Old Mar 05, 2011, 11:13 PM
Build, Build, Build
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
DAW P-40 crunchie
Fabio built this DAW wood P-40 kit. Nice day at Lilly's today. Nice flying plane.
Tom
TRISME is offline Find More Posts by TRISME
Old Mar 06, 2011, 01:01 AM
BadPilot
badpilotto's Avatar
United States, IL, Downers Grove
Joined Nov 2007
Tom,
That P-40 flew awesome!! It look fun, how long can you fly, is it solely limited by the winds?
TFS
John
badpilotto is offline Find More Posts by badpilotto
Old Mar 06, 2011, 09:41 AM
Joined Feb 2011
Muy hermoso, donde lo has comprado?
gracias.
Carlos
andalucia is offline Find More Posts by andalucia
Old Mar 06, 2011, 10:00 AM
Build, Build, Build
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Originally Posted by badpilotto View Post
Tom,
TFS
John
Yes it can only fly on the slope when the wind is blowing about ten to fifteen mph.
Old Mar 06, 2011, 10:09 AM
Build, Build, Build
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
gracias.
Carlos
Este avion es viejo, la compania es " Dave's Aircraft Works". Ahora la compania "Skykingrcproducts.com" venden algos. Mi espanol es mal.
Tom
Old Mar 07, 2011, 06:27 PM
I DS slower than I build!
Cory's Avatar
Idaho Falls
Joined Jul 2006
Fun little planes. I have the old DAW crunchy TA-152.
Cory is offline Find More Posts by Cory
Old Mar 07, 2011, 09:19 PM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Thank you! I learn something new every day. Slope flying really does look like fum
John
Old Mar 07, 2011, 09:49 PM
Cory's Avatar
Idaho Falls
Joined Jul 2006
gracias.
Carlos
Carlos,
My Spanish isn't good enough to answer you in that language, but I understood your question. I hope you can understand my English answer. These crunchy D.A.W. warbirds were produced during the mid 1990s before the EPP revolution. They have been out of production for at least 12 years.
Old Mar 07, 2011, 10:15 PM
Cory's Avatar
Idaho Falls
Joined Jul 2006
You can get the EPP versions here: http://www.skykingrcproducts.com/rcplanes/DAW_kits.html
Old Mar 09, 2011, 05:46 AM
03svtsnakevert's Avatar
USA, TX, Copperas Cove
Joined Jul 2010
Originally Posted by Cory View Post
Carlos,
Here ya go, just helpin' out:
Mi isn' español; t bastante bueno contestarle en esa lengua, pero yo entendía su pregunta. Espero que usted pueda entender mi respuesta inglesa. Estos warbirds crujientes de D.A.W. fueron producidos durante los mediados de años 90 antes de la revolución del EPP. Han sido fuera de producción por lo menos 12 años.
03svtsnakevert is offline Find More Posts by 03svtsnakevert
Old Mar 09, 2011, 09:32 PM
I crash planes
bbjsw10's Avatar
USA, OH, Findlay
Joined Apr 2010
Am I the only one that is laying on his side to watch this?
I wish there was someplace to slope around me, I may need to start watching for some. Should the wind blow at the slope or away? Side of a reservoir work?
bbjsw10 is offline Find More Posts by bbjsw10
Old Mar 09, 2011, 10:17 PM
SlingWinger
San Bernardino, California, United States
Any aircraft that doesn't have a motor will only stay up when it is in rising air, which we call "lift".
One source of lift is ridge lift, or slope lift. It happens when the wind encounters an obstruction, such as a cliff or slope. So yes the wind has to blow against, and up, the slope.
Another source of lift is "thermals". This happens when the air is heated by the sun warmed ground to a temperature that is higher than the surrounding air. It forms a big bubble that breaks loose and rises up through the cooler air. If you live in the flatlands you may have to use thermals. To do that usually requires having your glider towed up by a "High-Start" or a winch. But if your glider is light enough and you're strong enough you can throw it up to thermal catching altitude, about 100' minimum I think.
Good luck!
dayhead is offline Find More Posts by dayhead
Old Mar 10, 2011, 08:17 AM
The Far East
Joined Jan 2006
NO videos, but here's my contribution. Same DAW crunchie Ta 152.
http://www.rcgroups.com/forums/showthread.php?t=997721
suirendoujin is offline Find More Posts by suirendoujin
Sold DAW 31" WS P-40 Warhawk crunchy Kit. codezilla Aircraft - Sailplanes (FS/W) 4 Jan 17, 2011 12:43 PM
Discussion HK Mini P-40 vs. E-Flite Mini P-40 anj4de Electric Warbirds 3 Sep 29, 2010 03:14 AM
Sold Phase 3 P-40 Warhawk - Local p/u AZ or SoCal crxmanpat Aircraft - Electric - Airplanes (FS/W) 5 Sep 13, 2010 08:56 AM
Sold DAW - Curtis P-40 Warhawk Slope Kit *NIB* richardc951 Aircraft - Sailplanes (FS/W) 1 Nov 27, 2008 06:37 PM
DAW P-40 w/Mega16/15/3 (Started life as a Kawafoamie) Grapeape Foamies (Kits) 4 Mar 04, 2003 01:38 AM
