Old Nov 18, 2011, 08:43 PM
kokopelli is offline
Find More Posts by kokopelli
Joined Oct 2011
Originally Posted by perschek View Post
Ok heres my solution to the tail motor connector failing FOR NOW I'm sure I'll end up with a different solution eventually but I think tis will do for now. Soldered to the front of board and ran the wire through my landing gear.
What's the big deal with just using the stock tail motor plug? Is there really THAT much extra resistance vice soldering to the other side of the board. I've never had a stock tail motor connector fail.
kokopelli is offline Find More Posts by kokopelli
Reply With Quote  (Disabled)
Old Nov 18, 2011, 08:46 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
But don't I have to remove a resistor?? (can't find the resistor anywhere, pretty positive I don't have a resistor on my steve converter, but I have no clue.... I want to solder to that point to get linear throttle but don't want to do it if it won't work. Right now I'm soldered to the front of the board motor + spot
Lots of people on HF have left the resistor and soldered to that point. I would remove it....
The resistor is most likely on the underside of the red PCB attached to your ESC. Its between the yellow wire and the - terminal that goes to the ESC, should be a black rectangular thing with the numbers 222 on it, and it probably looks like it was added after the PCB was populated.
Dylwad is offline Find More Posts by Dylwad
Old Nov 18, 2011, 08:49 PM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
They hardly ever totally fail, it just becomes a higher resistance connection, and creates a voltage drop when the tail really needs the extra oomph.
Old Nov 18, 2011, 09:07 PM
Joined Oct 2011
Are you saying the connector becomes higher and higher resistance over time? If so, how does that happen if you're not plugging and unplugging it all the time?
Old Nov 18, 2011, 09:12 PM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
Vibration, crashes, Etc Its still higher resistance than a straight solder joint. Probably best to leave it connected, and glued as good as it was stock.
Old Nov 18, 2011, 09:16 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
mine takes 0 force to remove it, it literally falls out if I hold it upside down so it was time for some solution. This will work for now. I see the rectangular resistor, doesn't look like ones i've seen before. I'll have to remove the steve completely to get to it
perschek is offline Find More Posts by perschek
Old Nov 18, 2011, 10:16 PM
Joined Oct 2011
I had that problem with my mSR. Slightly bent the pins apart and never had a problem again.
Old Nov 18, 2011, 10:48 PM
cgriffith is offline
Find More Posts by cgriffith
cgriffith's Avatar
United States, FL, Oviedo
Joined Apr 2011
For the tail motor connector, why not just add a dab of hot glue to almost permanently hold it in place until you want to remove it.
cgriffith is offline Find More Posts by cgriffith
Old Nov 18, 2011, 11:07 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Try upping the pitch a few points over the stock blades.
you mean up the swash % some? it did feel like I didn't have as much - as I did before with other blades they feel kinda flimsy
epoweredrc is offline Find More Posts by epoweredrc
Old Nov 18, 2011, 11:38 PM
ian145 is offline
Find More Posts by ian145
ian145's Avatar
United States, CA, Santa Cruz
Joined Nov 2010
im thinking of getting the mcpx as my first cp heli. how does everyone like this heli so far?
ian145 is offline Find More Posts by ian145
Old Nov 19, 2011, 12:15 AM
rsmheli is offline
Find More Posts by rsmheli
rsmheli's Avatar
Indiana
Joined Feb 2007
Is this how you do research?
Spend some time and read the multiple threads as we have
Only you know your experience level and if this chopper may be correct for you
If you have read any threads, you would know how people like it and why.
rsmheli is offline Find More Posts by rsmheli
Old Nov 19, 2011, 01:39 AM
ian145 is offline
ian145's Avatar
Joined Nov 2010
i already did some research and i haven't heard anything bad, so i was thinking it would be helpful to ask here so someone will tell me if everything is great or if it has any major problems. i would rather not read 400 pages of this thread so i was just seeing if anyone would take a little bit of time to tell me if this is a good heli.
Old Nov 19, 2011, 02:29 AM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
Its not a heli, its an addiction, if that tells you anything
Its probably the best first CP heli PERIOD if you already have a Spektrum TX
Old Nov 19, 2011, 02:30 AM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
Exactly, Swash % is the pitch channel ATV on the MCPx
Old Nov 19, 2011, 05:24 AM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Well these 400 pages provide a massive focus group and many, many indervidual perspectives. Both after first purchase (flight) and after familiarity with this specific heli and the issues / joy they may have / had.
If you'd prefer to reduce this knowledge base to just a few comments..
I like the blue, red and white of the canopy. It exactly matches the other mcpx I bought..uncanny!
Yep, I'm being a smart a..
It is a nice heli but NONE are without their shortfalls. Well worth spending some time to read and see if it suits your requirement, expectation etc.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15676 Aug 30, 2015 11:28 PM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
