Old Nov 20, 2011, 12:32 PM
leereyn is offline
Find More Posts by leereyn
1981 Z28 "The Wife"
leereyn's Avatar
Bainbridge, GA
Joined Feb 2002
Originally Posted by Stugoose View Post
servos are constantly moving as it is flybarless, electric smell?
It's probably because it's new, but I smell something while flying. As long as the twitching is normal then I'll fly it and not worry. Thanks.
leereyn is offline Find More Posts by leereyn
Old Nov 20, 2011, 12:33 PM
LawnDartHeli is offline
Find More Posts by LawnDartHeli
And here..we..GO!
United States, AR, Alexander
Joined Sep 2011
Finally broke the tail boom on mine, only took 3 months..yeaaaaaa!!
Also broke one of the balls off my swash, I know I still have 2, but Im thinking of buying the microheli swash and eliminating that problem all around. Has anyone changed to the MH swash only, and used all the stock head components? Does it make it fly weird if I dont upgrade the other parts?
LawnDartHeli is offline Find More Posts by LawnDartHeli
Old Nov 20, 2011, 12:49 PM
Stugoose is offline
Find More Posts by Stugoose
Stugoose's Avatar
United States, NY, New York
Joined Jul 2011
Also broke one of the balls off my swash, I know I still 2, but Im thinking of buying the microheli swash and eliminating that problem all around. Has anyone changed to the MH swash only, and used all the stock head components? Dies it make it fly weird if I dont upgrade the other parts?
this video is a stock head with the swash, stock v1 boom with kbdb tail blade
Mcpx inverted indoor (cruizin) (1 min 33 sec)
Stugoose is offline Find More Posts by Stugoose
Old Nov 20, 2011, 01:34 PM
kokopelli is offline
Find More Posts by kokopelli
Joined Oct 2011
I have the Microheli swash and love it. The rest of the head is stock except I put one rubber head damper behind each blade grip ball/link because I had some wobbles with the higher head speed after converting to brushless.
kokopelli is offline Find More Posts by kokopelli
Reply With Quote  (Disabled)
Old Nov 20, 2011, 01:40 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
its like paraphrasing an anology to the notorious b.i.g.
the mo motor the mo problems lol
Old Nov 20, 2011, 02:45 PM
RCMattG is offline
Find More Posts by RCMattG
Joined Mar 2011
Concerning performance I don't like the KBDD blades (main rotor). I am
able to fly with them obviously but they aren't as responsive as the stock high performance blades. I tried about 6 batteries on the KBDD and then switched back and notice much more "pump" in the pitch ha. It's possible I need to add more positive pitch for the KBDD blades as I did notice that there is a small amount of space in the blade grips with the KBDD blades. Any other similar observation?
RCMattG is offline Find More Posts by RCMattG
Old Nov 20, 2011, 03:55 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
I'm noticing this too. I had the white kbdd main blades when I first got the heli and they seemed to work fine but then when they broke I went back to the stock and weighted blades for about 2 weeks. Then I slapped the orange kbdd blades on and it seems alot more sluggish. I'm going to weigh them right now because they are also not tracking. This might be because of my broken / glued main hub. But I'm thinking they are a little too heavy. I'm running 95% pitch travel and its still "slow" compared to the regular blades :-/.
HELP Towards the end of my flights the last 2 minutes or so my heli is way out of wack trim wise. I hope my 3axis isn't out of wack or something. I'll trim it right off the bat and it just sits there, then at the end it will drift backwards, not just a little, its MAJOR like if I didn't stop it I would be upside down................................ Well thats an exaggeration but it is major 4-5 clicks of trim to keep it steady. I'll try re-binding and all the simple stuff but if anyone else has had this prob let me know. Maybe I need a swash leveler because I noticed my push rods are bent too..
perschek is offline Find More Posts by perschek
Old Nov 20, 2011, 04:16 PM
RCMattG is offline
Joined Mar 2011
Let me know the weight of the blades. They have a different shape to obviously. A small spacer washer might fit in between the grip and blade to remove any "slop".
This may be stupid but is your battery staying in place or sliding back in the battery grip? I use the larger battery "tray" from Astroid Designs and the turnigy bats slide back from aggressive flight. Then balance is towards the back.
Old Nov 20, 2011, 04:21 PM
Ibs is offline
Ibs
Find More Posts by Ibs
Ibs
Brisbane, Australia
Joined Apr 2009
Hi,
I have flown my with badly bent servo links. The FBL controller just compensates but it does look silly when you pull the battery and the swash is wonky. However, if they are so bend that there is not sufficient servo travel then this could be your problem. Of course, it would only affect flight when you reach max servo travel so it would be very inconsistent. And of course, after the servos being jammed at full travel they might not return to normal smoothly.
Cheers, Ibs
Ibs is offline Find More Posts by Ibs
Old Nov 20, 2011, 04:35 PM
Joined Oct 2011
Perschek, how bent are they? It's not hard to just eyeball it. Carefully turn the large servo gears by hand (obviously no batt) to center the slider in each servo slot and look to make sure the swashplate is level. Bend links back to "normal" as necessary to achieve as level a swashplate as you can. The two front links should have 90 degree bend angles, as a good starting point. Once the swashplate is level, check center stick for zero degrees pitch. If it's not there, start turning links in or out an equal number of turns until it is. Check everything again when powered up against TX settings before flight.
Any minute "out of level" with the swashplate will be taken care of by the AS3X FBL system, so "tune out" any gross errors beforehand. I can't imagine trying to use a swash leveler on something this small and I don't think it would make much of a difference anyway.
Old Nov 20, 2011, 04:44 PM
jamz2233 is offline
Find More Posts by jamz2233
High Impact Lander
jamz2233's Avatar
United States, ME, Gorham
Joined Oct 2011
Screws? In MY motor?
You know how the motor is kind of buried in these things? Well, I had my canopy off for a sec today to CA the main gear onto the main shaft because it would keep slipping down, and I saw a tiny screw attached to the motor, sideways. I looked closer, and saw a second screw a little higher up.
They were not screwed into anything, just magnetized onto it.
I found a total of 4 random tiny screws hanging on the motor, through all of it's flights, crashing, etc. Must have come from the factory that way! (I've not unscrewed anything on it yet). And yes, I did look it over very carefully to make sure nothing had become unscrewed.
jamz2233 is offline Find More Posts by jamz2233
Old Nov 20, 2011, 04:49 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
flew mine today and well I went back to the stock non bullet blades. the KBDD just don't seem to make it as easy to flip the heli i already at 150% for negative on my radio and + is like 80% i played with trying to change %'s and all but never got it to fly like i liked. so just put other blades back on. I will fly the others sometime just think it fly better flips faster and all with stock.
love this lil guy flying my hyperion batters it fly nice for like 3 mins but then tail start to kick hard I think the tail motor is going out its moving back and forth even just inverted hovers'
epoweredrc is offline Find More Posts by epoweredrc
Old Nov 20, 2011, 04:50 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
http://www.rcgroups.com/forums/showthread.php?t=1468765
Dylwad is offline Find More Posts by Dylwad
Old Nov 20, 2011, 04:54 PM
Joined Oct 2011
Dylan, you've got mail...
Old Nov 20, 2011, 05:06 PM
Rockytop448 is offline
Find More Posts by Rockytop448
Rockytop448's Avatar
Joined Oct 2009
http://www.youtube.com/watch?v=X3KkkqifHPE
heres the video it came from
Any chance of getting your DX6i setup? Mine is no where near that stable. Hoping its more setup than aircraft. Brushless conversion on the way. Hoping that makes a difference.
Rockytop448 is offline Find More Posts by Rockytop448
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15676 Aug 30, 2015 11:28 PM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
