Old Mar 06, 2011, 12:57 PM
djdavid60 is offline
Find More Posts by djdavid60
If it flies, I can crash it!
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
HobbyKing Icon-A5 for FPV?
I was poking around the HobbyKing website and stumbled across this rather large airplane. The cockpit is enormous and I got to thinking it might actually make an interesting FPV project.
Here is the link:
http://www.hobbyking.com/hobbyking/s...dProduct=16605
Here are specs:
Specifications:
Wingspan: 1800mm
Length: 1150mm
Flying Weight: 2.5KG
Motor: 3740 400kv Brushless
ESC: 60A (Required)
Servos: 5 x 17g and 1 x 25g MG
Battery: 22.2v 6s 2800-3200mah (Required)
Propeller: 12x6E
Spinner: 1.5in
Required:
ESC: 60A
Servos: 2 x 17g (for Flap option only)
Your own Tx/Rx
It might be a fun project because the way it is set up, you can fly it off ground or water.
Any thoughts?
Doug
djdavid60 is offline Find More Posts by djdavid60
Old Mar 06, 2011, 03:31 PM
perfeet is offline
Find More Posts by perfeet
Internal Paradigm Consultant
perfeet's Avatar
Joined Dec 2009
Looks interesting. Huge space inside.
Personally I think it is ugly looking and also looks draggy.
Also very pricey (200$).
I would go for a Skywalker instead (89$)
perfeet is offline Find More Posts by perfeet
Old Mar 06, 2011, 04:08 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
Someone had one of these with a GoPro, then a blackbox on it. Was MR_B maybe? They said it didn't handle wind well, was impossible to glide without the motor on (I remember a very intense video when the motor cut out) but was very easy to set up.
Honestly I think the Skywalker looks better in every sense.
Acorns is offline Find More Posts by Acorns
Old Mar 06, 2011, 04:23 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Yes I think Mr_B had one, he gave it a go but if i remember well he decided to put it away. The video was very unstable. maybe it is because of the short tail boom that makes it twitchy
rcmonster99 is offline Find More Posts by rcmonster99
Old Mar 06, 2011, 06:27 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
yep ive heard the same on another forum, seemed too hard to fix and wasnt recommended at all unfortunately
CrashMeUp is offline Find More Posts by CrashMeUp
Old Mar 06, 2011, 07:11 PM
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
Thanks everyone.... I agree about the Skywalker. The ICON just looked pretty interesting with its amphibious capabilities.
Doug
Old Jul 13, 2011, 02:08 PM
Wheazel is offline
Find More Posts by Wheazel
Tech freak
Sundsvall Midlanda, Sweden
Joined Aug 2002
I have a thread in the waterplanes section of the Icon.
Deciding factors for me was land and water capabilities, roomy fuselage and a decent 1800mm span. Will be my first fpv plane.
http://www.rcgroups.com/forums/showthread.php?t=1469996
Wheazel is offline Find More Posts by Wheazel
Old Jul 13, 2011, 03:20 PM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
I have the smaller version from Hobbycity.
I am very disappointed with it, almost impossible to fly with that bird. With low throttle it more or less flyable, but hard to climb with such low throttle.
With even slightly higher throttle it became extremely unstable, the situation is similar to a tipstall, but of course at such high speed it can't be that. It drops nose and rolls in the same time into a spiral, without correct reponse to the aileron or elevator. Really hard to avoid death spiral. The situation is the opposite to a good plane: normally escaping from the spiral you need high throttle, but with this plane the only chance to lower throttle until aileron response comes back...
The only good feature is the very strong foam, it survived several crashes without any visible sign.
Hard to tell what is wrong with it. I suspect that the hollow bottom wing is too weak, subject of twisting torsions.
mmormota is offline Find More Posts by mmormota
Discussion Hobbyking - Icon A5 xenupy Foamies (Kits) 27 Jun 20, 2011 07:17 PM
Discussion Icon A5 build afitz87 Foamies (Scratchbuilt) 69 Mar 14, 2011 09:13 AM
Discussion Super Icon A5 Amphibian 70" wingspan!! JGuilty13 Waterplanes 2 Dec 25, 2010 03:13 AM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
