Old Mar 08, 2011, 06:02 PM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
Originally Posted by danny.act View Post
Clarence F. Lee "SIDEWINDER"
Now this is an interesting engine ! I think I read about it once in an American modelling magazine, but have never seen such beautiful photo's of the actual engine ! If memory serves me, it was designed to allow a more streamlined, less draggy frontal area on a model, a similar concept that spawned the original FOX 59 and the British AMCO 3.5 (incidentally, the "long shaft" version of the latter only has a longer prop driver,than the "short shaft" model). Does this engine have reduction gears built in,or is it 1 : 1 ? Whatever, being built by the Master it would be a priceless work of art ! Possibly a one off ? BOB
Twin-Stack is offline Find More Posts by Twin-Stack
Old Mar 08, 2011, 06:20 PM
Closed Account
Joined Nov 2009
Here's something you don't see every day - the starting technique is particularly interesting !
Old Mar 08, 2011, 06:24 PM
danny.act is offline
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
BelgiŽ, Vlaams Gewest, Putte
Joined Jun 2004
Hi Bob,
Thanks, The Sidewinder on the photo's is #2 of only 3 made, #1 is still in Clarence Lee's collection. It has a bore of .750" and stroke of .724". The total displacement is .31985cu.in.
Piston has been machined from Mehanite cast iron and sleeve from Ledloy steel. Due to the miter gears the crankshaft turns clockwise. It's 1:1.
Regards,
Danny.
danny.act is offline Find More Posts by danny.act
Old Mar 08, 2011, 06:34 PM
Closed Account
Joined Nov 2009
Danny, the most pleasing aspect (for me at least) is the fact that you are an un-ashamed engine collector like myself. On most other forums, collectors are treated like lepers or second class citizens (eg. that stunt forum named after a German dive bomber). Collectors rise up ! Throw off your shackles - you are liberated ! In the meantime Danny - would you take 200 bucks for that Sidewinder ?
Old Mar 08, 2011, 06:45 PM
danny.act's Avatar
Joined Jun 2004
Bob,
Good to hear You are a collector to, seems You are having a whole lot of information on engines, that's great ! I just thought it's time to show some of our engines however, just to say un-ashamed collector would be just a step to far
Don't want to take advance of Your goodness Bob $200 would be over the edge
Regards,
Danny
Old Mar 08, 2011, 06:57 PM
Closed Account
Joined Nov 2009
Do you have a mid-fifties ENYA 29 with the "airfoil" exhaust stack ? If so, does it have the big exhaust or the small exhaust ? What is this guy talking about, I hear you say. Here are a couple of photo's of the 2 variants, note also the different rear profiles of the bypass passage.
The longer stack is 38.5 mm in length, the shorter one 36 mm.
Old Mar 08, 2011, 07:17 PM
williame3590 is online now
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Wow never seen one of those Enya's either, I have to get out more
I have a nice engine in transit.....customs loves to fondle. It's a 1967 Fox 60 Blue Head with dual plugs, very nice engine.
I'll post photos as soon as it arrives.
Bill
williame3590 is online now Find More Posts by williame3590
Old Mar 08, 2011, 07:50 PM
Closed Account
Joined Nov 2009
Bill
Bill, some people might think that the engines made by Duke Fox would not appeal to devout collectors - not so ! I have 14 FOX's in my collection (mostly the 29 & 35 Stunt versions) and I derive just as much pleasure from handling them, as I do from expensive exotica. There is a certain appeal about an item, be it a model engine or something else, which is simple in design, well made & robust, yet not expensive to purchase. Nothing fancy, just made to do a specific job well. Look forward to the Blue Head photo's !
Old Mar 08, 2011, 08:05 PM
Closed Account
Joined Nov 2009
My latest FOX - we could have a FOX feast !
Old Mar 08, 2011, 08:11 PM
Joined Aug 2007
Speaking of exotic, this one will definately qualify. A Damo 218 twin, very limited run hand made in Sweden. About a 1.10 power displacement and just a shear work of art.
Mine is NIB and I was very lucky to be able to aquire this engine, one of my favorites. Early 80's vintage, sorry!
Bill
Old Mar 08, 2011, 08:30 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
How about a nice Fox Bluehead .60 engine with dual glow plugs?
I had shelved it for many years as way back then we didn't use mufflers and .60 engines are incredibly loud without a muffler, but one day I found that a Davis Diesel Development Soundmaster Muffler would fit the engine. So I took it out, clean it up some, put in new rings, and it runs great once more. The engine has a needle bearing rod (both ends too) and two piston rings, not just one ring, and a great three needle carb, with adjustments for high, mid range and low. The crankcase for the engine design eventually grew into the Fox .78 engine, of which Fox manufactured for many many years.
I had first flown the engine in a Astro Hog and later another plane, and the engine outlasted both planes.
Anyway the engine is alive and well and flying in a Goldberg Tiger 60 plane now. I suspect it will wear out this airplane too.
bench running the engine after its ring job.
The engines used an exhaust baffle coupled to the carb throttle arm, so they could have a tickover idle speed.
earlwb is offline Find More Posts by earlwb
Old Mar 08, 2011, 08:38 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I used to have a couple of Madewell .49 engines that were converted to glow.
A long exhaust stack version and a short exhaust stack version. This one was never run.
Old Mar 08, 2011, 08:45 PM
Closed Account
Joined Nov 2009
Bill
Bill, indeed a lovely thing with all those bits & pieces moving up and down. Did yours come in a nice wooden box ? Also, did you get a set of instructions for it ? - the oil content in the fuel is critical to that engine.
Old Mar 08, 2011, 08:50 PM
Closed Account
Joined Nov 2009
Earl, was the Madewell er, made well ? I have seen a few O&R engines, and was far from impressed. The piston / liner fit reminded me of a tin can rattling around in a drain pipe. With the dual-plug FOX, do you find you only have to light one plug ? BOB
Old Mar 08, 2011, 08:58 PM
Joined Aug 2007
Damo
Not a wooden box just a cardboard box. I have all the instructions for though.
Bill
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
