighting the underpowered tail.
Wookster is offline Find More Posts by Wookster
Old Dec 08, 2011, 09:22 PM
Heli Mad
Joined Feb 2002
Buy a better battery (like the ones Dywald has) and the KBDD tail blade and the tail problem will be nearly resolved - have you reduced the pitch travel to help with this?
Old Dec 08, 2011, 09:38 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
just a little indoor fun flight no inverted, v3 tail stock mcpx with bullet blades and grommets on all 3 swash balls
http://www.youtube.com/watch?v=QWPs6U0EMg0
Old Dec 09, 2011, 12:49 AM
Dr.Ben is offline
Find More Posts by Dr.Ben
Joined Oct 2005
Forgive me guys since I know that somewhere buried in this thread is the answer, but what are you using to mount Hyperion 550's in an MPCX?
Ben Minor
Dr.Ben is offline Find More Posts by Dr.Ben
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15686 Sep 07, 2016 02:54 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
