Espritmodel.com Heli Air
Old Mar 09, 2011, 04:27 PM
Joined Feb 2011
flying a vector-Deltabox as a single line kite
if you add more tails, it even fly`s better !!!
picture 1 + 2 shows a one-point bridle adjustment (about 10cm behind the top of the keel)
..and instead of the carbon-vector-frame i use a lighter 6mm carbon tube !
Vectorflyer is offline Find More Posts by Vectorflyer
Old Mar 09, 2011, 05:32 PM
Twisted Sheets's Avatar
The Gorge - Oregon USofA
Joined Sep 2006
Kites!
Wow. Spectacular pictures and what a wonder. I can fly my kite as a kite!
Any ideas about the travel version?
Twisted Sheets is offline Find More Posts by Twisted Sheets
Old Mar 09, 2011, 10:36 PM
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
what is the highest wind range that the various models remain controllable and able to penetrate?
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Mar 10, 2011, 01:13 PM
Joined Feb 2011
flying on a windy day
hi Joel,
if the wind is more than 2 Bft, i fly my kites on lines.
vector-kite-flying makes sense (and a lot of fun) from 0-2 bft.
the premier-canard fly`s best in windconditions from 0-1 Bft.
Premier-Deltabox 0-1,5 Bft.
Best for windpenetration is the Premier-Pyramidbox: 0-3 Bft.
if you like, try this:
start your pyramidbox at 4 Bft, fly no curves just straight, if you throttle the motor your kite will come down and drift at the same time backwards.
After five minutes you land at your starting place!
Old Mar 10, 2011, 02:45 PM
Joined Aug 2000
A higher wind range is one Parameter a kite with moveable surface has over vectored thrust. I would not hesitate to fly my Canard in 15+ mph winds. Here is a video of A custom Hawkeye with an attached elevator flown in winds gusting to 25mph.
Hawkeye High Wind Elevator Test (5 min 11 sec)
Old Mar 10, 2011, 06:04 PM
Joined Mar 2011
What size motor?
Hi -I'm just starting out with a kite thats 1400mm span by 570mm high. What size motor would you recommend? And is there a critical distance between the motor and the kite's spine?
Would appreciate any help.
Coleoptera is offline Find More Posts by Coleoptera
Old Mar 13, 2011, 04:41 PM
Joined Feb 2011
PremierRC: Pyramidracer Tecmo
vectorkite your life 8 "PremierRC Pyramidracer" (2 min 35 sec)
Old Apr 27, 2011, 02:24 PM
Joined Feb 2011
some of my new 2-D kites
during the last weeks i built some vectorkites with a simple 2-D-vector-unit:
motor is connected with the servo and turns right and left, up and down flight via throttle control !
enjoy the pictures
Name: 2-D-Deltabox orange rush.jpg
Description:
Description:
Description:
Description:
Description:
Description:
Old Apr 27, 2011, 02:57 PM
Joined Feb 2011
my new kite project
still seeking for a name, but it looks like a big paperflyer, a dart, a pointer or a starship. i will inform you about my progress with this kite-work.
i like to make a video where i used my car as a "hangar" and landing my "vector-starship" inside....
Description: the kite inside the "hangar"
Description: kite with vector-unit
Description: with tails as a single line kite
Old Apr 27, 2011, 04:19 PM
Expat
Japan
Joined Apr 2010
looking good
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Apr 29, 2011, 03:48 AM
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
That pointer/dart/starship kite looks good. I hope you don't mind if I copy it
slebetman is offline Find More Posts by slebetman
Old Apr 30, 2011, 02:03 PM
Joined Feb 2011
maiden flight of the "vectordart"
i fly the "vectordart" first with my premier generation I unit. enjoy
vector kite your life 17: vectordart (1 min 52 sec)
Old Apr 30, 2011, 02:41 PM
Joined Feb 2011
vectorstarship flying home in his hangar
...then i changed to 2-D-unit and make test-flights. i was astonished about the perfect flight performance, so i put my photo to the transmitter and make these shooting.
enjoy
vector kite your life 18: landing a 2 D vectorkite in a caravan (1 min 57 sec)
Old Apr 30, 2011, 02:48 PM
Joined Feb 2011
...next time i will try to start the vector-kite out of the car
....so i don`t have to leave the car anymore, when i go vector-kiting !
Old Apr 30, 2011, 04:37 PM
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Good stuff! That's what we wonna see
flattermann
flattermann is offline Find More Posts by flattermann
Discussion Premier RC Vector Kites Patron RC Kites 22 Oct 24, 2011 12:15 PM
Discussion Vector Kites - wow! Slider2732 Indoor and Micro Models 113 Feb 21, 2011 11:57 PM
Discussion RC Vector Kites proposal Harry D Site Chat 15 Feb 15, 2011 01:28 PM
Off Site Vector Kites tbroeski Aircraft - Electric - Miscellaneous (FS/W) 3 Jan 16, 2011 06:03 PM
Cool Vector Kites tbroeski Electric Sailplanes 0 Jan 06, 2011 11:04 AM
