Old Feb 17, 2013, 02:42 AM
kakariki is offline
Find More Posts by kakariki
Newbee
Mornington Vic
Joined Mar 2010
Rebuilds
Originally Posted by Reginald View Post
Guys, to give you some idea of the "rebuilts" I do get in at times, how about this FS80 ? Good thing I do have this new casting looking for a good home....
Here is one I got, a Saito FA-90T twin R/H cylinder repaired with solder.
If anyone has one I'll be happy to buy it, the engine is near new.
kakariki is offline Find More Posts by kakariki
Old Feb 17, 2013, 02:55 AM
Twin Stack is online now
Find More Posts by Twin Stack
Joined Feb 2013
There's not that much work in making a model engine, is there ?
Yeah, right !
(this is just page 3)
http://www.model-engineer.co.uk/foru...p?th=70308&p=3
Twin Stack is online now Find More Posts by Twin Stack
Old Feb 17, 2013, 04:02 PM
G WILLIE is offline
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
Model Engine Gallery Page 14
The Charlie Tomalesky Gallery Page
Some time back a beautiful drawing of one of the old engines showed up on here and people wondered were it came from. If you look at Ron's Engine page, page 14 of the gallery, you'll find Charlie Tomalesky did the beautiful rendering. http://www.modelenginenews.org/
G WILLIE is offline Find More Posts by G WILLIE
Old Feb 17, 2013, 04:21 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
http://modelenginenews.org/gallery/p14.html
coriolan is offline Find More Posts by coriolan
Old Feb 17, 2013, 06:36 PM
Joined Feb 2013
Diesel engine : Displacement: 2.47 cc
Bore: 15 mm
Stroke: 14 mm
Weight: 165 g
Induction : rear rotary valve
Origin: Believed to have been developed and manufactured (circa 1985) for F2C by two experienced (German ?) Team Race modellers. The carburetor is missing because in Team Racing a special design is used.
Glow engine : Displacement 4.84 cc
Bore: 19 mm
Stroke: 17 mm
Weight: 237 g
Old Feb 17, 2013, 06:48 PM
kakariki is offline
Newbee
Mornington Vic
Joined Mar 2010
Some identity help please
Hi All
I just recieved these as an unidentified vintage engine lot and have no idea what they are, all glo and the one on the right has a tiny glo plug, any ideas would be appreciated.
Thanks Barry
Old Feb 17, 2013, 06:55 PM
Joined Feb 2013
Originally Posted by kakariki View Post
Hi All
Thanks Barry
Barry, the two smaller ones have to be related to those shown in Post # 5856 !
What intrigues me more than anything else, is the fact that some of them appear to have the glow element built into the head, in a similar fashion to the 1948 H & H 45. More info please !
Old Feb 17, 2013, 08:01 PM
Joined Feb 2013
First came the dual needle valve idea (see bottom row, a rare FOX 29 Stunt from 1954), alternating between a fixed high & low speed. In between that crude system and the first simple throttles, came the rotating exhaust valve as typified here by the 1957 FOX box art. The rotating rod had a "waisted" or flat machined section in the middle.
Old Feb 17, 2013, 08:18 PM
kakariki is offline
Newbee
Mornington Vic
Joined Mar 2010
re
My R/H one seems the same as the R/H one in post #5856 and has a built in glo plug, the other two have normal removable glo plugs. I looked up the H & H 45 and they are close except the H & H doesn't have webs on the crankcase coming down to the beam mounts. I don't know what else I can tell you, there is nothing on the engines whatsoever apart from me checking the capacity.
Barry
Old Feb 17, 2013, 08:29 PM
Steve_P. is offline
Find More Posts by Steve_P.
Newby Retiree
United States, NM, Las Cruces
Joined Dec 2011
In Twin-Stack's pics of the Fox .35 RC, its interesting to note the off-center glow plug location in the Fox .35 head.
Steve_P. is offline Find More Posts by Steve_P.
Old Feb 17, 2013, 08:55 PM
kakariki is offline
Newbee
Mornington Vic
Joined Mar 2010
Further info
Barry
The large L/H is 24.24 X 23.22 10.71cc .65ci
The middle is 16.70 X 18.36 4.02cc .24ci
The R/H is 16.73 X 22.00 4.8cc .29ci
The middle one has a prop drive with an adaptor to suit a boat prop shaft as well and the two smaller ones are very similar in construction, they also all came from the USA.
Old Feb 17, 2013, 09:04 PM
Joined Feb 2013
Steve, that head was a special one-off, just for that engine. Some came in the specially marked pink / black / white box above - others in the standard 35 Stunt box as shown below.......
engine test here -
http://sceptreflight.net/Model%20Eng...%20&%20RC.html
Old Feb 18, 2013, 12:52 AM
Joined Feb 2013
And for anyone wanting to have their very own FOX 35 R/C Special, there's one here - http://www.ebay.com/itm/Vintage-Earl...item4850e91b64
Old Feb 18, 2013, 01:23 AM
50+AirYears is offline
Find More Posts by 50+AirYears
United States, SC, Irmo
Joined Jul 2004
I had one of those Fox .19 RC Specials around 1964. In fact, it was my first RC engine. I could only get my escapement and linkage to work erratically, but the engine seemed to have a very reliable idle. Didn't have a tach in those days, but I was guessing about 13000 full speed and maybe 2500 tp 3000 on a 9-4 prop. It would idle for a full 4 ounce tanik, and then if I could catch the quick blip, almost immediately spring to full throttle without hesitation.
50+AirYears is offline Find More Posts by 50+AirYears
Old Feb 18, 2013, 07:19 AM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hello !
Do you know if the F2C engine is from east germany ?
Some Parts look like a heavy Modified BWF.
Is it possible to show the engine assembled without the head ? when the liner ends at the top of the piston in upper position, that could be a clue.
I know the designer of the BWF personally, so i would ask him if he knows anything about this engine.
Regards !
flyinglog is offline Find More Posts by flyinglog
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 03:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 02:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 07:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 08:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 11:42 AM
