Old Nov 18, 2011, 10:33 AM
Stugoose is offline
Find More Posts by Stugoose
Stugoose's Avatar
United States, NY, New York
Joined Jul 2011
i prefer my weighted blades to the kbdd, but kbdd work better with the metal head,
Stugoose is offline Find More Posts by Stugoose
Old Nov 18, 2011, 11:39 AM
RCMattG is offline
Find More Posts by RCMattG
Joined Mar 2011
Why?
RCMattG is offline Find More Posts by RCMattG
Old Nov 18, 2011, 11:40 AM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
weighted blades are more stable, the kdbd are a tad thinner where they meat the grips and the metal head is tighter fitting
Old Nov 18, 2011, 11:41 AM
RCMattG is offline
Joined Mar 2011
I thought I remember back when this first came out that everyone was saying keep the blades as loose as possible...I guess if they are thinner though, that it would created bad "Tracking" with less responsivness...it might present itself in almost a "lag"....I think you're right...
Old Nov 18, 2011, 12:23 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
i find when i tighten my blades regardless if it is not equally loosened then there will be shakes, if they are tight at the screw there will be shakes
Old Nov 18, 2011, 01:41 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
I really want a stock brushed mcpx with the extended TUBE 140mm with kbdd tail blades for doing 3d practice. I've got too much money invested in my hotrod mcpx to do 3d now HAHA
C05 / hp05 (in transit)
MicroHeli 140mm Boom w/ motor mount and vertical fin
MicroHeli Swash (in transit)
Kbdd orange main and tail rotors
MIA Phantom Kit
Delrin Main Gears
xp7a / the steve
THINKING OF:
2s battery setup once I know how to do it safely
Brushless tail
Once I know how to do the above I'm going for it!
NOW thats all bling baby, nothin but the brushless is necesary!
STU - I know you got a bone stock mcpx you wanna sell me.
perschek is offline Find More Posts by perschek
Old Nov 18, 2011, 01:51 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
why dont u buy my parts lot, there is a stock mcp minus 1 servo there
see
http://www.rcgroups.com/forums/showthread.php?t=1541207
Old Nov 18, 2011, 02:01 PM
kokopelli is offline
Find More Posts by kokopelli
Joined Oct 2011
If you make a Y-harness, it's very easy. One female connector for each battery and one male connector to the heli. Solder both white wires from the battery end connectors to the appropriate white lead "to heli" pin and both black wires to the other and use heat shrink. Presto...you've got a parallel harness and you can run two batteries. Just have to decide how you're going to mount them...
kokopelli is offline Find More Posts by kokopelli
Reply With Quote  (Disabled)
Old Nov 18, 2011, 02:04 PM
RCMattG is offline
Joined Mar 2011
MIA Phantom Kit
Delrin Main Gears
xp7a / the steve
THINKING OF:
Brushless tail
I got a stock mcpx with extended boom/V3 tail CF fin and tail motor holder. Everything else is stock....I'd be willing to sell it forrrr let's say $120 shipped...
Old Nov 18, 2011, 02:16 PM
Stugoose is offline
Stugoose's Avatar
Joined Jul 2011
i believe he asked stu lol,,,, Just KIDDING DUDE
Old Nov 18, 2011, 02:27 PM
RCMattG is offline
Joined Mar 2011
What are you selling yours for? ha
Old Nov 18, 2011, 02:52 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
I think he means 2 cells in series, or 7.4 volts nominal.
2S setups need a motor with around half the KV, and a 3 amp diode between the BEC output of the ESC and the MCPx main board to drop the 5 volts down to 4.3 or so. I may try a 2S setup soon with a Phoenix 10 just to have a governer, and run a 2s hyperion 180 pack.
Would be nice to have 5400 RPM for the entire flight with no bogging
Dylwad is offline Find More Posts by Dylwad
Old Nov 18, 2011, 03:02 PM
dze is offline
dze
Find More Posts by dze
dze
Originally Posted by Dylwad View Post
I
do you know some motors offhand that are in that category, and is that diode a special type? Just a black 3 amp diode with a silver band on the end? .. im not too up on how diodes function, i didnt know they dropped voltage
dze is offline Find More Posts by dze
Old Nov 18, 2011, 03:16 PM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
2S motors
http://www.clubheli.com/Oversky-HP08...OR_p_2835.html
http://www.xtreme-production.com/xtr...mart&Itemid=31
2S guide http://www.helifreak.com/showthread.php?t=341139
Any 3 amp Diode will work. There is a .7 volt drop through the diode. Its a proven method for dropping BEC voltage down to 1S voltage when running a 2 cell brushless setup on the AR6400 in UM planes.
Old Nov 18, 2011, 05:48 PM
epoweredrc is online now
Find More Posts by epoweredrc
27 yrs. of Aircraft flying.
epoweredrc's Avatar
United States, GA, Tallapoosa
flew my kbdd mains today with my hyperion battery the battery is great 4 mins and only used 120mah out of it. the blades, well there okay but i was expecting much better flight. i think the stock mains fly a lil better but will give some more flights to decide for sure
epoweredrc is online now Find More Posts by epoweredrc
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15686 Sep 07, 2016 02:54 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
