Old Mar 07, 2011, 02:35 AM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, FL, Milton
Joined Mar 2011
Help!
I need some feedback on a new idea of mine. (wiring diagram attached)
Name: wiring diagram.jpg
Description: so I just threw this wiring diagram together as somewhere to start... I need feedback to see if it will even work. and what needs to be fixed to get into the building process.
Im going to use basic x( Left and right) y(up and down) and z axis orientation for the discription.
the basic idea is a tri-copter using propped brushless outrunners. dual props in the front of the aircraft (left of diagram), and the third centered in the rear. I want all the motors to tilt independently along the x axis: all foreward for FF, same for reverse flight, two front motors in opposite direction for rudder/yaw rotation (along the z axis). I am hoping that I can use variable thrust on the two front motors in order to induce roll along the x.
so a couple of questions of mine are:
can I put the esc's in the circuit that I have attached?
is my idea even feasible?
Please any feedback is welcome? I am pretty new to this and being quite ambitious.
kicekilla is offline Find More Posts by kicekilla
Old Mar 07, 2011, 07:28 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
This would be mechanical thrust vectoring to control flight as an alternative to varying the thrust on the three motors. If it has been tried it would probably be on the multi rotor helocopters subforum, and it might be a good place to get an opinion on it too:
Multi Rotor Helis - http://www.rcgroups.com/multi-rotor-helis-659/
It would seem to be a more complicated way to do it to me.
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion Need help on wiring diagram jshander Dock Talk 0 Feb 03, 2011 11:32 PM
Idea esc fan idea i need some opinions on! TRAXXAS DEMO Electric Power Cars 12 Oct 17, 2010 04:52 PM
Discussion Need a Wiring Diagram TigerI Batteries and Chargers 1 Sep 02, 2010 07:19 PM
Help! Need confirmation on battery wiring (diagram inside) steve1814 Batteries and Chargers 2 Oct 04, 2008 09:02 AM
need some feedback on Supertigre G90 MrPropJet Engines 2 Nov 06, 2004 08:59 AM
