Old Mar 04, 2011, 11:05 AM
wac is offline
wac
Find More Posts by wac
wac
Joined Jun 2005
X8 is only flying for 5 minutes, is this right? Maybe some help with numbers?
Hi All,
I just recently built an X8 with rc timer 2836-11 motors with 12x3 apc props and seem to have pretty low flight times.
Yesterday i flew with one 4x 5000mah pack and it gave me 5:35sec before it had no more power to fly, and i charged that battery back up with 4015mah.
I was planing on using 2x 4s 5000mah packs but im thinking that will only give me at the most 10minutes and i was hoping for at least 12-15min.
Are the short flight times im getting normal?
Here are some stats from my watt meter
Lowest voltage 14.06
Watt-Hours Wh 1646.2w
Amp -Hours Ah 4.785
Peak Watts 71.35w
Thank you
Bill
wac is offline Find More Posts by wac
Old Mar 04, 2011, 11:11 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Bill,
You are definitely experimenting here. Are the upper and lower rotating in the same direction? What is your AUW? 3s or 4s? Perhaps APC1365 props are a better match? How old are your lipos and what is the C-rating? Some Gents were using APC1365's on similarly sized Pulso motors getting only 4 minutes on a 4.5kg hexa using a 4s 5000mah c-rating? lipo putting 3200mah back: http://www.rcgroups.com/forums/showt...1#post17048665
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Mar 04, 2011, 02:55 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
i think you're pushing these motors hard with 4S and 12" props, try a 3S or prop down to 10"
i personally would try 2 x 3S 5000 with 12"
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Mar 04, 2011, 02:58 PM
AlcoNaft43 is offline
Find More Posts by AlcoNaft43
Joined May 2009
Looks like motor's KV is too high (1100). I got 16 min hover with 4S5000 quadro from MK with DT750. What is the weight?
AlcoNaft43 is offline Find More Posts by AlcoNaft43
Old Mar 04, 2011, 03:02 PM
mkmkmk13 is offline
mkmkmk13's Avatar
Joined May 2007
RCTimer 2836-11 is 750KV
Old Mar 04, 2011, 05:59 PM
tori3 is offline
Find More Posts by tori3
Joined Jun 2009
It could be the props being too large, but I personally don't think so. I'm flying on these motors and I'm hitting 30 minutes hover time no problem (with a 1.5kg hexa). Here are their performance graphs with 11" props.
Your math doesn't look right - a battery with U = 14.06 V, C = 4785 mAh should have energy on the order of 67 Wh, not 1646. That's about 242,000 Ws, or 242 kJ. Now assuming your rig hovers at 71 W (which doesn't sound right either), you should be able to hover for almost an hour (E/P = 3411 s).
Or was that a per-engine figure? In that case your 5ish minutes are correct. How much does your rig weigh? Mine hovers at around 25 W per motor.
tori3 is offline Find More Posts by tori3
Old Mar 05, 2011, 11:05 AM
wac is offline
wac
wac
Joined Jun 2005
Hi Jim,
I appreciate you chiming in...
Im not sure about the overall weight but it was loaded down with 2 4s 5000mah 25c, askman pro 3 axis camera mount, 900mhz wireless video system, gopro hd camera and a canon hv20 camera (brick).. Im working the next couple days but after ill try and run down to the post office and get it weighed..
My hover is about 1 click above half throttle.. Ill try and provide some more numbers this monday or tuesday..
Thank you
Bill
Originally Posted by jesolins View Post
Hi Bill,
Cheers,
Jim
Old Mar 05, 2011, 11:12 AM
jesolins is offline
Joined Feb 2007
Hi Bill,
Your using the words "1 click" when you mentioned your throttle makes me have to ask if your throttle has the model plane ratcheting still on it? Most Gents do the simple mod to remove that ratcheting which a heli Tx does not have to make it easier to hold a hover. If you need help getting rid of the ratcheting, let me know and I will point you to some mod threads. FWIW
Cheers,
Jim
Originally Posted by wac View Post
Hi Jim,
Thank you
Bill
Old Mar 05, 2011, 11:19 AM
wac is offline
wac
wac
Joined Jun 2005
Hi Jim,
Im sorry but its not actually one click, its one line up from center on the throttle stick.
Bill
Hi Bill,
Cheers,
Jim
Old Mar 05, 2011, 11:20 AM
jesolins is offline
Joined Feb 2007
No problem Bill...I had to ask...
Cheers,
Jim
Hi Jim,
Bill
Discussion Help With Some Numbers Please therealhiphop Electric Ducted Fan Jet Talk 3 Mar 03, 2011 12:19 AM
Discussion Maybe this will cut through some of the chaff dll932 Life, The Universe, and Politics 4 Nov 26, 2010 10:18 PM
Discussion Maybe this help us with the Oil costs... Norman Adlam Life, The Universe, and Politics 5 Sep 23, 2010 04:57 PM
Discussion Help - Flying time HDX 500 only 2 minutes! spityman Electric Heli Talk 12 Apr 28, 2010 06:03 AM
