Old Mar 05, 2011, 04:32 AM
EQMOD is offline
Find More Posts by EQMOD
EQMOD's Avatar
Joined Mar 2008
Micro T stabilization: 3S/4S Low Cog Mount and Front Stabilizer Bar Mod
Here is my setup;
A 3S/4S Micro-T with a front Stabilzer Bar (or Anti Sway Bar) attached on the front suspension;
Yup, this setup with the stock shell has enough space for a 3S or even a 4S Lipo battery;
For a good 3S/4S hi speed run, best to keep the car stable and sway free. On this thread, i will introduce two mods that will help to make the car more stable.
1st to tackle is the COG specially if we are to mount a 3 cell or even a 4 cell lipo battery. The only available space i got is the battery tray itself but this time instead of loading it from below, i removed the above casing and made it top loading.
3S Battery neatly mounted from the top. The rest of electronics including ESC were moved up-front;
Not to compromise the chassis structure, i CA'ed the battery cover permanently;
With lipo battery almost in line with the car's axle plane, COG is kept low even if use a 3S or a 4S. It helps minimizing the unwanted body roll.
Another mod added here to keep the chassis leveled even at sharp turns, a front sway/stabilizer bar is added. For the bar i used a walkera 4#3 skid;
The swaybar mount is from a micro-raminator shell post bolted/CA'ed below the chassis;
A couple of stabilizer bar posts are added on the suspension arm;
View from below;
I used a shock absorber piston rod as the mount for the shock absorber and the stabilizer bar eyelet;
VIDEOS:
Stabilizer Bar Articulation Test 1;
Front Stabilizer Bar Losi Micro T - Articulation Tests 1 (0 min 27 sec)
Stabilizer Bar Articulation Test 2: This shows how the swaybar affects the opposite suspension as one side of the front suspension is compressed. Very typical of any front/rear stabilizer setup;
Front Stabilizer Bar Losi Micro T - Articulation Tests 2 (0 min 40 sec)
Testing Car Handling at fast sharp turns;
3S Lipo Brushless Front Stabilizer Bar Micro T - Suspension Stabilization Tests (0 min 55 sec)
For the 3S Lipo mounting, here she is with a quick demo;
3S Lipo Brushless Front Stabilizer Bar Losi Micro T - Low COG Battery Mount (1 min 26 sec)
and finally a good hi-speed Micro-T run with a 3S Lipo on a 10300KV Brushless Motor;
3S Lipo Brushless Front Stabilizer Bar Losi Micro T - Drag Run 1 (1 min 1 sec)
EQMOD is offline Find More Posts by EQMOD
Old Mar 06, 2011, 07:06 AM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
I decided to put the stock wheels back and changed the pinion to a delrin 14T paired with the 49T delrin spur;
And for the stabilization part, i took some frames on the test video and checked if all four wheels remain on the ground during a sharp turn;
Here she is as sampled from one frame capture during the turn - all four wheels on the ground despite the body roll and the compressed spring on the outside turn;
ANd here is the actual gif animation of such turn;
And here are more video test runs on 10300KV 3S using a 49T Spur 14T Pinion ...
3S Brushless Low COG Stabilizer Bar Grease Shocks Dampened Micro T - Run 2 (0 min 59 sec)
Doing some fast turns while camera is placed on the ground;
Low COG Stabilizer Bar Grease Shocks Dampened Micro T - Steering Stability 2 (1 min 5 sec)
Old Mar 07, 2011, 08:54 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
ok, here is one added mod that made a significant difference; Wheel Axle ball bearings
Video of the run ...
Current Specs:
- 3S 180maH Lipo, bottom tray low COG placment
- 10300KV Brushless Motor
- Front Stabilizer Bar
- Tamiya AW Grease Dampened Shrink Tube Piston Shock Absorbers
- Ball Bearing upgrades on the wheel axles
- The rest are stock
Micro-T Ball Bearing 3S Lipo Brushless Front stabilizer Grease Damping Shocks - Run 1 (1 min 5 sec)
Discussion 1/24 Scale 4WD with Front Stabilization Kit EQMOD Micro Cars 1 Feb 13, 2011 11:53 PM
Cool **OFFICIAL** Parkzone Micro T-28 Mod Thread RCSwitz18 Micro Ready-to-Fly 3 Jan 02, 2011 04:30 PM
Sold parkzone micro t-28 bnf canopy mod $80 shipped ohsnap Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 Dec 28, 2010 08:43 PM
Help! Can I use 4S instead of 3S LiPo on my T-34? j10fighter Batteries and Chargers 8 Oct 03, 2010 07:05 PM
