Old Dec 07, 2012, 09:55 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Originally Posted by Reginald View Post
The OS H-60 RC dates from 1967
I was rather curious myself so I quickly dismantled the engine and here are some pictures. Still very oily but no real visible dirt ! The previous owner did take care of his engines. Bronze conrods. One has to look really well but in the last picture you can see a hair-size line, that is where both parts of the rod do join at the bottom, a very unusual method. Very well made indeed. And very precise fittings all over, no sloppy fits anywhere. I was told that the builder was a precision-fitter at Republic and it shows.
Reginald is offline Find More Posts by Reginald
Old Dec 07, 2012, 01:23 PM
brokenenglish is offline
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Thanks Reggie, Super!
Obviously, the rods can't be on the same crank-pin (I had a "senior moment"!).
brokenenglish is offline Find More Posts by brokenenglish
Old Dec 07, 2012, 01:56 PM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Yes. And pretty difficult to make a crank this way. Has to be very hard steel to avoid "bending". Typical failures (to me) are fe the FMO twin or the Craftsman twin. The Hiness twin as well. Did have those engines. Wonder how he did those conrods however.
Old Dec 07, 2012, 05:51 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I did also forgot about the crankcase compression .
olmod is offline Find More Posts by olmod
Old Dec 08, 2012, 10:58 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
OS Max 60-H
Fiddling with this twin reminded me of the fact I am still in need for a Max 60-H
piston, have a near-new Blackhead lying about without piston. Will pay a good price for one and may be used, ring is no problem.
Old Dec 13, 2012, 07:26 PM
apilgrim is offline
Find More Posts by apilgrim
Canada, AB, Calgary
Joined Apr 2006
Saito FA 30 4-stroke MKI & MKII
Are there any other difference between MK I & MK II, aside from the rocker arm, MK I Cast alum, MK II machined steel?. Why did they changed to steel rocker arm?
The cast rocker arm seems more appealing to look at. Any info or comments much appreciated.
apilgrim is offline Find More Posts by apilgrim
Old Dec 13, 2012, 09:06 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Mathe
Don't think I posted this one, it's a brute. 25cc made in Italy about 79 or 80.
I would have to go and look again but this has a very low serial # and not mant were made.
This company has been in business since and specializing in high performance boat engines.
williame3590 is offline Find More Posts by williame3590
Old Dec 13, 2012, 11:37 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Mathe engines are still very popular in Europe for the offshore racing class and large scale cars. Here is a bit of their history:
http://www.matheengines.com/history.htm
The airplane versions are less often seen! Here is some boat action
Modified Gas Boat Racing on the Fore Shore Trinidad! (0 min 38 sec)
coriolan is online now Find More Posts by coriolan
Old Dec 14, 2012, 12:41 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Just think : what is more delicate and prone to break ? Those high positionned alu rockers or the much lower compact steel ones ?
Old Dec 14, 2012, 09:14 AM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
My G46 not the much more common ST46 built on the same G21 case as the .29/35.
Will go in a 1050sq in Kerswap
RyanNX211 is offline Find More Posts by RyanNX211
Old Dec 14, 2012, 10:49 AM
apilgrim is offline
Canada, AB, Calgary
Joined Apr 2006
SAITO FA-30 rocker arm
Thanks for your input
Old Dec 16, 2012, 03:41 PM
stg61abc is offline
Find More Posts by stg61abc
Joined Oct 2007
Hello to all.
Does anyone have an engine review on the Enya 09 IV?
Thanks in advance
Carlo
stg61abc is offline Find More Posts by stg61abc
Old Dec 18, 2012, 08:48 PM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Irvine 61RLS
I managed to pick up a NIB Irvine 61RLS off the bay and it arrived yesterday. Now I have the big brother to my 40RLS .
Looking at the parts list it's obvious the RLS is quite different to the standard 61R in much the same way my 40RLS is different to the 40R by using a mix 'n match from other engines. The RLS uses the crankcase from the 61R but the head, piston/liner, wrist pin and gasket set are peculiar to the RLS. The con rod, crankshaft and wrist pin circlips all come from the Irvine 72. Sometime soon I'll be stripping it down to take some measurements to compare with my (also new) Dykes ringed Irvine 61R which is on the left in the photo.
downunder is online now Find More Posts by downunder
Old Dec 19, 2012, 02:35 AM
Joined Nov 2011
Originally Posted by stg61abc View Post
Hello to all.
Thanks in advance
Carlo
Carlo, the model with RC carb (Enya 19-IV TV) was tested by Peter Chinn in A/M January 1969.
Would that be of interest? I can scan it, no problem.
Old Dec 19, 2012, 04:40 PM
stg61abc is offline
Joined Oct 2007
Thanks so much matey. In fact Im looking for the review on th Enya 09 IV
Thanks by your kindness
Carlo
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
