Espritmodel.com Heli Air
Old Mar 16, 2011, 03:56 AM
Closed Account
Joined Nov 2009
State of the art engine control, late 1953
Twin-Stack is offline Find More Posts by Twin-Stack
Old Mar 16, 2011, 03:59 AM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Originally Posted by RyanNX211 View Post
I heard that the rights to the Forster .99 were bought after the war by the Japanese company that became Honda. They used an enlarged version as a generator.
Originally Posted by Twin-Stack View Post
That may not be correct - my understanding is that Randy Linsalato (RJL) owns the rights to that engine, and indeed produces new build Forster 99's from the original dies. BOB
The Japaneses may well have done what Ryan says....except for that 'buying' thing........so you may both be right...
Gluehand is offline Find More Posts by Gluehand
Old Mar 16, 2011, 04:23 AM
Closed Account
Joined Nov 2009
Danny, from Radio Modeller March 1966
Old Mar 16, 2011, 04:40 AM
Gluehand's Avatar
Joined Sep 2008
Not 'NIB' anymore (like myself)...but two early (Duromatic) McCoy ´stunt´engines.
.19 and .29
Nice honest work horses with twin ringed baffled pistons.
Rumours says that the later McCoys weren't that good, although I haven't compared this myself..
Old Mar 16, 2011, 04:51 AM
Electrif(r)ied nitroman
danny.act's Avatar
België, Vlaams Gewest, Putte
Joined Jun 2004
Thanks Bob !
I really like all the info and articles i can get about the 'Lee' engines, thanks!
Always like to read additional information and history about engines we collect, and others to.
That's also an important part of the fun in collecting engines, beside making new friends.
You have great information about engines, let's keep it coming!
I like Your Enya .63 Typhoon!
regards,
Danny.
danny.act is offline Find More Posts by danny.act
Old Mar 16, 2011, 05:08 AM
Gluehand's Avatar
Joined Sep 2008
Very stylish...!
Also, the speed-control sheets are lovely...in these days of electronics, we need this less abstract technology to rest our eyes and brains on.....
I find it inspiring...not in the sense of bringing mankind further, but to enhance the quality of life...
Old Mar 16, 2011, 10:00 AM
danny.act's Avatar
Joined Jun 2004
Hi Gluehand,
So You'r not NIB anymore, but Your Duromatic system does it still works??
regards,
Danny (also not NIB anymore)
Old Mar 16, 2011, 06:29 PM
danny.act's Avatar
Joined Jun 2004
Kalt FC-1
Kalt FC-1
Last edited by danny.act; Mar 17, 2011 at 06:48 AM. Reason: Adding picture Kalt & Feeney
Old Mar 16, 2011, 07:37 PM
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
I know don't tell me.......
Bill
williame3590 is online now Find More Posts by williame3590
Old Mar 16, 2011, 08:43 PM
Closed Account
Joined Nov 2009
Tools, Tips & Techniques
OK guys, what we need here is for all you collectors out there to start pooling their accumulated knowledge - all those little helpful tips which we have gathered over the years, in tinkering with model engines. To kick off, here's some stuff I use - the ONLY screwdriver which touches my precious ENYA's is the one shown, a Fuller. With the #2 bit fitted, this is the only screwdriver I have found that can loosen & tighten ENYA screws without marking them in any way. Note though, how the "ears" are carefully ground off near the point, otherwise they will "catch" or foul some head fins (ie. bend them). The other gadget shown with the driver is just a faster way to install / remove glow plugs. The engine with a lump of wood sticking out the back is how I remove most screw-in type backplates. Just select a piece of an old broom handle or whatever, and carefully grind it down (with a taper) until the end will just fit in the backplate - tap it all the way in, and clamp the wood in a vise. Other photo's show a selection of different size (1/4 in. drive) sockets, mainly used for removing needle valve assemblies. With my little 4" adjustable wrench on the other end, it makes the job easy ! Obviously though, all these sockets have to be ground down carefully - I just do 'em by hand. Hands up all those guys who used to use long nose pliers to remove NVA's ! BOB
PS note how I cunningly removed the compression adjuster from the AMCO to give the impression of it being a glow !
Old Mar 16, 2011, 10:59 PM
Closed Account
Joined Nov 2009
Anybody got any idea what this is - http://cgi.ebay.com/NEW-T-GLOW-PLUG-...item1c1a23b9a1
Probably a home made job, but as I know the seller has sold off quite a few Aussie Taipans (some of which have a "T" on them), could this be a rare one- off by Gordon Burford ? BOB
And the spark ignition version - http://cgi.ebay.com/OBSCURE-T-IGNITI...item1c1a3a631a
Old Mar 17, 2011, 12:17 AM
Closed Account
Joined Nov 2009
Here is my basic gasket making kit. The most important item is the nylon, kitchen chopping board ! This is because the point of the circle cutter will gradually dig deeper and wider into a wooden surface, with the end result you have an out of round circle. The nail scissors have curved blades for cutting complex shapes, and I only use the pen re-fill so as to mark more accurate bolt holes, and the outside shape of the engine part. The circle cutter can be purchased for $12 - $15 at any craft or sewing shop, and if using the nylon board, the cutter can be held stationary (or only moved 75 degrees or so of wrist movement), whilst the board & work are rotated.
A couple of more tips - sometimes (if you're a perfectionist like me) its takes a while before you find the exact setting on the circle cutter. So rather than waste the actual gasket material, make practice cuts on thin paper until you get the perfectly sized circle for your backplate or whatever. If the outside perimeter line of your gasket is a complex shape (ie. not perfectly round), you will find it easier to cut out accurately with the curved scissors if you first go round the shape making a cut about 1mm outside the traced shape. Also, as the traced shape will be slightly larger than the actual backplate, the final cut should be made just inside the line. BOB
Old Mar 17, 2011, 01:20 AM
Closed Account
Joined Nov 2009
Have you ever wanted to remove the front housing from an ENYA or a bolt-on backplate from another engine - without wrecking the gasket, that is ? Here's the way to do it - slacken off all the retaining bolts about a millimeter, but do not remove them completely. Pour a small amount of acetone into a nylon container, and using a brush or old toothbrush, paint around the gasket with the fluid. Most gaskets will come away from one of the surfaces in 5 minutes or less, and by leaving the bolts in whilst you do this, you won't damage the gasket if the surfaces suddenly come apart whilst a portion of the gasket is still stuck. If the two surfaces are stubborn and remain stuck together after several minutes of soaking in acetone, try this. Immerse the whole engine (with the glow plug removed) in a container filled with acetone, making sure that the withholding bolts are still as in the photo below. If you have bolted on a nylon propeller stub, you can "rock" the crankshaft back and forth with the crankcase filled with liquid. As you twist the shaft to the right, the piston coming down will compress the fluid in the case and the pressure should "pop" the backplate off. BOB
Old Mar 17, 2011, 03:48 AM
Closed Account
Joined Nov 2009
For our European friends - February 1966
Old Mar 17, 2011, 03:58 AM
Closed Account
Joined Nov 2009
June 1966
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
