Joined Mar 2011
Hi
people have been finding out that the rear swash ball likes to break off in a crash , someone posted a good theory as to why on on of the other forums , seems to be that the rear link wire being straight , does not bend like the front two do , this transmits the impact of a crash to the rear ballone problem with putting a relief bend in the rear link , is that there is a frame member in the way i used a piece of 0.020" ( 0.5mm ) music wire and formed a half loop to pass out and around this frame member , and i snipped the threaded end off a stock link , and used a simple lap joint , with a fine wire wrap and solder to complete it here is a photo , best regards
Prescott, AZ
Joined Jan 2011
United States, AK, Ketchikan
Joined Mar 2008
I received my box of spares yesterday so I was able to install the new tail boom. Flew once more yesterday but managed to pop out the pin fix yet again. Back into the hangar, where I regaled it with some med CA. Finally got some good flights in this morning, 7 in total. The wind had picked up, and was fairly gusty, for the last 4 flights, but this heli sure can handle it well, especially for its size. I mostly practiced normal flight, and due to the wind, didn't attempt any stunts. Had a few crashes but everything held together this time, for once!!
CA and Epoxy do not work. nothing wants to stick to this plastic but JB weld works the best for me so far. or wrap it in thread and ca it. i did that for the tail boom. my heli looks like HELL now but its still kicking. |
Joined Mar 2011
Hi
i wanted to post a bit of an update on the soft rear link i have been playing with i was worried that the big half loop i did the first time might prove to be too soft and i thought it was worth playing around a bit to match the flex of the front links i first saw this idea on the freak , and the post i was looking at had a piece of wire with a couple of bends in it right at the servo , it got me thinking a small loop would be a good solution also , and depending on the size of the loop you could tune the stiffness of the link , here is a new photo , best regards
I picked up some 2mm CF today and am gonna tear it down tonight and do a complete overhaul on it,to include cleaning the servos,changing the swash,head and servo links,and installing a new canopy(mine beat to pieces) a new tail boom.I have went through 3 tail booms,one blade grip(bearing seperated at flight #146),a canopy,and a set of bullet blades.The tail booms are annoying and cost a little bit so I won't do that anymore-using solid 2mm CF from now on.The airframe has 12 hours and 8 minutes on it.That's a pretty good return on my investment,in my opinion.Best of all-approximately 30 minutes of downtime so far.That's priceless to me,as I work offshore and have limited time in which to enjoy this hobby.
Binding with DX6i
I have bound my mCP X to my DX6i as described in the manual, but in step 6 it says move the trainer switch and the swash will move up and down to confirm it is in computer mode.
However, my swash does not move when the trainer switch is moved.... is this a problem?
| Thread Tools | |
| Discussion Blade mCP X BNF Heli... | ChuckTseeker | Micro Helis | 15109 | May 17, 2013 07:58 PM |
| Discussion Blade mCP X Discuss anything thread | A Rdnek | Micro Helis | 457 | Jul 26, 2011 11:34 PM |
| Discussion The New BLADE mCP X Has Arrived... | ChuckTseeker | Electric Heli Talk | 38 | Mar 27, 2011 07:35 PM |
| Discussion new blade mcp X anyone know anything new. | epoweredrc | Atlanta Area RC | 6 | Mar 16, 2011 08:14 PM |
| Discussion Blade mCP x - strictly on topic Q and A thread | jdog83 | Micro Helis | 58 | Feb 07, 2011 02:28 PM |
