My first attempt at designing a Vectored thrust kite.
Yesterday I built what might be described as a poor man's vectored thrust unit. Today I attached it to my Toucan Kite with mixed results. Perhaps I should have waited for better wind conditions. Winds 9mph gusting to 23. I was surprised at how little turning authority I had considering the range of thrust motion available.
P.S. I'm jealous that you're wearing shorts this time of year! |
Hi Joel,
From my point of view, Your bird (nice kite!) needs another wing-strengthening structure: 2 dehidral carbon tube-rods (at Your bird's wingspan: 6mm diameter) instead of gf-rods (too weak, too heavy), and tensioning battens across the 2 main rods (3mm carbon, massive), at the last third of a winghalf. This helps to avoid wrinkles within the wing, and twisting during flight, as well as what I call 'counter steering moments', what means: When You are sure that You have steered to the right, the bird follows for short, and then - due to the unwanted flexibility and twisting of the 1-rod-wing construction- the bird makes unwanted moves in other directions. When a single-liner birdkite is hanging at it's string, this does'nt matter - wing fluttering looks nice then, and the string stabilizes. For effective RC-purpose, a stiffer wing of vectorized single-liner bird-kites is a must. The photo shows the improvements I made at my Eagle (similar constructed single-liner kite like Yours), with the result of much more flight stability (see the videos). www.crazyplanes.de/eaglemini1.wmv www.crazyplanes.de/eaglemini2.wmv flattermann |
I am waiting for the video to be complete of the first flight of my vectored thrust Eagle Kite. It still needs some tweaking, but at least it flies. It is my first experience flying a vectored thrust kite. It is a bit hard to get used to the slow reaction times of this kite and how best to manage throttle and vector imputs. The Eagle was flown with a Dualsky speed 400 outrunner and a 2500 3s lipoly, with an 8x6 APC Slowfly prop. I plan on putting on a 9x5 for the next fights. The Kite Itself has been sitting in a store room for around 7 years, so the wrinkles are pretty pressed in. This is the Go Fly version of that design. It is actually pretty amazing that this little motor will fly an 8 1/2 foot span kite. I am pleased with how my vectored thrust system is holding up as I must have Jammed the Toucan a dozen times today. I was getting pretty frustrated today tinkering with the Toucan. I am still not convinced that vectoring is an improvement on moveable surfaces.It is different than normal RC with planes with moveable surfaces. It would seem that wing warping would give you more control. I am trying to figure out the easiest way to do this. Vectoring does have the advantage in that it will fly an existing airframe with little modification.
Hi Joel,
'....would start side to side oscillations until it dove to the ground...' I attach 2 photos - I guess, Your wings are missing 'stabilizers' where rods are crossing, to avoid warp of the wings. I also can not recognize kind of 'angle of incedence' (tail-lift for example). Here are 2 videos with eagles having stabilizations as named: www.crazyplanes.de/eaglemini1.wmv www.crazyplanes.de/eaglevectorkite.wmv If You would try a 1000mA Lipo (instead the 2200), You could save a lot of weight, and Your bird would perform better. Saving weight is the most important factor, when converting kites to Vector Kites. '.....I am still not convinced that vectoring is an improvement on moveable surfaces....' Vectoring as a new concept. Vectoring allows, to bring flying objects of many kind easyly without control surfaces into the air (as kites are, but not only kites). Give it some more tries, Joel, especially with Deltas/Deltaboxes, Boxes, Canards, Monowings (single, double, triple), X-Wings... There is a lot more to discover, and, to experience ... ![]() flattermann |
United Kingdom, England, Bognor Regis
Joined Feb 2011
I do not know much about it, but Premier had a kite called the Easy Cruiser that had twin motors.
Dave
Joined Feb 2011
thank´s for sharing your videos
Hi Joel,
don`t give up, your progress looks very good !!! think, you will become a very famous vector-kiter in the states !!! flying field arround the house, wow !!! give your birds (and all your vector-kites) an big 'angle of incedence' and they will fly! ...therefore the keel must have a curve, so the kite never makes the "diver" (=put the nose down) ....that is maybe the main reason why a canard is a very good vector-flyer. take a look at flattermanns eagle-picture: they lift the tail of his bird up by using an alu-tube. premiers eagle has this too. vector kite the rest of your life !!! watch your progress from germany ! |
Joined Oct 2011
Hello, I finally decide to built my own vectorkite. It`´s see very interesting
, I want to built a 8.5" delta box whitout the top of the box like Flatterman design, what size you can recommend me to build the triangle motor structure?Thank you to share your work, this make me possible to dream with this proyect
| Thread Tools | |
| Discussion Micro Vectored Thrust Kite | del | Indoor and Micro Models | 15 | Feb 19, 2011 06:46 PM |
| Cool crikey, i feel stupid… (noob's first attempt at soldering) | tiamak | Batteries and Chargers | 14 | Nov 06, 2010 02:58 PM |
| Discussion My First Try At Designing My Own Plane | wamsy55 | Foamies (Scratchbuilt) | 5 | Oct 08, 2010 11:19 AM |
| Video GWS J-10 and first attempt at thrust vectoring | ditchit | Electric Plane Talk | 0 | Apr 05, 2009 12:53 PM |
