Old Mar 08, 2011, 07:29 PM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Video Receiver RSSI overlaid in OSD
There are products that show video receiver RSSI such as this one:
http://www.dpcav.com/xcart/product.p...2&cat=0&page=1
But this doesn't help when you've got goggles on during flight.
Is there any manufacturer that produces anything that can overlay the Video Receiver RSSI into the video display?
Or something even simpler - a warning buzzer if the RSSI drops to 50%?
Cheers,
BB
borneobear is offline Find More Posts by borneobear
Old Mar 08, 2011, 07:31 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Cheers,
BB
Check out the FrSky transmitter modules with telemetry receivers.
Art Newland is offline Find More Posts by Art Newland
Old Mar 08, 2011, 07:38 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
You mean the Video rssi rather than rc rssi right?
I was thinking the RMILEC was $10 - (now a bit more!) OSD could be used on the vrx side to display that, particularly if you bought a few whilke they were $10. As I think it can be used to display the rc rssi.
NDw is offline Find More Posts by NDw
Old Mar 08, 2011, 08:05 PM
llamero is offline
Find More Posts by llamero
Joined Jun 2010
Any voltmeter will do:
Poor man's RSSI monitor
Since the video receiver has an RSSI pin, and I figured that sort of information would be helpful, I hooked up a cheap multimeter I had laying around to the RSSI. For my receiver a strong signal reads <1V while no signal is 2-3V. Now I can monitor both background signal as well as signal strength coming from the plane without having the video cut-out first.
0.98V when the transmitter is on and nearby
2.29V when the transmitter is unplugged. (Likely the antenna is still picking up emissions from the BECs and monitor as when it is away from all that it reads >3V...again even more useful info).
Besides, it let's my spotters feel more like co-pilots when they get to monitor RSSI voltage and other data. Spotters also are voice activated so you can get an audio feed of your RSSI data in real-time, on command .
Otherwise, you'd need a second OSD on the receiver side over-laying the RSSI info onto the video stream. Not sure if anyone is doing this yet.
llamero is offline Find More Posts by llamero
Old Mar 08, 2011, 10:17 PM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Yes, I was thinking of along these lines.
But don't quite know how to do it. ... like, how do I tap into the Video Receiver video stream?
Old Mar 09, 2011, 12:59 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
It's pretty simple to overlay video RSSI with the rmilec OSD. At least on my Fox 800 VRx, there's an RSSI pin coming out of the internal tuner (metal box) in your video receiver that you can connect to the 2nd voltage input on the Rmilec OSD. One downside is that the 1st voltage input of the OSD requires at least around 6.5 volts to power the OSD, so you'd need to connect it to the DC input of your VRx or similar. The 2nd voltage input on the OSD registers from around 0.3v to 18v so it can go to the RSSI pin. The result will be 3 values from left to right (V1=VRx lipo voltage, timer, V2=RSSI voltage). You will not be able to turn off V1 or the timer, but can position the on-screen info at several places from the top to bottom of your screen. You could easily install the OSD inside your VRx.
With that said, I feel that on-screen video RSSI is all but useless. During FPV, there are essentially 2 conditions where video signal becomes degraded, and an RSSI indicator doesn't really help in either circumstance. If your plane goes down and if your very, very lucky enough to still be getting a video signal at ground level, then RSSI might help you locate it.
Condition 1 - You fly behind an RF attenuating obstacle (be it a building, the ground, or your plane's lipo). On-screen RSSI won't in anyway prevent you from doing this; nor will it help after the fact.
Condition 2 - You gradually fly away until video signal is lost. The slowly increasing level of graininess and static in your picture will be a much larger indication that it's probably time to turn around, than an on-screen RSSI value. RF propagation isn't linear, so RSSI voltage won't be as helpful as you'd think in gauging remaining range either.
I am a big believer in having an RSSI indicator of your R/C control link because it's something that often shows no sign of weak signal until it fails. Even my best analog 72Mhz Corona RD802II receivers won't glitch and simply loose link when out of range.
patricklupo is offline Find More Posts by patricklupo
Old Mar 09, 2011, 01:01 AM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Maybe you could use a second osd on the ground, after your VRx but before your goggles? Set up a screen on that OSD with only one parameter, perhaps for instance, an ET osd and use the RSSI parameter. Instead of the RSSI from RC Rx, you use the RSSI from the ground station Vtx. I think they have similar values. Set it up in the wizzard as you would normal, presto, Vtx RSSI on video overlay. Only thing is I dont know what will happen running video with overlay (off plane) through another osd. I dont think it would be a problem provided any telemerty is already used.
I have the spare gear for this, maybe I have a go and let you know if it works.
George.
EDIT: ^^ What Patrick said!
Thumb_number is offline Find More Posts by Thumb_number
Old Mar 09, 2011, 01:12 AM
felipesalomao is offline
Find More Posts by felipesalomao
Joined Sep 2010
would be great eagle tree osd pro support it, i think that isnt so hard to do it, we could connect rssi pin wires from receive to eagle eyes ground station, then it would add these informations (rssi) on video out, its possible ?
felipesalomao is offline Find More Posts by felipesalomao
Old Mar 09, 2011, 09:49 AM
flipflap is online now
Find More Posts by flipflap
Joined Mar 2009
basically you'd like to know when it's going too low, so maybe an audio indication can be sufficient ? a beep when the signal is weak should be quite easy to do.
or if you are looking for a complicated way to do it, connect somehow the rssi to a channel of your RC TX. This will control a servo which moves a needle or small flag which is seen by the camera...
flipflap is online now Find More Posts by flipflap
Old Mar 09, 2011, 11:36 AM
Shikra is online now
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Use something like Remzibi OSD on video line of your groundstation - you can display what you want, where you want.
Or one of the MAX OSD projects boards and do your own.
But really your eyes are best RSSI ! If picture is crap time to turn around and come home!
Shikra is online now Find More Posts by Shikra
Old Mar 09, 2011, 12:22 PM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^ +1
I second Shikra's post. Most video drop outs are due to multipathing, not lack of signal strength. RSSI does not indicate mutipath intereference and thus is of no practical use.
On top of that, RSSI is logarithmically scaled. It is very hard to get a definite "turn aruond at weak signals as the RSSI is not well defined in the lower ranges.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Mar 09, 2011, 08:52 PM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Thanks for all the great input guys.
If the Video receiver RSSI is not linear to strength and distance, than it is certainly useless for anything (other than maybe antenna modding ).
Back to the drawing board.
BB
Old Mar 10, 2011, 12:12 AM
Joined Mar 2009
Here is an article studying the feasibility of using the rssi to measure distance, it doesn't work well, but you can be interested by their study of the relationship between rssi and distance.
http://www.docstoc.com/docs/26290971...ion-Algorithms
New Product DPCAV RSSI Buffer Board - Installation Video - EagleTree OSD Pro + Thomas LRS FPV Bill FPV Talk 11 Jun 27, 2011 03:57 PM
Discussion RSSI. whats more important RC-rx or the Video-rx RSSI? rclab1 FPV Talk 2 Nov 15, 2010 09:58 PM
Help! RSSI set up on RV OSD and EZOSD Gree FPV Talk 1 Oct 31, 2010 03:54 AM
Discussion Dragon link RSSI + Eagletree OSD PRO ecampos FPV Talk 2 Sep 09, 2010 12:51 AM
Discussion RSSI output fed into ELOGGER and Video OSD rajesh5024 FPV Talk 6 Apr 14, 2009 02:03 AM
