Old Jun 10, 2011, 09:06 AM
BHChieftain is online now
Find More Posts by BHChieftain
Joined Apr 2010
I like the new design. I've had the cap of my tail motor break off in a crash...
Happened on my 2nd flight so was pretty bummed about that.
Chief
BHChieftain is online now Find More Posts by BHChieftain
Old Jun 10, 2011, 12:24 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Originally Posted by RobinBennett View Post
There's no logical reason why they should fly any better, unless your old one was worn or bent.
Or not made exactly right...kind of like the swashes. Some swash balls are tight some aren't. Both of my b grips were way tighter than my other older grips, which makes my mcpx's fly crisper
indoorheli is offline Find More Posts by indoorheli
Old Jun 10, 2011, 01:14 PM
DMala is offline
Find More Posts by DMala
DMala's Avatar
New Jersey
Joined Sep 2009
Originally Posted by Tom Z View Post
Here you guys go.
Old tail assembly on left, new tail assembly on right.(...)Tom
It seems stronger but cooling may not be as efficient.....
DMala is offline Find More Posts by DMala
Old Jun 10, 2011, 02:01 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Here you guys go.
Picture is from khogan.
Tom
Looks like the design from the 120. Hopefully HH can just sell the booms sep.
jabsten is offline Find More Posts by jabsten
Old Jun 10, 2011, 02:13 PM
SCAZE is offline
Find More Posts by SCAZE
SCAZE's Avatar
Sweden
Joined May 2009
My first sevear crash to day. Also my second crash
Crackt rotor blade and main gear, seems easy to crack the main gear
I couldn't hit the trottlehold button fast enough
SCAZE is offline Find More Posts by SCAZE
Old Jun 10, 2011, 03:37 PM
NwRcFlight is offline
Find More Posts by NwRcFlight
EDF Junkie
Pacific Northwest
Joined Oct 2007
Awhile back I think I saw a comment that the swash was being redesigned. Was that BS, wishful thinking or a memory failure on my part. I've seen nothing about it lately.
I thought the weakness of the rear swash ball would be addressed so a redesign made sense but it is easy to fix if it breaks (with the pin fix) or prevented with a bend in the rear arm.
NwRcFlight is offline Find More Posts by NwRcFlight
Old Jun 10, 2011, 04:34 PM
SCAZE is offline
SCAZE's Avatar
Sweden
Joined May 2009
Nop. My balls holds just fine but the main gear pops out quite often.
Hawe the new version with B grips and 25C lipos.
Old Jun 10, 2011, 05:04 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Stock vs. MH aluminum mainshaft weights, MH spool-up & flight-test
Awhile ago, someone asked about the weight of Microheli's aluminum mainshaft. Mine finally showed up & I just finished installing it. The weights include the collars & screws, but not the hub screws.
Stock shaft-- 0.56g
MH shaft ---- 0.71g
The collar is not symmetrical. I first installed it with the screw hole nearer to the head. After checking the fit of the main gear, I thought that the shaft should be sticking out of the gear a bit more than it was, so I reversed the collar so that the screw hole is nearer to the frame. I had to shorten the control rods by three turns each to restore zero pitch at mid-stick, but the gear fits much more snugly onto the shaft than it did before.
I spooled her up in my hand to check for vibration. She was smooth as butter! Definitely much smoother than with any of the c/f shafts I've had. The extra 0.15g was not noticeable in flight.
Setup:
MH mainshaft
MH swash
'B'-grips
Light blades
Dylan's Hyp 240 mount
Bare Hyp 240 cell
AUW: 45.60g
Joel
turboparker is offline Find More Posts by turboparker
Old Jun 10, 2011, 09:50 PM
Joined Apr 2010
Silicon o-ring mods
I read about using some 001 silicon 0-rings on the servo-to-swash links and also putting 3 of them on the feathering shaft between the blade grips-- wow, what a difference. Bird flies really smooth!
Chief
Old Jun 11, 2011, 09:30 AM
Nytflyer is offline
Find More Posts by Nytflyer
Newb Rotary Pilot
Odenton, MD
Joined Apr 2009
Just came from my LHS and the shop owner said they just got something from HH saying there is a recall on the entire heli now. Anyone else heard of this?
Nytflyer is offline Find More Posts by Nytflyer
Old Jun 11, 2011, 10:57 AM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
No recent bulletins on the HH website:
http://www.horizonhobby.com/Support/...Bulletins.aspx
maukabud is offline Find More Posts by maukabud
Old Jun 11, 2011, 11:02 AM
Joined Jul 2009
I stopped by my LHS yesterday to pick up the MH aluminum mainshafts I had ordered. The owner didn't mention anything about a recall. As Bud noted, there is no mention of it on the website.
Joel
Old Jun 11, 2011, 11:10 AM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Some are still talking about the blade grip recall from months ago as if it is something new. It's old news and your shop must just now be getting around to reading their notice from HH telling them to remove the old stock with the original grips.
Xrayted is offline Find More Posts by Xrayted
Old Jun 11, 2011, 11:37 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
That would be my guess too.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jun 11, 2011, 11:41 AM
Nytflyer is offline
Newb Rotary Pilot
Odenton, MD
Joined Apr 2009
Yea that is kind of what I was thinking too. I asked him if it was about the grips and he said no that you had to send the whole heli in to HH. I searched when I got home and couldnt find anything so just figured I would ask here to be sure.
Anyways, thanks for the responses and happy flying to all!
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Yesterday 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
