Old Mar 08, 2011, 08:00 PM
chriscap is offline
Find More Posts by chriscap
USA, CA, Los Angeles
Joined Jun 2010
Question
Proper Aurora 9 Lipo Discharge
I've been searching for answer to this on these forums all day and havne't found it. If I want to use a 2S lipo, is it okay to use a battery with a 20C rating? I can't find a TX pack that's 2S that's low discharge like I have on one of my airtronics. Does anyone have direct experience with this and/or can give me a definitive answer.
chriscap is offline Find More Posts by chriscap
Old Mar 08, 2011, 08:34 PM
mtnlvr is offline
Find More Posts by mtnlvr
Joined Jan 2004
You can use a 20C...30C...45C...etc. The higher C rating will no harm anything...just means that the battery has the capability to withstand higher amp draw. It will not discharge faster. Hope that is what you were referring to.
mtnlvr is offline Find More Posts by mtnlvr
Old Mar 08, 2011, 08:40 PM
chriscap is offline
Joined Jun 2010
That is what I was referring to. I was thinking it didn't matter because the Tx will pull what it needs just like a power system.
Old Mar 09, 2011, 12:26 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
The lower the "C" rating, the longer lasting and better for transmitters.
A good guide :
TX Lipo Battery Review - By Mike Llewellyn
more at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
(quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Mar 09, 2011, 12:32 AM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
But at $8 for 20C..if they last 2 years I'll get more!
4*60 is offline Find More Posts by 4*60
Old Mar 09, 2011, 02:04 AM
chriscap is offline
Joined Jun 2010
I read the review of the poweredge batteries. I'm sure they're very nice, but they have extremely low "C" ratings. If that's the case, why are they $30. Usually you pay MORE for a higher C rating. Plus it's only 2 cells. If it's not going to harm my radio, I just assume buy a 20C.
A good guide :
more at
Alan T.
Old Mar 10, 2011, 06:50 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
Chris, the PowerEdge TX lipo's arae designed to be used in a TX where the draw off the battery is low. These cells can handle being fully charged for long periods of time in comparison a lipo for powering an aircraft. Regular lipos should not be used in a TX or in a RX application and left charged as they will deteriorate which causes the cells to increase in IR and generate heat. When heat is generated, this is what causes a puff.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Mar 10, 2011, 12:28 PM
hdtvtom is offline
Find More Posts by hdtvtom
Get up, Get the shot, Get back
hdtvtom's Avatar
Mill Valley Ca.
Joined May 2009
Chris,
I have a 20c, 2200 in my A9. It works great. In about a week of heavy use, it might go down to 80% of full. When it gets to 7v, in a month, start thinking about charging it. With a lipo, you'll always have some reserve power in there, too.
Picked up some Hitec tx conns. on Ebay for a buck apiece. I like
all-battery.com a lot. Good deals there, mine was 20 bucks.
T.
hdtvtom is offline Find More Posts by hdtvtom
Old Mar 10, 2011, 04:54 PM
chriscap is offline
Joined Jun 2010
Thanks for all the input
Discussion Source for a 2500mah 2S Lipo for the Aurora 9? blueviewlaguna Hitec/Multiplex USA 30 Nov 10, 2015 07:14 PM
Discussion connect lipo wrong and does not work aurora 9 navarro08 Hitec/Multiplex USA 2 May 11, 2011 08:56 AM
Sold Hitec Aurora 9 + RX + HPP-22 Programmer and Lipo rotaryguy Aircraft - General - Radio Equipment (FS/W) 4 Oct 24, 2010 10:36 PM
Off Site Aurora 9 Lipo battery 2500mAh supi7 Aircraft - General - Radio Equipment (FS/W) 0 Jul 20, 2010 11:50 PM
Discussion Aurora 9 - Telemetry Reading for Individual LIPO Cells WEREE Hitec/Multiplex USA 3 Jun 03, 2010 07:25 PM
