Old Mar 04, 2011, 02:19 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Can anyone help with flying my wing!!
I'm new to flying wings, but have been flying planes and helis for years, just put my new raven wing together and took it out for a couple of test flights, its a right handfull!!! it flys as I would expect at speed but if I try to fly it gently the controls either respond very quickly or not at all, is it just that I have to get used to control response or does anyone think c of g is wrong or set up? I do realise that it needs airspeed over the control surfaces and wing for lift and control but it just seems reeeeeaaaallly hard to fly!!!
Any comments greatfully received! Thanks.
ripmax is offline Find More Posts by ripmax
Old Mar 04, 2011, 02:41 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Rip,
Suggest you double check your CG position and your elevon throws as well. It doesn't take much for either to be out of wack to make these things a handful.
Good luck!
Peter
PS: Also are you trying to fly it too slowly? ie does it handle better when its going at speed?
Peter M is offline Find More Posts by Peter M
Old Mar 04, 2011, 03:16 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
+1 for your cg, and do you use dual rates on the raven, if your radio has dual rates then set the low rates to 50% and that will calm down the wing, and pm teslahed he had the raven, and could help you, here is his raven http://www.rcgroups.com/forums/showp...postcount=2481
carl
doggit is offline Find More Posts by doggit
Old Mar 04, 2011, 03:20 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Elevon throws are set at max as I like lots of control, think u might be right as far as flying too slow, too used to heli and quad flying where u don't need speed over control surfaces for lift and control! Thanks for your reply. Will double check CG.
Old Mar 04, 2011, 03:26 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
doggit, only have a basic radio no rates and using a separate elevon mixer, thanks for the info
Old Mar 04, 2011, 04:00 PM
doggit is offline
doggit's Avatar
Joined May 2009
well if you dont have dual rates then you could try this, put your control rod on the highest hole on your sevos, and put the other end of your control rods in the lowest hole of your elevon horns, this should reduce your throws, and allow you more control, flying wings tend to be a right handful on full throws, unless your an expert wing flyer its best to tone down your throws
carl
Old Mar 05, 2011, 12:50 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
doggit, I think that you reversed the servo and horn holes. What you described would give the most throw on the controls.
djacob7 is offline Find More Posts by djacob7
Old Mar 05, 2011, 01:44 AM
doggit is offline
doggit's Avatar
Joined May 2009
just realised, hope he has not tried my way yet
carl
Old Mar 05, 2011, 10:34 AM
T0RN4D0 is offline
Find More Posts by T0RN4D0
Fail Warrior
T0RN4D0's Avatar
Slovenia
Joined Mar 2010
Probably your CG is too far aft if the thing just wiggles in the air. Wings generaly don't like slow flying, so just let it have a decent air speed. Its not helicopter.
And dial down your throws, your "maximum" control is not really working and causing you to actually have less control then with normal throws. Its like having car steering where wheels can turn 90. o.O
T0RN4D0 is offline Find More Posts by T0RN4D0
Old Mar 13, 2011, 01:40 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Thanks all for your comments, think i may have too much control throw, so i will reduce it n give that a go
Poll Help me decide on my next flying wing PBR600RR Slope 17 Mar 02, 2011 07:13 PM
Help! Can anyone help me troubleshoot my Synrad 48-1 J series 10 watt laser Joel K. Scholz CAD/CAM 14 Nov 23, 2010 01:22 PM
Help! Problem with vapor electronics!! can anyone help? aviator2010 Electric Plane Talk 1 Oct 28, 2010 06:26 AM
Help! Help on setting up my Flying Wing (WHIZZZ) Ben Morrow Beginner Training Area (Aircraft-Electric) 12 Sep 24, 2010 10:27 AM
Can anyone help me to setup the camera mounting on a flying wing blackhawk Aerial Photography 6 Oct 22, 2002 06:28 PM
