Joined Nov 2009
This is interesting - I've not seen one before...
http://www.ebay.com/itm/WEBRA-SPEEDY...item53ec80adff |
Joined Nov 2009
Rarely seen in the original box -
http://www.ebay.com/itm/VINTAGE-HOPE...item4ab6583e7b Info at : http://modelenginenews.org/ad/hope_p2.html (both engines below appear to have non-standard NVA's, the one with the red tank also being set up for use in a model car) |
Joined Nov 2009
Name this Mystery Engine Part and what its off....
(This is the backplate & venturi tube from the R/C version of the early 1960's ENYA 06. The round bit with the piece of wire through it operates the internal butterfly valve - the NVA is situated between it and the backplate, but the spraybar hole is at 90 deg. to the valve shaft) |
Joined Nov 2009
Looks like two identical OS's doesn't it ? In 1964, the OS factory released the new Max H 35 Combat engine to take over from the Max III 35, which was getting too hot for stunt (replaced in 1963/64 of course, by the much milder running Max S35) and then again in 1965, they released the detuned Max H 35 aimed at general sport & R/C flyers. Both engines have a bronze bush main bearing with a single rear ball race and display beautiful workmanship, but look at the difference in the size of the venturi's ! The date (year) stamped under the lugs of these two is 65 for the Combat, and 66 for the standard H. Note the tiny letter "C" stamped under the numbers "35".
| Thread Tools | |
| Discussion Vintage Engines being run video | earlwb | Engines | 37 | Apr 01, 2013 02:48 PM |
| For Sale Multiple glow engines | Greyout | Aircraft - Fuel - Engines and Accessories (FS/W) | 12 | Oct 03, 2012 01:13 PM |
| For Sale Vintage glow engines for sale very cheap | TheEdge | Aircraft - Fuel - Engines and Accessories (FS/W) | 19 | Jan 18, 2011 06:37 PM |
| Question rc glow engines | startup1 | Beginner Training Area (Fuel) | 6 | Nov 04, 2010 07:53 PM |
| For Sale four glow engines | thriller | Aircraft - Fuel - Engines and Accessories (FS/W) | 5 | Sep 25, 2010 10:42 AM |
