Old Mar 07, 2011, 10:28 AM
firefly_joe is offline
Find More Posts by firefly_joe
Joined Feb 2011
how to boost servo signal through long wire?
Does anyone know if there is something that I can use to boost a servo signal from the receiver through a large amount of wire (maybe 50ft or more)?
I haven't tried it yet but I'm pretty sure the servo signal is going to be pretty weak.
firefly_joe is offline Find More Posts by firefly_joe
Old Mar 07, 2011, 10:39 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
No need (I think). There are two components here: the 5-6v power circuit, and the PWM signal (white wire on most servos). The signal line only involves tiny current flow, so there won't be much in the way of voltage drop on that line... and the servo doesn't respond to a voltage signal anyway, but to the pulse widths.
If you do have an issue here, try some heavier gage wire.
For power, you might want a local power source... a 4.8 - 6v batterywired into the red/black leads. Keep a common ground wire back to the source, and delete the +5v red wire in the long run, you'll be fine.
patmat2350 is offline Find More Posts by patmat2350
Old Mar 07, 2011, 10:58 AM
MikeC47 is offline
Find More Posts by MikeC47
Growing up is overrated
MikeC47's Avatar
Bellevue, WA, USA
Joined Nov 2009
Firefly joe
I have to ask, what are you building that will have a 50’ wire from the receiver to the servo? That is going to be one “really big model”.
MikeC47 is offline Find More Posts by MikeC47
Old Mar 07, 2011, 11:00 AM
Joined Feb 2011
sounds promising! I am more than likely going to to have a battery pack at the other end of the line, so you are saying if I connect the servo's +/- to the secondary pack and then the signal wire only connects to the receiver I should be good?
Old Mar 07, 2011, 11:08 AM
Joined Feb 2011
@Mike, I'd like to be able to drop a mini sub off my barge, long term plans but just thinking ahead now
Old Mar 07, 2011, 11:34 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
And a common ground wire, the signal needs a reference. So, black and white wires on the long run, black and red wires to the local battery.
Old Mar 07, 2011, 12:09 PM
Joined Feb 2011
awesome thanks!
Old Mar 07, 2011, 06:05 PM
WA3ETD is offline
Find More Posts by WA3ETD
United States, VT, Pittsford
Joined Feb 2011
50 feet
I would test the project before assuming it will work. The capacitance of the parallel signal and ground wire is considerable and with the associated inductance the system becomes a transmission line exercise. The clean square wave pulses from the RX will probably become "rounded" with extended rise and fall times. The device on the far end may still respond correctly - but I would definitely test the system first!
John WA3ETD
WA3ETD is offline Find More Posts by WA3ETD
Old Mar 08, 2011, 12:57 AM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
How big of a mini sub will this be? 50' of servo wire will be pretty draggy through the water.
Aerominded is offline Find More Posts by Aerominded
Old Mar 08, 2011, 01:02 AM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
If your going to have the battery in the sub, better off having the RX in there as well, and just transmit the RF town a thin Coax from the Tx, I have a drawing posted in the ROV forum with a simple circuit to allow video signal up the same coax
I will watch this space
Nick
nick_75au is online now Find More Posts by nick_75au
Discussion FPV Signal gets fuzzy, should I boost it? airbagit13 FPV Talk 21 Jan 20, 2011 08:43 PM
Discussion Detached signal wire on servo? elitepanda Parkflyers 3 Sep 14, 2010 05:41 AM
Discussion Servo signal wire pudd Mini Helis 1 May 30, 2008 09:36 AM
Discussion How can you boost the signal of your radio Petewp Radios 9 Oct 14, 2006 07:13 AM
FS - 2M glider, Rx, (2)servo signal filter/boost extensions Skid Aircraft - Electric - Airplanes (FS/W) 6 Oct 09, 2003 03:53 PM
