Mar 08, 2011, 02:32 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by tenspeed
The firewall isn't angled. I'll have to add spacers to get the prop to clear the cowling. So angling it won't be a problem. Just know how much will be the only issue. ...
If there's no data available from the instructions or this forum, then trial-and-error is the only way.
I don't think that wrong angle has ever been the direct cause of a crash -- it just gives the plane some undesirable characteristics: If you're cruising in level flight and you quickly open the throttle and the nose lifts, then you probably need to dial in a bit of downthrust. Alternatively, you back off the throttle and the nose drops before the speed does, also means you could do with a bit of downthrust. Ideally you shouldn't feed the need to adjust the elevator trim every time you change the throttle setting.
I'm not so certain about right thrust, except that first indication that you need it is often when the plane swings left during your takeoff run. After you've checked that nosewheel (if it has one) and rudder are straight, then next port of call is some right thrust.
