This thread is privately moderated by turboparker, who may elect to delete unwanted replies.
Old Mar 05, 2011, 02:39 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Data
PZ Mosquito info
All,
I just performed a static RPM test. The motors only have 8 minutes of time on them, so they are not fully broken-in. As usual, the RPM was measured with a calibrated tach under natural light 30 seconds into the run on a freshly-charged cell. I will retest after the motors have a few hours on them.
Aircraft
EW: 64.52g
AUW: 72.88g
Batt: 8.36g
Propshaft to fuselage clearance: 2.25"
Battery: stock
Motors: stock
Props: stock
Conditions
Elev: 910' AMSL
Temp: 70 F
Port: 6810 RPM
Stbd: 6720 RPM
Edit 5/30/11:
After ~10 hours of flight-time, I repeated the static RPM test with the stock cell. I also tested with a Hyperion 240 mAh cell.
Conditions
Elev: 910' AMSL
Temp: 70 F
Stock 250 mAh cell:
Port: 6720 RPM
Stbd: 6720 RPM
Hyperion 240 mAh cell:
Port: 6900
Stbd: 6900
Cell weights as tested:
Stock 250 mAh ----- 8.36g
Hyperion 240 mAh -- 6.78g
Observations:
The motors seem to be better-balanced than they were during the first test, which was before they were broken-in. As expected, the Hyp 240 mAh cell provides a noticable increase in power over the stock 250 mAh cell, with a significant reduction in weight. In this case, thrust is up by 5%, while cell weight is down by 19%. The Hyp 320 should perform even better, as the Hyp 240 gets rather warm in this app. As we have seen in the past, the Hyperions are clearly superior in the higher-current apps - and the Mossie is most definitely a high-current app!
I will also be testing the new TP 65c 325 mAh cells.
turboparker is online now Find More Posts by turboparker
Discussion Start of PZ Micro Mosquito FB mtflyr Scratchbuilt Indoor and Micro Models 134 Sep 25, 2011 12:20 PM
Discussion Official PZ Ultra Micro Mosquito Thread G-Man Parkflyers 3 Feb 05, 2011 09:50 PM
Sold Mosquito twin warbird ARF brand new in box with motors, ESCs and spinners SPasierb Aircraft - Electric - Airplanes (FS/W) 4 Sep 18, 2010 07:46 PM
Discussion PZ Sized Micro Mosquito FB mtflyr Electric Warbirds 4 Jul 15, 2010 06:17 PM
Hopf Mosquito info? Paco1001 Racing Boats - Electric 1 Apr 27, 2003 08:37 AM
