Old Nov 22, 2011, 06:37 PM
Stugoose is offline
Find More Posts by Stugoose
Stugoose's Avatar
United States, NY, New York
Joined Jul 2011
iits the shiny more squared off one, i was reluctant to try the kbdd tail rotor but i love it
Stugoose is offline Find More Posts by Stugoose
Old Nov 22, 2011, 06:39 PM
DudeInMyrtleBch is offline
Find More Posts by DudeInMyrtleBch
United States, SC, Myrtle Beach
Joined Jun 2011
You just described it perfectly...
Originally Posted by kokopelli View Post
Anyone have a picture of this V3 tail rotor blade? Is it just the new shinier, more squared off and slightly longer one from Horizon/Blade?
DudeInMyrtleBch is offline Find More Posts by DudeInMyrtleBch
Old Nov 22, 2011, 06:53 PM
kokopelli is offline
Find More Posts by kokopelli
Joined Oct 2011
Okay, that's what I have. What's the V2 tail rotor blade look like? The V1 was exactly the same as the mSR tail rotor blade.
kokopelli is offline Find More Posts by kokopelli
Reply With Quote  (Disabled)
Old Nov 22, 2011, 06:54 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
v2 is same as v1 which is same as msr
Old Nov 22, 2011, 06:57 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
this is why its safe for me to fly this by my dogs, this dog hates air going on his nose so he abandons hopes when it reaches
http://www.youtube.com/watch?v=YXqCnyEnng0
Old Nov 22, 2011, 07:01 PM
Joined Oct 2011
Ah, thanks. What was the difference of the V2 over the V1 tail assembly? Just the cage around the motor? I don't think anyone ever determined if the motor was upgraded or not. Seems the same to me.
Old Nov 22, 2011, 07:12 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
I am actually using the motor from the msr and all 3 versions are the same, the v1 is exactly the same as msr, i think they redid the coating on the end cap for v2 and v3
Old Nov 23, 2011, 07:45 AM
str8eightshot is offline
Find More Posts by str8eightshot
homeless or heli's...hmmm?
tucson
Joined Aug 2009
I got this upgrade from wowhobbies, solderless pnp
http://www.wowhobbies.com/thestevebl...r-3-1-3-1.aspx
Before the upgrade I modified the tail boom adding 3/4 length to get it to hold and it was working until I upgraded now it blows out in a simple figure 8
I was getting 2.5-3 min on stock batteries and 4-5 min on Nano-tech 300mah now a stock battery is 30 seconds and a nano-tech is 2 min I tried dropping the throttle curve from 100 to 85, little improvement
Radio = DX8 No Subtrim, All travel set to 100% but the Pitch, set to 75%
D/R A= 70/30 Fmode 100/20 E= 70/30 Fmode 100/20 R= inh
Throttle N= 0 40 65 70 80 1= 80 75 70 75 80 2= 85 85 85 85 85
Pitch N= 40 40 50 75 100 1&2= 0 25 50 75 100
str8eightshot is offline Find More Posts by str8eightshot
Old Nov 23, 2011, 08:08 AM
Joined Oct 2011
I don't know about the DX8 settings as I run a DX7, but something is definitely wrong. I have the same WOW PNP brushless kit (C05 motor) and I don't get any blowouts with the stock tail. It will step out about 30-45 degrees with hard pitch pumps at the end of a battery, but it definitely doesn't "lose it". I'm getting 3.5 minutes on Hyperion 240mAh batteries, which are pretty well used. I just got a no-name 550mAh battery and logged a 7.5 minute indoor flight with hovering, low speed FF, piros and lots of pitch pumps. I like the battery so much that I have more on the way. Overall, the brushless conversion has been great and I'm waiting for Dylan to make some more 140mm booms that I can try with the stock motor to see if I can get it to hold better at the end of a pack.
My WOW kit initially came with the 120SR tail running the Novus CP tail rotor blade. It worked great, but I already crashed and broke it, so I'm back to running the stock tail for now.
Old Nov 23, 2011, 08:56 AM
perschek is online now
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
I can't get the link to work did you get c05 or hp05. If you got c05 then there is something wrong because I have same kit and I didn't notice more than 30 seconds battery difference from stock. I've heard the hp05 requires a bigger battery because 300mahs don't last long at all. Especially if they are "seasoned" a bit and need to be replaced. The stock batteries are no longer used for me, they suck try lectron 300 35cs they are 2 for 13 bucks and are my favorite over all my batteries (hyperion 250s included) You can also wire 2 batteries in parallel to double the mah and get much more flying time. You might consider soldering the power from the esc to the back of the board as well. I noticed a slight power increase after doing so and it wasn't hard to do since the spots are big. Just touch the soldering iron to the solder for a few seconds before you try and solder the wire on. Wait until it starts to looks "liquid" like but don't hold it there for ever. There seems to be a film or something over it, so you need to melt it off a tad. Don't burn the crap out of it, but touch it for a second or two, take it off, touch it for a second or two, take it off. AS SOON AS you see it start to melt then solder to it. (If you decide to go that route, it's not necessary at all.
As far as the tail a 6" with my brushless was the best tail hold I could find with my c05.
perschek is online now Find More Posts by perschek
Old Nov 23, 2011, 11:49 AM
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
Looks like the grommet mod is still necessary on the MH swash, the same or more slop with out the grommets
Old Nov 23, 2011, 11:52 AM
Joined Oct 2011
I didn't find that to be true on my brushless mCP X. I had a low speed wobble, but I fixed that with a head damper on each blade grip pitch arm behind the upper part of the dog bone link. Not really the "regular grommet mod" everyone does by putting them on the swashplate balls. But, that's not to say mine won't need it in the future...
Old Nov 23, 2011, 12:51 PM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
lame, lame...
MSN homepage has a "toy recall" section on their homepage, with an MCPx featured prominently:
http://www.msn.com/
Then, in the link, come to find out...it's a cheapie plastic toy heli:
http://specials.msn.com/a-list/news/...%20helicopters
Rumour-mongering bastages.
maukabud is offline Find More Posts by maukabud
Old Nov 23, 2011, 12:52 PM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
My MH swash has zero sloppage w/o grommies....
Old Nov 23, 2011, 01:07 PM
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
http://www.msn.com/
Wow if I were HH I would be pissed for them putting that picture on there website with toy recall on it. Lawsuit anyone?
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15686 Sep 07, 2016 02:54 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
