Old Mar 16, 2013, 07:46 PM
Twin Stack is offline
Find More Posts by Twin Stack
Joined Feb 2013
......And the winner of this years "British Understatement of The Year" is.........
Frog 500 Model Aero Engine incomplete
Twin Stack is offline Find More Posts by Twin Stack
Old Mar 16, 2013, 07:54 PM
Joined Feb 2013
Perhaps krafty could give us his thoughts on this one ?
"...a small 1.5cc four stroke aero engine designed to run on methanol & castor oil mix ie glow fuel. It was built by my Father in 1960.....it used to be flown in a free flight model, dimensions are width across engine bearers 33mm height from engine bearers 44mm and length from rear of carb to prop driver 68mm"
http://www.ebay.co.uk/itm/home-made-...item5aef3fc74d
Old Mar 16, 2013, 08:03 PM
Joined Feb 2013
Very nice old Enya 60 6-bolt with original factory "carb" - circa late '50's, very early 1960's. The "muffler" is actually just a duct, but also factory original. Rare marine version last 2 photo's
Old Mar 16, 2013, 08:17 PM
Joined Feb 2013
This one would definitely be the oldest engine we have ever seen......
"........this one was built by my Father in 1088......"
Old Mar 16, 2013, 09:13 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
His father lived a very long time........................ From ebay:
http://www.ebay.co.uk/itm/home-made-...item5aef3fe65a
[Here i have for auction a home made four stroke aero engine of 12.5cc it is very similar to a laser 75 this one was built by my Father in 1088 and has not run for some years now built to a very hight standard and produces more power than a laser 75 1000rpm more and is a bit lighter comes with silencer but need ba screws to fit 8ba i think not sure comes with 14in prop as well please feel free to ask any questions and ill get right back to you and do look at my other items for auction]
Here i have for auction with a starting price a small 1.5cc four stroke aero engine designed to run on methanol castor oil mix ie glow fuel it was built by my Father in 1960 and has not run for some years now it is in bery good condition and is built to a very high standard it used to be flown in a free flight model dimensions are width across engine bearers 33mm height from engine bearers 44mm and lenght from rear of carb to prop driver 68mm please feel free to ask any questions and ill get right back to you and do look at my other items
coriolan is offline Find More Posts by coriolan
Old Mar 16, 2013, 09:26 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Half Laser the other half Enya.
Bill
williame3590 is offline Find More Posts by williame3590
Old Mar 16, 2013, 09:35 PM
Frog 50 is offline
Find More Posts by Frog 50
United Kingdom, London
Joined Apr 2012
Hi,
Do you know where I can get one of the exaust ducts? The one on my ENYA 60 is missing.
Thank you.
Frog 50 is offline Find More Posts by Frog 50
Old Mar 16, 2013, 10:18 PM
Joined Feb 2013
Originally Posted by Frog 50 View Post
Hi,
Thank you.
Sorry, I can't help - I only have the one NIB 60 myself. Like flexi needles and tanks on Frog 500's, they were the first things discarded
Old Mar 17, 2013, 12:11 AM
Joined Feb 2013
Confused by the fact that this OS has 15 D written on the side, and comes in a Max 15 Diesel box ? However, it is the genuine glow version (note the head with the offset plug) even though both engines share the same basic crankcase. Its official title is the OS Max-D 15 Racing Glow, dates from 1961 and is now, I would think, very much rarer than its Diesel sibling (which was a bit of a flop, but collectors don't care) Chinn's test here
(http://sceptreflight.net/Model%20Eng...15%20Glow.html) It's thought that these were never made available to the public, but were handed out by the OS Factory to top F/F flyers of the day. Presumably hand-made, very few exist (supposedly, only 28 were manufactured). The top engine appears to have the 4 digit Serial # of 1008 whilst the lower ones are # 106 and # 104
The genuine Diesel Max-D on the bottom row for comparison - note that it has the word DIESEL spelt in vertical letters between the exhaust stack & lug
Old Mar 17, 2013, 12:25 AM
Joined Feb 2013
WEBRA 1.8cc GLOW ENGINE FOR MODEL BOAT USE. ENGINE HAS 2 : 1 REDUCTION GEAR WHICH ALLOWS THE ENGINE TO DEVELOP MORE TORQUE TO TURN A BIGGER PROP.
Last photo on top row description -
This is a vintage custom built Russian MATAS - 2.5 cc geared glow engine, it was specially modified from an original Russian MATAS engine for fast nitro RC boat F1-V3.5 NAVIGA competition class. Only one engine in this configuration was made. Donor engine was manufactured in USSR in 1980. Serial number is 381 (only about 500 of these engines were manufactured). Bottom row of photo's show a standard air-cooled aircraft MATAS
Old Mar 17, 2013, 03:17 AM
Gluehand is online now
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Browsing old catalogues, it seems to have been sold as late as 1964-65....here, as a standard part of the marine version.
Gluehand is online now Find More Posts by Gluehand
Old Mar 17, 2013, 04:27 AM
Joined Feb 2013
Bosse, correct ! That old 60 was sold pretty much right up to the time that the Enya 60-II Model 7032 appeared in 1965
Old Mar 17, 2013, 05:49 PM
Joined Feb 2013
" Profi 0.49 Combat Glow engine. This unit is one of the first series of these engines and was produced (I believe) somewhere in the 2006 - 2008 timeframe. This engine has an identical mounting pattern to the Cyclon 0.49 and features an AAC piston/liner assembly and uses Nelson glow plugs. The unit is very highly timed and will respond best to props with no more than 3" of pitch (2.5" may well be better). Please note a pressure fitting (Super Tigre) has been mounted in the back plate "
Old Mar 17, 2013, 05:56 PM
Joined Feb 2013
Would you believe it ! Just when we thought we had found the oldest engine (shown above, 1088) known to Man, along comes an even older one (by 22 years). Incredible !
http://modelenginenews.org/ad/conq_1066.html
Old Mar 17, 2013, 06:26 PM
Gluehand's Avatar
Joined Sep 2008
I can see their smiles when they - finally - found a use for The Holy Glowdriver...
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
