Old Feb 05, 2013, 08:48 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
The alkaline solution is called Crystal Clear. You can leave any metal submerged indefinately with no ill affects. Also heat can be used at any tempreture and it will not darken or discolour the aluminum.
Bill
williame3590 is offline Find More Posts by williame3590
Old Feb 07, 2013, 01:02 PM
quietflyer is offline
Find More Posts by quietflyer
B.C.,Canada
Joined Jan 2003
Thank you for the lead on the Crystal Clear solution and the SharperTek U-Sonics.
quietflyer is offline Find More Posts by quietflyer
Old Feb 07, 2013, 01:41 PM
B.C.,Canada
Joined Jan 2003
Originally Posted by Frank Klenk View Post
My first usonic cleaner had no heater, the next one I bought did, and it is worth the money. I find the warmer the better. Using cleaner fluids even dishwashing liquid will harm aluminum if it gets hot enough. The problem is sodium hydroxide. Stuff like oven cleaner has it and will turn aluminum black. I use a product called Crystal Clear, available here in Ontario. For those really grimy baked on castor crud engines I just turn up the heat. Usually I run it at 110F, tough stains I go to 140F and let it soak for a while and then turn it on. Also get as big a cleaner as your budget will allow. I have the 12 liter tank. I can float a separate sealed dish on the surface with a caustic to clean brass and with a lid it does not pollute the original mix. Just my experiences.
Thanks for your input, Frank. Your advice based on your experiences is much appreciated. Do you use a Sharpertek unit or some other brand? I apologize for drifting off topic a little.
Min
Old Feb 07, 2013, 01:43 PM
B.C.,Canada
Joined Jan 2003
One more question, do ultrasonics affect anodising? Thanks.
Min
Old Feb 07, 2013, 02:33 PM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Min
There is ONE exeption, the black anodising on OS twins ! Gone in one minute.
Reginald is online now Find More Posts by Reginald
Old Feb 07, 2013, 02:55 PM
kakariki is offline
Find More Posts by kakariki
Newbee
Mornington Vic
Joined Mar 2010
re
That black anodising on OS twins seems to come off with anything you put on it, must be some strange process they use and it isn't very good
Barry
kakariki is offline Find More Posts by kakariki
Old Feb 07, 2013, 06:41 PM
Joined Aug 2007
The ultransonic used with this cleaner will strip paint and anodizing clean off.
Bill
Old Feb 07, 2013, 07:44 PM
Frank Klenk is offline
Find More Posts by Frank Klenk
Ontario, Canada
Joined Jan 2004
Min
No problem Min. A bit off topic but a good thing to discuss. I use a Pro Sonik, DSA200-SK2-12L. I found the seller on the bay, beyondsales2007 and I notice he has not sold for quite a while. However he does have a store in New Market Ontario. He sells all types of cleaners and the office staff is great to deal with. The store is called Crystal Electronics. I can pm you contact info if you need it.
I agree with a big YES that usonic will rip the anodize color off in a heart beat. You can soak it in the heated cleaner and after I just clean with a tooth brush.
Frank Klenk is offline Find More Posts by Frank Klenk
Old Feb 08, 2013, 07:42 PM
G WILLIE is offline
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
Frank, Where is my newsletter??
G WILLIE is offline Find More Posts by G WILLIE
Old Feb 09, 2013, 01:49 PM
Reginald's Avatar
Belgium
Joined Aug 2004
Not all kinds of anodising.
Old Feb 10, 2013, 09:25 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"That black anodising on OS twins seems to come off with anything you put on it, must be some strange process they use and it isn't very good"
Has anyone confirmed that it is anodizing, and not just a chem film of some sort????
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Feb 11, 2013, 08:35 PM
Ontario, Canada
Joined Jan 2004
I sent you an email ... LOL.
Old Feb 14, 2013, 06:21 PM
Twin Stack is offline
Find More Posts by Twin Stack
Joined Feb 2013
"This is a Viper Four Cylinder prototype engine. This engine is strictly a prototype that was made with 20 other prototypes to determine the best design. This engine is complete with the exception of two pistons and an incomplete crankshaft. It does turn over like a normal engine. If the buyer is a machinist and wishes to complete the engine I will send him the missing parts (two pistons and the crankshaft parts.) This can be made into a running engine; however, the crankshaft is a patented item, therefore it is protected and cannot be reproduced for sale."
(on German eBay)
Twin Stack is offline Find More Posts by Twin Stack
Old Feb 14, 2013, 06:28 PM
stg61abc is offline
Find More Posts by stg61abc
Joined Oct 2007
Hi Bob, its very nice to see you again here.
Be welcome mate
stg61abc is offline Find More Posts by stg61abc
Old Feb 14, 2013, 07:41 PM
Joined Feb 2013
Here, from 1957, is Gordon Burford's rendition of an old favorite - the 3 bolt backplate FOX Stunt, otherwise known as a Series 1 Glo-Chief 29. Look closely at the rear view - see that small casting protrusion on the main case, halfway along the top of the backplate (just next to the red paint) ? Ivor F described it as a "jib-sail" or "spinnaker" shape, and yes, it does look a bit like a sailboat's, er sail. Apparently, when working on the original casting die, Gordon's grinder broke through at that spot into a porosity "air bubble". GB just cleaned it up the best he could, and went on to produce 250 engines from this "fingerprinted" die. Last photo shows the 35 size of this "FOX" Glo Chief........
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
