Old Oct 02, 2012, 09:41 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
HYPE r/c
Originally Posted by Twin-Stack View Post
A very attractive looking engine that I don't believe we've seen on here before, the HYPE 69. Now, I originally thought that these were Chinese made, but it seems they may have been made by Kyosho in Japan. Does anyone know anything about them ? They only seem to appear on eBay Germany.
HYPE is a German hobby company which used to market this engines( a cheaper alternative to OS). They now sell only electric planes,cars and boats!
http://www.microsofttranslator.com/B...-Coolfire.html
http://www.hype-rc.de/eng/shop/index.html
coriolan is online now Find More Posts by coriolan
Old Oct 02, 2012, 10:18 PM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
Brilliant, thank you !
Twin-Stack is offline Find More Posts by Twin-Stack
Old Oct 02, 2012, 10:32 PM
Closed Account
Joined Nov 2009
"LASER 300v S FOUR STROKE MODEL AIRCRAFT ENGINE. THIS IS THE NEWEST LIGHTWEIGHT VERSION OF THE LASER 300v THAT HAS ONLY JUST GONE INTO PRODUCTION."
Old Oct 03, 2012, 12:53 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Reggy, have emailed a request for more information to the seller.....
http://www.ebay.co.uk/itm/Stebro-Mer...item337c911766
My guess : a contraction of Steven and Brown ?
Reginald is offline Find More Posts by Reginald
Old Oct 03, 2012, 03:25 AM
Closed Account
Joined Nov 2009
A new one on me, the LST - all the way from Lithuania !
http://www.ebay.de/itm/LST-Motors-Sp...item3a7a6423e6
Old Oct 03, 2012, 01:08 PM
PantherEngines is offline
Find More Posts by PantherEngines
Haenertsburg, South Africa
Joined Nov 2008
There has to be a reason that the majority of entries in the world scale champs use Laser engines! Superb.
PantherEngines is offline Find More Posts by PantherEngines
Old Oct 03, 2012, 03:56 PM
Closed Account
Joined Nov 2009
The shy and retiring FROG 80 glow, with its much more common Diesel sibling
Old Oct 03, 2012, 08:47 PM
Closed Account
Joined Nov 2009
Thanks to Charlie Stone !
"From the TARMAC archives, here are 3 views of a 14.2 cc engine built here in WA in 1952 by Graham Ockleshaw for use in a tether hyroplane. Some details and a drawing were published in Model Engineer magazine by the designer, a Mr. George Lines (AKA Meridian). This engine has a lapped piston (no rings), rear rotary disc induction, and a twin ball race supported crankshaft. It also has several unusual features. A composite piston made of cast iron with a rivetted in light alloy little end yoke and the glow plug screws into a contra piston that can be moved to vary the compression ratio. That is controlled by the upper cooling fins which screw on to a threaded section at the top of the cylinder liner. Graham produced his own castings for the crankcase and even made the glow plug himself because the commercially available ones (like KLG) didn’t seem to be able to stand up to the stresses of this engine. The engine is very strong and since the method of launching the boat which was fitted with a `surface’ propeller was to throw it across the top of the water (not always perfectly), it has been submerged below the waves several times while screaming at full revs without any damage at all."
Old Oct 05, 2012, 12:12 AM
Closed Account
Joined Nov 2009
More FROG's.....
"A FROG "VENOM" 049 / .8cc GLOW MODEL ENGINE, SERIAL # W 308. THE FROG "VENOM 049" WAS ACTUALLY BUILT FOR A.A. HALES BY DAVIES-CHARLTON Ltd. AND WAS LATER RE-BRANDED AS THE D.C "WASP".
Old Oct 05, 2012, 12:16 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Cox
I do need a new black plastic front case for a Cox like this, only, I always get confused if this is the O9 version or the 049 one ? What is this one ?
Old Oct 05, 2012, 01:34 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
That looks like the 09, based on the pictures on here:
http://www.mh-aerotools.de/airfoils/cox_frameset.htm
Going by proportions alone it is hard to tell, but there is an extra groove around the base of the cylinder on the 09 in the picture and on yours.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 05, 2012, 01:44 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Pat MacKenzie
Yes I did look up that site. Xenalook does have black housings for sale, they say that the O49 and the 051 are the same. So is the 09 different ? Thank you anyway.
Old Oct 05, 2012, 05:09 AM
pmackenzie's Avatar
Joined Dec 2002
051 has a bigger piston bore, all other parts are the same as the 049.
09 is a bigger motor , no common parts with the 049
Old Oct 05, 2012, 05:10 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
OK thank you for the information
Old Oct 06, 2012, 12:22 AM
Closed Account
Joined Nov 2009
"Micromeccanica Saturno Super-Tigre G 20 2.5 glow, square exhaust stack from year 1950. Original front washer rare in this new condition. Original needle with its cadmium plating. Free-Flight 6 mm white bakelite venturi insert. The engine has a clear matte finish. The glow plug is one of the first produced by Garofali, but I am not sure if it was sold with this engine. Piston with two rings ; one ball bearing at rear of shaft with plain front bearing. This engine is the first 2.5 cc and the first model of G 20 built by Garofali. See Reference Book of James Dunkin, page 113, # 91".
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
