Mar 08, 2011, 07:39 AM
South Wales U.K.
Joined Mar 2003
The easiest is probably to use an existing DC brushed (permanent magnet), motor. Then experiment on propeller size and different pitch angles to see what output can be achieved.
The two wire brushed motor can be from almost anything, toys etc.
The more powerful home-built wind generators use alternators, that would make it more complicated.
As a brushed motor output is not constant or regulated, you could always add a voltage regulator to control the output so that a LED wouldn't be overloaded. Or use a filament bulb instead. The filament will brighten with speed, until.........Hey!, who switched the light off...
