Old Mar 06, 2011, 01:53 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
ALZRC 450 Pro kit/combo
This arrived this morning from HK-Parts.com:
http://www.hk-parts.com/alzrc-trex-450-pro-kit.html
Only took a few days by EMS.
First impressions are very good. Nice printed box, like they show on the site, vacuum wrapped in plastic. Odd, there is some main shaft spacers and a tail control pushrod, taped to the outside of the box. Will find out more about this, when I open the box.
Even though they refer to it now as ALZRC, I think the name came from AL2RC (Align 2 RC).
Mine is the kit version, but they also have a combo version (3800KV Brushless Motor and 40A ESC), as well:
http://www.hk-parts.com/alzrc-trex-4...esc-motor.html
I'm told by HK-Parts that the motor is up to the hardest 3D, and the ESC looks like the HobbyWing (Turnigy plush) version; but I already had plans for an Align BL450M and an HK blue 40A ESC (same as the Mystery one).
It's well under half the price for the same version of the Align 450 pro kit and HK-Parts told me they have a "no crap" policy, for quality. The guy I ended up speaking to, by using there contact us page, had perfect English writing skills, which was a plus, and was very eager to be of help.
So I'm going to put them to the test, since I've built several Align and HobbyKing kits.
I don't have the time for a full build thread, but I'll certain show more photos and info about the quality of the kit as I build it.
David
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Build posts:
In the kit 1: http://www.rcgroups.com/forums/showp...36&postcount=3
In the kit 2: http://www.rcgroups.com/forums/showp...97&postcount=6
In the kit 3: http://www.rcgroups.com/forums/showp...79&postcount=9
In the kit 4: http://www.rcgroups.com/forums/showp...4&postcount=16
Head assembly: http://www.rcgroups.com/forums/showp...4&postcount=21
Main frame assembly: http://www.rcgroups.com/forums/showp...8&postcount=26
Motor and cyclic servo installation: http://www.rcgroups.com/forums/showp...8&postcount=30
Tail section: http://www.rcgroups.com/forums/showp...3&postcount=34
Tail servo install: http://www.rcgroups.com/forums/showp...2&postcount=45
My setup: http://www.rcgroups.com/forums/showp...2&postcount=47
ESC installation: http://www.rcgroups.com/forums/showp...1&postcount=67
Tail servo failure: http://www.rcgroups.com/forums/showp...7&postcount=74
Conversion to FBL: http://www.rcgroups.com/forums/showt...9#post18829225
3GX capacitor mod: http://www.rcgroups.com/forums/showt...2#post19252578
Associated links:
ALZRC 450 Pro SKD FBL (Flybarless) Head: http://www.rcgroups.com/forums/showthread.php?t=1491796
ALZRC High Grade 450 Pro Canopies: http://www.rcgroups.com/forums/showthread.php?t=1475255
ALZRC 3GYS Flybarless System: http://www.rcgroups.com/forums/showthread.php?t=1490079
RC Logger Digital Pitch Gauge: http://www.hk-parts.com/trex-450-pro...tch-gauge.html
High hardness frame screws: http://www.hk-parts.com/alzrc-450-pr...-hp45017a.html
Super hard hex drivers: http://www.hk-parts.com/catalogsearc...driver&x=0&y=0
beenflying is offline Find More Posts by beenflying
Old Mar 06, 2011, 02:08 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
looking forward to your thoughts and hopefully lots of pics! It's always good to have alternatives. Happy building!
2Doggs is offline Find More Posts by 2Doggs
Old Mar 06, 2011, 02:22 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It gets better, with a printed manual in the kit.
Description:
Description:
Old Mar 06, 2011, 02:24 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks. I'll try to post as many as I can.
Old Mar 07, 2011, 03:59 AM
Look at me, I can fly...
Heliaxe's Avatar
Australia, NSW, Sydney
Joined Jun 2010
Thanks David for the update and starting this thread.
I will keep a keen eye out on your findings. In particular the quality compared to the Align Trex 450. Please post any parts that you find not to be comparable .
Thanks...
Heliaxe is offline Find More Posts by Heliaxe
Old Mar 07, 2011, 01:58 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Looking though all of the bags in this kit, you can't help but feel like you are opening an Align kit. Everything is nicely packaged for each section of the build.
One of the reasons I bought this kit was because the canopy and blades looked very good. In fact the only parts I bought to replace parts in this kit, is a metal tail control arm and a metal vertical stabilizer spacer.
Edit: I later found that the metal tail control arm was already standard in this kit.
I put the canopy on my current 450 pro (an HK (HobbyKing) and Align hybrid) and compared it to my Align 450 sport canopy (HC4105), I recently purchased, that is very similar. Other than the Align 550E, this is one of the best canopies I have received in a kit. The gloss is not quite as good as the Align canopy but it is definitely close and will be a keeper.
The blades are nicely packaged and look good. They also come with two tin foil balance stickers. The blades weight 21.66g and 21.85g. They look well made and feel quite stiff. The blades are all white on the bottom.
Description:
Description:
Description:
Description:
Description:
Description:
Old Mar 07, 2011, 02:29 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I forgot to mention, the tail control pushrod, attached to the outside of the box, is about 5mm longer than the one in the kit. Perhaps they were finding that not enough threads were being used on the ball links. A nice touch that they proved this, and shows that they want people to be happy with this kit.
Old Mar 08, 2011, 04:01 AM
Heliaxe's Avatar
Joined Jun 2010
I agree Davis the canopy and certainly the blades look very smart. They got my attention as well.
Old Mar 08, 2011, 06:09 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Okay, today we'll go through the accessories bag. Once again very nicely packaged and labeled.
Description:
All of the packets out of the main bag.
Description:
Nice touch providing the plastic ball link removal tool, which wont scratch the balls, like the metal one's can.
Description:
The servo arm ball joints and other spares. I zoomed in so you could see the servo arm balls have a plastic thread. I prefer a threaded ball with a nut, but these plastic threads with a bit of CA should hold forever (Align used them on the 500 plastic mixer arms.
Description:
13 and 14T pinions and motor screws. I'll be using the 14T on the Align BL450M, like my Align 450 sport.
Description:
Nice battery strap and black Velcro pads.
Description:
Some thread lock and, a real bonus, some good quality grease and quite a lot of it too.
Description:
Plenty of "black" cable ties, three Alan keys and a Philips screw driver, which I suspect is for the tail blade holder screws. Again very thorough.
Description:
Head linkage rods. They appear to have an "A" to indicate which side goes on to the ball ("A" faces out).
Description:
Upper head fixed length linkage rods.
Description:
Next up we'll look at the head and fit all of the linkage rods, to see if there's any slop.
David
Old Mar 09, 2011, 04:09 AM
Heliaxe's Avatar
Joined Jun 2010
Who is ALZRC
Looking good.
I am still trying to work out who ALZRC is
I think they are the mob that produces the Align parts?
Old Mar 09, 2011, 04:38 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by Heliaxe View Post
Looking good.
All I know is that it's the newest kit on the market, and based on what I've seen so far, it's the nearest thing you will get to an Align kit. Certainly the experience for me so far, has been the same.
I can only hope by supporting them, that they will go on to make other kits, as well.
Old Mar 09, 2011, 11:13 AM
Joined Mar 2011
This is ALZRC
Hey David,
Thank you very much for putting all of this information on the web. It's nice to have someone provide such detailed information about the kit.
For all those concerned, I have created a BLOG entry for ALL About ALZRC. If you want to know more about them here it is.
ALL ABOUT ALZRC
Can't wait for you to finish the build.
-E
Pharsyde is offline Find More Posts by Pharsyde
Old Mar 09, 2011, 12:03 PM
Joined Oct 2008
I received my 450 kit yesterday as well. I'm also quite impressed with the way it looks. I am however looking for a programming guide for the esc. If anyone knows, please let me know as well. I also ordered the flb head for my kit, so this will be my first fbl helicopter. I'm told that they fly like a larger heli. We shall soon find out!
sonnyhad is offline Find More Posts by sonnyhad
Old Mar 09, 2011, 01:51 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by Pharsyde View Post
Hey David,
ALL ABOUT ALZRC
-E
This link works better:
http://www.rcgroups.com/forums/showthread.php?t=1403646
Thanks for this. It certainly filled in a few blanks for me. Please feel free to comment on anything here. I'm sure everyone would appreciate your input.
A build for me can take a while, due to family life and work commitments. Perhaps others can share their experience, as well, if I'm taking too long.
Old Mar 09, 2011, 01:58 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Glad to hear you have one as well, and obviously the combo, so you can let us know your experience with the motor and ESC.
If it's the ESC I think it is, then the attachment should help. I also think this programming card should work:
http://www.hobbyking.com/hobbyking/s...idProduct=2169
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
For Sale T REX 450 PRO Super Combo NIB BlueDevil69 Aircraft - Electric - Helis (FS/W) 7 Jan 02, 2011 11:36 AM
Discussion Align 450 pro combo for intermediate flyer??? rnorth 3D Electric Heli Flying 6 Dec 01, 2010 09:32 AM
For Sale 450 Pro Super Combo(SOLD) thundercl58 Aircraft - Electric - Helis (FS/W) 1 Oct 22, 2010 04:44 PM
Sold Trex 450 PRO kit Combo $290 jmadams Aircraft - Electric - Helis (FS/W) 5 Mar 18, 2010 08:50 PM
