Old Mar 03, 2011, 03:28 PM
avengedkevinfold is offline
Find More Posts by avengedkevinfold
Joined Feb 2011
ParkZone P-47 Thunderbolt
If I have the ParkZone P-47 Thunderbolt and want to add flaps and retracts. Can I do this with a DX6? Or will I need 7 channels since this plane has two separate servos for the ailerons.
avengedkevinfold is offline Find More Posts by avengedkevinfold
Old Mar 03, 2011, 03:40 PM
capadotia is offline
Find More Posts by capadotia
Joined Jun 2008
You only need 6 channels. You need to put both ailerons on a y-harness and plug them into the aileron channel. Then put the gear on a y-harness and plug that into the gear channel. Then put the flaps also on a y-harness and plug that into the flap channel.
You can also do it with only 5-channels if you put the gear and flaps into one channel on yet another y-harness and program your radio to mix the gear and flaps together.
capadotia is offline Find More Posts by capadotia
Idea Parkzone P-47 Thunderbolt Modification Thread Smokescreen38 Electric Warbirds 87 Feb 18, 2012 02:38 PM
Wanted Parkzone P-47 Thunderbolt Broken wing 31 Aircraft - Electric - Airplanes (FS/W) 1 Mar 03, 2011 11:51 PM
Discussion P-47 thunderbolt e-flite copy 59.99 scubajohnny37 Hot Online Deals 20 Dec 10, 2010 02:34 AM
Discussion Eflite copy P-47 thunderbolt scubajohnny37 Product Announcements 6 Sep 26, 2010 01:21 PM
