Old Mar 08, 2011, 10:21 AM
vmcdonald is offline
Find More Posts by vmcdonald
United States, LA, Baton Rouge
Joined Feb 2011
Exceed RC Rocket 1490kv motor
I am looking at ordering the Rocket 1490kv motor, what amperage ESC does that motor require?
vmcdonald is offline Find More Posts by vmcdonald
Old Mar 14, 2011, 10:05 PM
theleetbeagle is offline
Find More Posts by theleetbeagle
Flying Shoe
theleetbeagle's Avatar
Ohio
Joined Nov 2010
HAHAHAH. Good luck.
www.headsuprc.com for full details on each motor he sells and if you email him, he will respond! You don't have to resort to chanting, sacrificial worship and off-site forum posts for answers.
theleetbeagle is offline Find More Posts by theleetbeagle
Old Mar 14, 2011, 10:50 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
What is your application? Are you running on 3s ? Which prop ?
Vien
vienquach is offline Find More Posts by vienquach
Old Mar 14, 2011, 11:42 PM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
I'm thinking the 40A on 3s should be big enough? 9x5 prop? maybe 10x5?
Just guessing.
http://www.hobbypartz.com/volcano-40...oller-esc.html
keyman923 is offline Find More Posts by keyman923
Old Mar 15, 2011, 10:00 AM
Joined Feb 2011
Running this on a 41" Yak 54 w/ a 10x7SF to start but I do have a couple of other props ie 10x5SF and a 10x4.5SF to test
Old Mar 15, 2011, 10:01 AM
Joined Feb 2011
oh yeah, a 3s 2200 mAh lipo to power everything
Old Mar 15, 2011, 10:36 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Are you flying aerobatic, 3D, or just flying around ? What is the motor weight ?
Old Mar 15, 2011, 01:58 PM
Joined Feb 2011
flying around w/ some mild aerobatic maneuvers. i'm too new to the sport for 3D flying but would like to do some easy stuff once i have the basics down. the motor weighs less than 100 grams, somewhere in the low 90's upper 80's i think
Old Mar 15, 2011, 02:47 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
To be honest. I guess you got the "wrong" motor kv for 3s power system. 1490kv is too high for 3s, unless you go with 9" or at most 10" prop (motor might got really hot) with the draw back of not having enough thrust. In this case, you'd need 40A esc. 3s 1800/2200 mah is good, and 9g servos.
If did it again, I'd choose a motor 75 - 90g, ~ 1050 - 1150 kv spinning APC 11 x 5.5 or 12 x 6, 40A ESC (30A works fine with sufficient cooling), 3s 1800 - 2200 mah. Perfect power setup for aerobatic and later 3D if you'd like to, IMO.
Vien
Old Mar 15, 2011, 03:48 PM
Joined Feb 2011
Thanks for the input, i have a 40A ESC for the motor. I'll have to see how it goes, according to the specs on the motor the max voltage is 11.1 volts
Old Mar 15, 2011, 05:44 PM
Joined Aug 2006
Are we talking this motor?
http://www.hobbypartz.com/86mb17-roc...08-1490kv.html
Get this instead
http://www.hobbypartz.com/86mb18-roc...08-1190kv.html
or probally a better choice
http://www.hobbypartz.com/86mb23-rocket-2814-840kv.html
or but the 840 kv is probally you
http://www.hobbypartz.com/86mb22-roc...14-1035kv.html
Are we talking this plane?
http://www3.towerhobbies.com/cgi-bin...&I=LXMUW7&P=FR
Like Vien said drop your KV down to around a 1000
Old Mar 15, 2011, 08:24 PM
Joined Feb 2011
Things are starting to make sense now i'm guess the lower the kv means a smaller prop so am i correct in saying that i would probably need to run a larger 12 or bigger) diameter prop so not to over rev the 1490 kv motor. and that's why a 3s will not provide enough power to swing that larger prop
Old Mar 15, 2011, 10:48 PM
Joined Aug 2006
The lower KV will allow you to swing a larger prop for more thrust less speed. I don't think the 1490 will swing a 11-7 or 12-6 without cooking itself on 3s
Old Mar 16, 2011, 12:34 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
That's true.
For the same prop and voltage, a lower kv motor draws less current. In other words, you choose a lower kv motor to spin a larger prop to get more thrust.
I believe your Yak 54 is either a 3D or aerobatic plane. 11" of prop should be good for that 41" Yak.
Your motor will likely cook with 3s and 11". Spend $20 and get another motor. Problem solved.
Old May 25, 2011, 07:59 PM
Joined Aug 2006
I know someone who bought 1 and what do you all think about the apc thin e 8x8 on 3S?
http://www3.towerhobbies.com/cgi-bin...1p?&I=LXHAP0&P
For Sale Exceed RC Mini 50MM 2.4Ghz MIG-15 High Performance Ducted Fan Jet w/ Brushless Motor/ Mikey 68 Aircraft - Electric - Jets (FS/W) 14 Mar 26, 2012 07:49 PM
Help! maxjet f117 exceed rc motor and esc zoalord 3D Foamies 4 Feb 27, 2011 12:30 AM
Discussion Exceed RC Optima Brushless Ducted Fan 70mm EDF Motor 2700KV makaveli956 Power Systems 2 Feb 02, 2011 07:32 PM
Discussion question Exceed RC Optima Brushless Ducted Fan 64mm EDF Motor 4900KV lowkeylaidback HobbyPartz.com 6 Jan 17, 2011 05:45 PM
Sold Exceed RC Alpha 370 brushless outrunner motor 150W - never flown anhtuanb Aircraft - Electric - Power Systems (FS/W) 5 Sep 24, 2010 04:36 PM
