Old Aug 07, 2003, 08:33 PM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
First avalanche
Woo hoo ! ! ! !
Finally figured out the timing, and it worked out perfect.
Did it two more time to make sure it wasn't an accident .
My legs are still shaking, though.
I get like that every time a do a new maneuver.
Viper
Viper Pilot is offline Find More Posts by Viper Pilot
Old Aug 08, 2003, 02:45 AM
t_predator90 is offline
Find More Posts by t_predator90
-=Futaba RuLEz=-
t_predator90's Avatar
Netanya, Israel
Joined Sep 2002
So, how does one "avalanche"?
t_predator90 is offline Find More Posts by t_predator90
Old Aug 08, 2003, 09:17 AM
God is good
Banjul
Joined Jan 2001
t_,
An avalanche is a half-loop follwed by a snap-roll at the top.
The difficulty is trying to get the timing right at the top of the loop so that you exit the snap in the same direction you entered it.
Do a half-loop cutting power as you approach the top, and then bury both sticks to the lower left.
Viper
Old Aug 10, 2003, 01:47 AM
-=Futaba RuLEz=-
Netanya, Israel
Joined Sep 2002
Just tryed it in RF G2. Very cool! Thanx VP
Old Aug 10, 2003, 01:51 AM
SkyPyro is offline
Find More Posts by SkyPyro
Burnin' holes in the sky!
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
Now ya just gotta try it with snaps on the vertical upline, top, vertical downline and the recovery. There is always more to try,,,
Dan
SkyPyro is offline Find More Posts by SkyPyro
Old Sep 01, 2003, 04:40 PM
Alex W. is offline
Find More Posts by Alex W.
What crash???
Alex W.'s Avatar
Albuquerque, NM
Joined May 2003
yeah, avalanches are fun, but if you want a little more challenging (ok, alot) trick, try diamond loops. be straight and level, pull to a 45 upline, full roll, pull 90* to the inverted up at a 45 (if your plane is underpowered, this is where you will know it), pull 90 * to the 45 inverted downline, roll, pull 90* to the rightside up 45 down line, then when you are to the point that you started at, pull to straight and level. Pretty challenging the first few times, but if done correctly, it is one of the most beautifull precision aerobatic tricks.
Alex W. is offline Find More Posts by Alex W.
Old Sep 01, 2003, 07:28 PM
SkyPyro is offline
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
Want challenging, try a rolling loop! I can do that one, but it is pretty durned sloppy! With full aileron and alternating rudder and elevator, it really slows down near the top as well!
Dan
Old Sep 02, 2003, 12:19 PM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Mine are on the sloppy side as well, getting better thanks to AeroFly Pro though. That last downards section really sorts the boys from the men when flying in reality.
I saw Christophe Paysant Le Roux perform earlier in the year in dreadful conditions and he made it look so so easy, single roll, perfect circle finishing exactly where he started.
Dave
wildpalms is offline Find More Posts by wildpalms
Old Sep 02, 2003, 05:45 PM
SkyPyro is offline
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
Yah, makes ya sick at how good some people can be at that kind of stuff. I will hopefully get there someday.......
I agree on the last part of rolling loops, on a lot (but getting fewer.... probably only on 1/8 or so) I have bailed out and just pulled out normal. The top is hard too, mine end up looking like a giant egg
Dan
