Old Aug 15, 2011, 09:33 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
I have to dig out some more engines this thread is great!
Bill
williame3590 is offline Find More Posts by williame3590
Old Aug 15, 2011, 10:00 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well one way is to have a lip at the top of the cylinder sleeve, the aluminum head is machined slightly oversized to fit. You then freeze the head and heat up the cylinder and then lightly press the head into place. let it cool off and it ought to really be on there good. As when the engine is running the head will heat up and expand too.
The lip can be shallow as is the recess it fits into on the head too.
But yeah staking normally means someone drilled holes and pressed in some pins around the circumference.
earlwb is online now Find More Posts by earlwb
Old Aug 15, 2011, 10:04 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You go for it Wiz. They are pretty good running engines. I already have two, so I won't be competing for it.
Anyway, did anyone here win that auction for the COX Twin 0.040 engine that was on Ebay? That looked to be a good runner too. It looked like it had a reed valve for the intake. But it looked pretty nice though.
Old Aug 16, 2011, 01:49 AM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
Here is an abbreviated engineering definition of "staking" which I found on Google -
"Staking is a method of securing parts by pushing surface metal together with punch and hammer. It is a process usually employed to secure two parts together. Threaded parts that draw up to a certain critical point are sometimes staked to maintain that position. The advantage of staking is that it holds parts together in a final position".
Pretty vague huh ?
It would appear that "staking" is a generic term for any method of attaching a cylinder head, other than by threads (a la COX), or with bolts.
Twin-Stack is offline Find More Posts by Twin-Stack
Old Aug 16, 2011, 07:20 AM
G WILLIE is offline
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
Regarding Herkimer OK engines, the staked on heads were really staked on cooling fins. The cylinder was blind bored with the combustion chamber an integral part of the cylinder. A small diameter spud was machined on the top. This spud was drilled and tapped for the plug. The head cooling fin assembly was slipped over this spud and the edge of the spud was upset (staked) to firmly hold the fin assembly to the cylinder. Of course the spud's diameter was large enough to not disturb the plug's seat.
There was actually an accessory head made for the Brown Junior that was a set of head cooling fins, but retained by the spark plug, not staked.
G WILLIE is offline Find More Posts by G WILLIE
Old Aug 16, 2011, 06:31 PM
Closed Account
Joined Nov 2009
Another very interesting site for engine lovers - http://www.vrhc.co.uk/Hardware/Engines/Engines.htm
Old Aug 16, 2011, 07:01 PM
Closed Account
Joined Nov 2009
When I was trying to find the definition of "staking", I learnt that Ohlsson & Rice engines used a novel method for securing their cylinders to the back half of the crankcase. Variously described as "spot welding", "attaching" etc. this process apparently involved pouring molten alloy around the base of the liner, through 2 holes in the crankcase. These holes were then sealed off with alloy plugs. Thus, if you wanted a new piston & liner for your O & R, you had to take a new half crankcase as well, as the 3 components were not sold separately. The photo's below show two different O & R engines with the "plug weld." BOB
Old Aug 16, 2011, 07:38 PM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Bwf 2,5 s
Hello !
Here we have two examples of " BWF 2,5 S " , the early version with the silver Head and rare RC carb and the later version with Venturi.
They were made between 1983 and 1991 in east germany.ABC Piston/liner and double Ball bearings. The cylinder head dont go into the liner , it is screwed flat on it. Not so vinage engines, but never produced again and they are Very good looking.
There was also a "r" and "rr" version with high silicium Piston, for up to 36000 u/min
The "S" was/is used mainly for CL and FF . spin up to 26000 on ground without pipe. also good RC engine, when you got the carb.
flyinglog is offline Find More Posts by flyinglog
Old Aug 16, 2011, 07:48 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Interesting engines! They have rear exhaust but then a side muffler. I assume that some also used the rear exhaust with a tuned pipe?
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Aug 16, 2011, 07:51 PM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Picco / OS Hybrid
Here is a Picco / OS .60 hybrid
cylinder and P/L is Picco, Crank and front housing is OS . Dont know anything about the carb. Dont know if its Powerful, but looks cool and runs.
Old Aug 16, 2011, 07:53 PM
G WILLIE is offline
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
The chopper link naturally omitted the Fox Eagle 4 heli engines. Here is the Eagle 4 .74 heli:
Old Aug 16, 2011, 07:58 PM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Yes , the BWF was designed for use with pipe. the muffler was for the hobby pilot and gives you a lot of trouble during engine installation, it fits nowhere.. But you have to open up the exhaust for pipe use(just the S versions).
regards
Old Aug 16, 2011, 08:04 PM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
so , the last one for today explains itself :
(mvvs 2,5)
Regards , Sebastian
Old Aug 16, 2011, 09:13 PM
Closed Account
Joined Nov 2009
Some interesting engines from auctions past, these are (from the left) -
A sectioned TMN 12 sleeve valve
Unknown 40 Serial #84
A K&B/TWA 15 from 1972 Serial #105
Discussion Vintage Engines being run video earlwb Engines 37 Apr 01, 2013 02:48 PM
For Sale Multiple glow engines Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 12 Oct 03, 2012 01:13 PM
For Sale Vintage glow engines for sale very cheap TheEdge Aircraft - Fuel - Engines and Accessories (FS/W) 19 Jan 18, 2011 06:37 PM
Question rc glow engines startup1 Beginner Training Area (Fuel) 6 Nov 04, 2010 07:53 PM
For Sale four glow engines thriller Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 25, 2010 10:42 AM
