This thread is privately moderated by kdean, who may elect to delete unwanted replies.
Old Mar 06, 2011, 05:13 AM
kdean is offline
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Mini-HowTo
Rear Loading Battery Cage on V400D02
I did'nt like that you had to take off the canopy every time you want to change a battery. It is very time consuming when you really just want to be up in air. With the Metal Tail Boom Support from RTF-Heil, it makes it possible to swap batteries from the rear and not have to touch the canopy.
I also moved the ESC to allow the use of bigger battery packs, but is also better balances the heli as well.
kdean is offline Find More Posts by kdean
Old Jun 09, 2011, 11:30 PM
mutski is offline
Find More Posts by mutski
mutski
United States, AK
Joined Jan 2011
How do you secure the battery? Can't reach the Magic Belt spot without removing the canopy?
mutski is offline Find More Posts by mutski
Old Jun 10, 2011, 01:14 AM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
after my "magic bands" broke, i started using rubber bands for the batteries. I found that if you place the rubber band on the end of the battery, and pushed it into the cage, the extra size of the band would hold the battery in place. As you push it in the rubber band would roll up the battery and normaly stop at the base of the main gear. I try to get the battery as far forward as i can to keep the center of gravity. It works really well with longer 3s batteries like the 1800mah and 2200mah. I would then pass the battery connection through the rear of the cage to esc connection. I'll take some pics next time i fly my #3.
Help! Battery for the Walkera V400D02 JumboA5 Mini Helis 0 Dec 13, 2010 11:53 AM
Discussion Good wing loading on a sailplane. Homebuilt balsa? ihor14448 Sailplane Talk 6 Nov 07, 2010 09:03 PM
Question 2 female bullet connectors on battery side VS one/female on battery? T-CAT Batteries and Chargers 13 Oct 26, 2010 06:34 PM
Discussion Walkera 4#3 Battery Cage CG Fix princew Micro Helis 0 Mar 10, 2008 05:32 AM
Battery Cage flightdeck-guy Micro Helis 1 Aug 26, 2005 08:45 PM
