Old Mar 10, 2011, 05:04 AM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
Originally Posted by Twin-Stack View Post
Is this the place ?
Yes, 56, Boulevard de Strasbourg, this is the place indeed
I believe the were the only ones selling Rea. Or maybe Gems Suzor ("Le Tableau de Bord du Modélisme") in Auteuil had sold the 10 cm3 ignition Rea earlier ?
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Mar 10, 2011, 05:18 AM
Joined Jul 2003
Originally Posted by Gluehand View Post
...An early, pre-"V-Series" Super Tigre G21/35, of .35 cu.in. (1956-1959)
Note the upright intake stub and the shallow head fins.
I don't know what the "56" indicates...not the displacement though, as a measure confirms it's a .35.
A nice old stunt engine, featuring a baffled piston with 2 rings.
It must be the G21/35 of this list, predecessor to the G21/35V. Now, what is the 56 about? Maybe the year ???
Is it plain bearing as the list says, or ball-bearing?
Old Mar 10, 2011, 07:00 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
TwinStack,
About your first post. You'll need to make a new piston for it and a connecting rod as well. You can send the piston and cylinder to Frank Bowman and he can make a ring for it, if you don't want to make the ring yourself. You might get lucky and find a more modern engine's piston and or connecting rod that fits too. I would go for the regular gudgeon pin type of rod and piston myself instead of the ball and socket type.
That would be pretty neat to see it running again.
earlwb is offline Find More Posts by earlwb
Old Mar 10, 2011, 07:44 AM
flybaby55 is offline
Find More Posts by flybaby55
cleveland ohio
Joined Mar 2008
Mamiya .15
A Mamiya .15 that my father picked up in Japan in the late 50's
flybaby55 is offline Find More Posts by flybaby55
Old Mar 10, 2011, 07:57 AM
cleveland ohio
Joined Mar 2008
Super Tigre G20 .19V
An old Super Tigre .19 still new in the box,they were a little pricey back in the 50's at $14.95 but we had a lotta fun with them on Flitestreak's. Also a Como 51 that i want to convert to c/l,they had good power back in the day and they were cheap.
Old Mar 10, 2011, 09:11 AM
Mike1484 is offline
Find More Posts by Mike1484
Elyria, Ohio
Joined Sep 2004
Glue hand ,
Maybe the "56" is a 5.6cc on your Tigre .35.
Mike 1484
Mike1484 is offline Find More Posts by Mike1484
Old Mar 10, 2011, 09:26 AM
danny.act is offline
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
België, Vlaams Gewest, Putte
Joined Jun 2004
K&B .40S 'Lee Custom' Formula 1 Pylon race engines
K/B .40'S' Formula 1 pylon race engines:
The one in front is a pre-production model #5 of 6 pre-production engines made.'Lee Custom'.
The second one is a production series .40S
danny.act is offline Find More Posts by danny.act
Old Mar 10, 2011, 11:29 AM
Gluehand is offline
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
My example has twin ball bearings, contrary to the info...
That makes sense to me...you may be right there...
Here's another one, full of character....a Czech made Tono .35
Gluehand is offline Find More Posts by Gluehand
Old Mar 10, 2011, 11:35 AM
ZEROSKIN76 is offline
Find More Posts by ZEROSKIN76
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
ill be getting out the camera damn i wish this thread was here before i sold some of em off!
the sidewinder is an amazing looking engine
did it proform well and was it geared down?
ZEROSKIN76 is offline Find More Posts by ZEROSKIN76
Old Mar 10, 2011, 11:54 AM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The one on the left looks like a French Rea 5 cm3.
The glow-plug looks like an original SDI from the famous hobby shop "A la Source des Inventions", now gone. It was the French equivalent of the famous British "308" run by Henry Nichols.
Was in "La source des inventions" last in 1991,had my first "Kivao" HL glider build from their balsa at school and it started me on modelingOne of my friend in the early 60's was living near Gem Suzor store in Auteuil but we were too intimidated to visit! Back then we were flying at Bagatelle just like Santos-Dumont many years earlier!
coriolan is offline Find More Posts by coriolan
Old Mar 10, 2011, 11:58 AM
hastf1b is offline
Find More Posts by hastf1b
F1B is ok.
Monheim am Rhein Germany
Joined Jul 2008
Another nice Glo-engine.
Heinz
hastf1b is offline Find More Posts by hastf1b
Old Mar 10, 2011, 01:09 PM
Joined Jul 2003
I bought model material and engines from "La Source" as we called it. I remember buying a ready-to-fly controliner made of (ABS?) plastic and powered with a Dynamic 1,5 cm3, in the late 50's. I never visited the Gem Suzor shop either. Why ? I don't really know. Never flew at Bagatelle, but did fly at Vincennes.
Old Mar 10, 2011, 01:36 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
this guy looks like he could beat up a babe bee any day
Heinz
Old Mar 10, 2011, 03:33 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Some info about the Holland Hornets.
Both the Fox 049 FAI Special and the Hornets in 049 or 051 configuration were comparable-but in the case of the Hornets it was the works tuned versions that performed. The 049 FAI special was virtually a completely different engine from the standard Fox 049, and IIRC the only parts that were common were the backplate and NVA. The case, shaft, piston and liner were all significantly altered in the 049 FAI compared with the std.
The Fox peaked at about 19,000-a bit lower than the TD, whereas IIRC the Hornets peaked a little higher than the TD. The Hornet only had a aluminium rod-which let go if over-revved..........
The Fox as we all should know is still available-ditto parts-and limited parts for the Hornet are available thru MECOA. The heads are the problem-Doug Galbreath does an option with a turned down Cox head (converted into an insert, and using the Hornet head as a hold down ring)-but these too are now a dwindling resource. I have experience with the Fox and it is a nice handling engine-which performs well on a 6x3. The suppliers warn about going over 40% nitro-which will blow heads.
'ffkiwi'
ref: http://www.rcuniverse.com/forum/m_72...tm.htm#7273340
Old Mar 10, 2011, 04:10 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
I'm not a glow engine user or collector but I find this thread very entertaining. Thanks for posting all these great photos guys!
Mr. Wiz is offline Find More Posts by Mr. Wiz
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
