Old Mar 29, 2011, 11:21 PM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
Originally Posted by DAC1 View Post
Does anyone have any suggestions?
You could lengthen and flatten your pitch curve to make it less sensitive (move the 75% point value down to the 50% point) but this would then move the hover point from 75-80 down and you may also need to adjust your throttle curve to compensate.
stevebarrow is offline Find More Posts by stevebarrow
Old Mar 29, 2011, 11:59 PM
fairplane is offline
Find More Posts by fairplane
fairplane's Avatar
Canada, SK, Prince Albert
Joined Aug 2006
Originally Posted by Razors edge 29 View Post
got a link to those bearings you bought?
http://www.microheli.com/store/produ...718cb66aea1508
fairplane is offline Find More Posts by fairplane
Old Mar 30, 2011, 12:20 AM
NwRcFlight is offline
Find More Posts by NwRcFlight
EDF Junkie
Pacific Northwest
Joined Oct 2007
Hello, I just got my MCP X a few days ago. I set up my DX6i with the recommended settings.
With these settings I need to have the collective at about 75-80% to maintain a hover. The response is very touchy when I move the stick up from there. Is this typical?
I have shifted the pitch curve up a bit which has been a help but I am not totally happy with it. There doesn't seem to be anything to adjust on the heli. Does anyone have any suggestions?
What you are describing sounds like a DX6i that isn't set up right. When you set the pitch travel adjust to 75% did you do it twice? Once with the throttle stick below mid stick and again with the throttle above mid stick? Both positions need to be set and it isn't clear from the mCP X manual that both settings need to be done.
I experienced the same behavior that you are because mine was wrong initially. Once I had the programming right it was much easier to fly.
NwRcFlight is offline Find More Posts by NwRcFlight
Old Mar 30, 2011, 12:22 AM
sviking is offline
Find More Posts by sviking
Prescott, AZ
Joined Jan 2011
Actually, I've come to find that 3/4 "up" throttle is the proper place for an upright hover with zero degrees pitch at 1/2 stick. That way there is NO change or jump in flight when flipping from Normal to Stunt 1 or Stunt 2 in the upper half of the collective/throttle stick travel. Took some getting used to as I've always set my helis up to hover at 1/2 stick back in my glow powered engine days.
sviking is offline Find More Posts by sviking
Old Mar 30, 2011, 11:11 AM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
DAC-1,
I suggest you keep your pitch travel linear like the default setup but tweek the throttle curve. I found the sweet spot on mine to be:
N 0 27 54 75 100
ST-1 100 75 54 75 100
ST-2 100s
H 0s
Pitch curve:
N 25,25,50,75,100
ST-1&2 0,25,50,75,100 also Hold is the same for adjusting & measuring pitch
These settings give good altitude and RPM control over all for me so far.
YMMV, Don
dbennettya is offline Find More Posts by dbennettya
Old Mar 30, 2011, 02:02 PM
ihover is offline
Find More Posts by ihover
ihover's Avatar
United Kingdom, Knutsford
Joined Feb 2011
Everyone has been adjusting the length of the pushrods (3 or 4 turns) so that it hovers at mid stick. The blades do not then look like they are at 0 pitch though
ihover is offline Find More Posts by ihover
Old Mar 30, 2011, 02:04 PM
sviking is offline
Prescott, AZ
Joined Jan 2011
Uh, no...they haven't...
Old Mar 30, 2011, 02:05 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
No you dont want to do that...keep 0 pitch at mid stick. You should be able to hover around 70-75%. If you hover at 50% something is not set up right and for tranistioning to idle up you will have problems
indoorheli is offline Find More Posts by indoorheli
Old Mar 30, 2011, 02:08 PM
destinbeachman is offline
Find More Posts by destinbeachman
destinbeachman's Avatar
Florida
Joined Jul 2010
That's right.Shouldn't be hovering at mid-stick.Should be around 70-75 percent.
destinbeachman is offline Find More Posts by destinbeachman
Old Mar 30, 2011, 02:10 PM
sviking is offline
Prescott, AZ
Joined Jan 2011
Yup, don't want any unexpected jumps switching between the three flight modes at or above half stick...
Old Mar 30, 2011, 02:14 PM
VaderSS is offline
Find More Posts by VaderSS
Skill Seeker
Cordelia, CA
Joined Jan 2011
No, they've been adjusting them so they get zero pitch at mid-stick. They often come with a lot of negative pitch at mid-stick. Mine hovered at almost full-stick, out of the box...
VaderSS is offline Find More Posts by VaderSS
Old Mar 30, 2011, 02:20 PM
sviking is offline
Prescott, AZ
Joined Jan 2011
Mine took two full turns "out" on each link to move the swashplate up to zero at half stick.
Old Mar 30, 2011, 02:27 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Mine too two full turns "out" on each link to move the swashplate up to zero at half stick.
Mine has actually changed over time - I adjusted for zero pitch right when I got it, then I had to do another turn on all the links yesterday. I keep flying it with the heavy blades though - it's kinda zippy with those, but still precision is easier.
jasmine2501 is offline Find More Posts by jasmine2501
Old Mar 30, 2011, 02:48 PM
ihover is offline
ihover's Avatar
Joined Feb 2011
I have adjusted the push rods 3 turns for a hover at mid stick. In theory this should be when the blades are at 0deg pitch at mid stick, but I for one have found the pitch is say 15deg at mid stick which produces hover at mid stick. I use the bullet/FF blades, is this what everyone else is experiencing?
Old Mar 30, 2011, 02:50 PM
Florida
Joined Jul 2010
i have adjusted the push rods 3 turns for a hover at mid stick. In theory this should be when the blades are at 0deg pitch at mid stick, but i for one have found the pitch is say 15deg at mid stick which produces hover at mid stick. I use the bullet/ff blades, is this what everyone else is experiencing?
huh?
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Jun 29, 2016 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
