That is a big Enya R1.20 four stroke engine.
It is a big and heavy sucker. It is on my old Challenger II Biplane. It was all gunked up and cruddy looking, so it got all cleaned up, new ring and new bearings too. |
Latest blog entry: My Low Wing plane
Joined Nov 2009
The Kosmic engines more of a curiousity than a rare collectable, at the moment anyway. Maybe in 25 years time............ BOB |
Joined Aug 2004
Smallest 4-stroke
Lorain Ohio
Joined Jul 2004
Back around 1962, I had an interesting engine come into my possesion that so far, nobody I've mentioned it to has heard of, including about 15 years ago, the guy who was manning the MECA booth at Toledo. I have seen only two mentions of it, and while the one I had was Glow, it apparently was a pre-WW-II ignition engine. Points and condenser had been removed and thrown away. It was a Sideport Coby (.12 or .15?), not sure which, since the two articles I saw mention it each had a different displacement. Long stroke engine, could run either direction. Needed a shot of 3-in-one for starting, ran well on Fox Superfuel,seemed to outperorm my Fox .15X on 9" props.
Whoops, just remembered where I actually uploaded an old listing mentioning this engine on this thread, Pity the Poor CD, from a 1946 AT. It was listed as the Cobey-Waite, listed displacement of .147 cu in. |
Joined Nov 2009
Lorain Ohio
Joined Jul 2004
I guess I still have a bit of curiosity about the engine, since it is kind of uncommon. If I still had the engine today, I'd probably either try growing the piston in an oven, or do a little knurling on the piston diameter to restore it's compression. I always wonder if the sound it made ws from turning an exceptional high RPM for it;s size and era, or just a function of the noise it made with a wide open annular exhaust. If you do post the data, let me thank you in advance.
Joined Nov 2009
50+, the Cobey-Waite "Model 1470" is dated to 1946, and is listed as being made by the Molded Insulation Co., Philadelphia (Bill Cobey & George Waite). The capacity is/was 0.147 cu. in., of spark ignition and was a pretty typical layout for that era being a 3 (or side) port, thus enabling it to run in either direction (as a glow anyway). A footnote says "There have been some Cobey-Waite engines reported with the word "Scout" on bypass. One advert referred to a "Scout" engine." A guy named Mike Drozda built 20-25 replica Cobey-Waites in 1972. BOB
Joined Nov 2009
On Aussie eBay - http://www.ebay.com.au/itm/F-engine-...item2c5e912551
"The time has come, my friends, to part with one of my favourite engines - the "F". Many is the time when I have sat in my workshop and marvelled at the beauty of this purpose-built full-house F1J engine, knowing that I would never be able to build a model that would let it reveal its true potential ... Adapted from Martin Gregorie's F1J engine website : "This is a purpose built F1J engine from the Tartar republic. It is a twin ball race engine with AAC cylinder technology. It is equipped with an integral brake, flood-off inlet and pressure tapped backplate. Like many engines from the Russian republics, it is equipped for a pressurised hard tank rather than a bladder, though of course swapping it to a bladder is quite easy. The head suits a Nelson plug". Roger Simpson ran his F engine on 40% nitro and it turned 29,600 rpm on a 152 mm diameter propeller. The engine's maker, Ildar Faizrakhmanov, quotes about 31-32.000 for the AAC version on the 152 mm propeller: I don't know what fuel he uses. Lynn Pulley writes - "I have been using one of these engines for about a year and am very pleased with it. I have won several local contests and placed high in all that I have entered. In the recent San Valeers annual, competing against about 10 other F1J flyers,( using Cyclon 061 and KC-06 engines), there were three of us using F engines. Myself , Tony Robertson, and Jeff Ellington. Tony retired in the 5th round due to timer failure, while Jeff & I finished 1st and 3rd respectively just 8 sec apart. My engine turned 29,500 rpm on Ildar's 152mm prop using 25% nitro the day I received it. Ildar won't ship an engine unless it is turning at least 29,000 rpm on 0% nitro with a 148mm prop. My engine is now closing in on 31000 rpm with the same prop and 40% nitro!" |
Joined Aug 2004
Joined Aug 2004
Joined Nov 2009
Reggy, the book says the originals had a matte finished, built up steel cylinder, whilst the Drozda replica's had a cadmium plated cylinder, also the name on the bypass was highlighted in gold leaf ! Other Repro's exist also, so we will have to hire a detective (Inspector Clouseau perhaps ?) to work out what yours is ! BOB
Joined Aug 2004
| Thread Tools | |
| Discussion Vintage Engines being run video | earlwb | Engines | 37 | Apr 01, 2013 02:48 PM |
| For Sale Multiple glow engines | Greyout | Aircraft - Fuel - Engines and Accessories (FS/W) | 12 | Oct 03, 2012 01:13 PM |
| For Sale Vintage glow engines for sale very cheap | TheEdge | Aircraft - Fuel - Engines and Accessories (FS/W) | 19 | Jan 18, 2011 06:37 PM |
| Question rc glow engines | startup1 | Beginner Training Area (Fuel) | 6 | Nov 04, 2010 07:53 PM |
| For Sale four glow engines | thriller | Aircraft - Fuel - Engines and Accessories (FS/W) | 5 | Sep 25, 2010 10:42 AM |
