Joined Feb 2011
Hi
I've drawn the circuit out and piccies of the Black Mantis 20Amp ESC I have and would like to try your firmware with it - but using PWM input and not I2C. I've read that the Black Mantis, HK BlueSeries and HK Mystery ESC's are suppose to be the same ESC but have a different label on them, but not so sure myself due to the Black Mantis having all N-Channel FET's and the BlueSeries have the usual N/P channel FET's. So I've attached the schematic and piccies here for those that are interested. It differs slightly from the HK BlueSeries/Mystery ESC's it seems because it uses all N-Channel FET's so the upper FET's turn-on level is the opposite of normal. Ignore the 2 blown FET's, that was due to allowing two of the motor wires to short while testing, they have already been replaced. |
Joined Jun 2010
Noob question
The HK 30A Blue Series and the Mystery 30A Blue Series are the same product, right?
HobbyKing 30A Blue Series http://www.hobbyking.com/hobbyking/s...dProduct=13429 Mystery 30A Blue Series http://www.hobbyking.com/hobbyking/s...idProduct=9483 |
Canada, BC, North Vancouver
Joined Dec 2010
Cheers |
Joined Feb 2011
This is the HK Mystery 20Amp.
VERY similar to the Black Mantis (show is previous post), just the top FETS are a different type (P type instead of N type). Identical to the HK BlueSeries I guess. Lots of tiny solder blobs on the Mystery ESC's just waiting to dislodge and do their buisness it seems, so remove the ESC heat shrink and give the board a good clean. I found a very large solder blob on the FET side of the board that just fell off when I touched it - not very good quality control but no matter. |
| Thread Tools | |
| New Product HK 12A / 40A BlueSeries Brushless controllers | CrashingDutchman | Power Systems | 3 | Jan 01, 2011 10:34 PM |
| Discussion E-flite 30A ESC and general ESC-questions | RubenFelix | Power Systems | 14 | Nov 15, 2010 12:06 PM |
| For Sale E-Flite 30A Pro esc NEW 33 bucks...shipped. | misplacedtexan | Aircraft - Electric - Power Systems (FS/W) | 3 | Sep 21, 2010 05:17 PM |
| Found Looking for 2x NIB Turnigy 25A or 30A ESC's | Garret H | Aircraft - Electric - Power Systems (FS/W) | 2 | Sep 06, 2010 04:55 PM |
| Sold AXI 2217/16 and Jeti 30a ESC | dashunde | Aircraft - Electric - Power Systems (FS/W) | 1 | Sep 02, 2010 01:26 PM |
