Old Apr 14, 2012, 12:19 PM
peterjameswhit is offline
Find More Posts by peterjameswhit
Sore Sloper
York, UK
My Stinger arrived this week and it looks beautiful.
Nice to have a set of instructions with info on C of G, ballast sizes, and settings for thermal cruise and speed modes.
There is no mention of flaps linked to ailerons or snap-flap.
Any thoughts?
peterjameswhit is offline Find More Posts by peterjameswhit
Old Apr 14, 2012, 08:43 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I would start with 33% flaps to ailerons.
Interestingly, the setup sheet on my Extasy calls for NO flaps mixed to ailerons in thermal mode.
I tried this, and it seems to work fairly well, you may try that.
You're on your own for the snapflap....
G/L,
Target
target is offline Find More Posts by target
Old Apr 15, 2012, 10:03 AM
Sore Sloper
York, UK
Thanks target,
I normally use about 33% flaps to ailerons and none in thermal mode as you don't need a fast roll rate.
It's the snap flap that I was trying to get a handle on.
Otherwise, it's the long way round of trial and error but hopefully not too much error.
Old Apr 15, 2012, 02:00 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Good luck, I assume that someone will chime in with their own settings.
R,
Target
Old Apr 16, 2012, 02:25 AM
SpeedMaster is offline
Find More Posts by SpeedMaster
UAS Test Pilot
SpeedMaster's Avatar
Norway
Joined Jul 2003
I fly mine with 4mm. snapflap...
SpeedMaster is offline Find More Posts by SpeedMaster
Old Apr 16, 2012, 11:01 AM
Sore Sloper
York, UK
Many thanks.
Is that both up and down?
I tend to bring in snap flap only with the last 20% of elevator so it should not be too disastrous if it goes wrong.
Old Apr 17, 2012, 02:19 AM
Zimodile is offline
Find More Posts by Zimodile
Leicestershire
Joined Sep 2006
peter - not that I have a Stinger, but I would suggest that having snap coming in at the last 20% of the elevator is missing almost all the benefit of it. The wing will have less drag if it has a little camber introduced when it is a higher angles of attack - hence why we use snap flap. Try it on a model that you have this 20% set-up, but change it to just being proportional throughout the elevator throw. No fancy curves, just proportional. I think you will experience a really positive difference. There is no danger to it! In fact it makes the wing operate in a safer window from the flick perspective!
Z
Zimodile is offline Find More Posts by Zimodile
Old Apr 17, 2012, 02:34 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Iceland, Siglufjörður
Joined Sep 2008
And less is more.
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Apr 17, 2012, 08:44 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
+1 to what Z said.
You can turn down your elevator when you add Snapflap, and that's a good thing.
If anything, a 10% delay at the first part of the elevator travel, with the snapflap coming in for the remainder, makes sense to me, to allow for very minor pitch changes.
As he says, you want more camber when operating at a higher AoA on the wing.
R,
Target
Old Apr 17, 2012, 08:50 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
snap flap is confusingly named because "snap" sounds like it is some violent procedure to make the model do something it doesn't want to do, but in fact it is just there to reduce drag. It even works in your thermal setting.
satinet is offline Find More Posts by satinet
Old Apr 17, 2012, 01:03 PM
Sore Sloper
York, UK
Well now,
I used to have my snap flaps linear and on the recommendation of someone else (who shall be nameless) changed them to come in at 80% elevator because "you didn't need them until then".
Have just checked on the Skorp and they are linear. That flies superbly.
Will change the others back and see
Thankfully I just inhibited the programming and did not delete it.
Thank you gentlemen.
Old Apr 17, 2012, 11:30 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
And yes, I use some "reverse snapflap" with down elevator.
R,
Target
Old Apr 18, 2012, 02:56 AM
UAS Test Pilot
Norway
Joined Jul 2003
4 mm down measured at the flap root, and around 1mm up, if you want.. I dont use up... Ailerons follows flaps.
Old Sep 29, 2012, 02:51 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
I did 28 laps today with my stinger in F3b. Very pleased
The model is doing well for me in B. It's nice to fly.
Old Sep 29, 2012, 07:48 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's awesome, Tom, great job, congrats!
R,
Target
Discussion F3B & F3F rules on airfiol shape shifting! Sceptics welcome! Just flyy Multi Task F3X 21 Mar 21, 2011 05:35 AM
Alert F3B/F3F models for sale - UK Stephen Haley Multi Task F3X 6 Dec 12, 2010 06:32 AM
For Sale SOLD!!! Awesome SupersonicR F3B/F3F glider FLY F3B Aircraft - Sailplanes (FS/W) 14 Dec 07, 2010 05:32 PM
Sold F3F,F3B F3J servo gear concreteman Aircraft - Sailplanes (FS/W) 0 Oct 12, 2010 07:27 AM
Sold Boreas F3F/F3B + Wing Bags + Sailplane Backpacks Kai@UCSB Aircraft - Sailplanes (FS/W) 2 Sep 03, 2010 05:45 PM
